07-27-2022, 05:54 PM | #1 |
Drives: 2016 Camaro LT Join Date: Jul 2022
Flame Kit Installation
Trying to install a Hot Licks Flame Kit onto my 2016 Camaro LT. The kit requires me to wire the ingintion coil through a button to cut ignition from my engine when the button is pressed. I'm having alot of trouble locating the correct fuse that corresponds to the ignition wire that I will then route through the button. I see two fuses that say Even/Odd coils. There is another fuse that says: Fuel system control module ignition. Also a couple more fuses that have ignition in the name. I'm posting here because I want to be sure on which wire pertains to the ignition to make sure I don't mess up anything with my firing order. Any help would be much appreciated.
07-27-2022, 06:02 PM | #2 |
i would take it to a shop...i wouldnt do it yourself
07-29-2022, 10:51 AM | #3 |
I tried taking it to a shop, they told me alot of lies like the kit would put my car into limp mode so they would have to install it "their way" which is not true because my friend did it on his car. They also wanted to charge me to remove my cats which is not nessesary for the flame kit as the kit will blow the cats out itself.
flames, ignition, ignition coil, wiring |
