Old 05-25-2021, 01:40 PM   #1
secrethero89
Drives: 2011 3.6 V6 RS Cabrio
Timing Chain Replaced but still same problem (FIXED)
Hello,
I have 2011 Camaro V6 Cabrio at 55.000miles. I had check engine light which throws P0008,P0009 codes, my car was running sluggish, extreme power loss...
I had replaced the timing chain with Cloyes kit next month. But still check engine light is on with an additional P0016 code(P0008-P0009 still there). My car is still running sluggish, nothing changed..
Today i got replaced the 4 VVT Sprockets(cam phasers) with new ones. Still no change.
Timing Chain Replaced(Cloyes)
4 Cam Sensors Replaced (AC Delco)
4 VVT Selenoid Sensors Replaced(OEM-Aftermarket)
4 VVT Sprockets Changed(OEM-Aftermarket)
ECM flashed - reinstalled software
I am so disappointed. What should i do next?
Thanks.
**********UPDATE 31.05.2021*************
Yes, the problem is finally found! It's reluctor wheel! Skipped 1.5 teeth...
My mechanics fixed the issue without removing the crank.. YES it's TRUE! He gently and carefully applied force and take the wheel to the original position. BUT BE CAREFUL YOU MAY BREAK THE WHEEL!! He also applied a mini tack weld to avoid any further movements.. My car is back!! Day and night difference... It's a shame that GM's engine has such an important manufacturing defect!!!!!!!!! I recommend everybody who experience P0008, P0009, P0016, P0017 timing related DTCs to CHECK RELUCTOR WHEEL POSITION before replacing the chains... It's very easy... Just remove the oil pan and check the teeth to make sure it's 3.5 teeth away from the crank's edge.
Thanks everybody for helping my issue...
secrethero89 is offline   Reply With Quote
Old 05-25-2021, 07:29 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Were the timing chain tensioners replaced at the same time as the chain? If so, I wonder if the reluctor wheel has moved, putting the crankshaft out of alignment relative to the camshafts.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 05-26-2021, 05:49 AM   #3
secrethero89
Yes, it comes with cloyes kit. changed all tensioners, guides.. My mechanics says that it couldn't be reluctor wheel since my car is only at 50.000 miles and it's very unlikely to fail.. Is reluctor wheel a common problem? Anybody experienced issue with Relcutor wheel?
Old 05-28-2021, 10:54 AM   #4
secrethero89
Can you please check my reluctor wheel? It seems like it skipped 1.5 teeth (5 teeth instead of 3.5)
Old 05-28-2021, 11:43 AM   #5
KillboyPowerhead
Drives: 2015 Z/22
If you're referencing this: https://www.autoserviceprofessional....tor-wheel-woes
I'm no expert but I'd say the wheel has moved.
Old 05-28-2021, 02:51 PM   #6
cawengr
Drives: Classy
It has definitely moved, it needs to be 3 1/2 teeth from the edge of the crank relief. need to pull the crank and replace it or remove crank and pin the wheel in the correct position.
cawengr is offline   Reply With Quote
Old 05-29-2021, 09:24 AM   #7
cawengr
Drives: Classy
This is the file from GM https://static.nhtsa.gov/odi/tsbs/20...37734-9999.pdf
Old 05-31-2021, 12:22 PM   #8
secrethero89
Old 07-28-2021, 08:17 PM   #9
dreamst8
WrkrBee
dreamst8's Avatar
Drives: 16 Hyper & 11 Victory
Timing chain
May I ask what is costs to replace a timing chain?
2016 Hyper Blue w/ Pearl White Rally Stripes, Black Interior 2LT/RS V6 A8,
Lights, Memory & Convenience Options
Sunroof
2011 2 LT/RS Victory Red V6 M6
dreamst8 is offline   Reply With Quote
Old 09-09-2021, 06:40 PM   #10
Michaels_Camaro
Drives: Chevrolet Camaro
If you don’t mind sharing, what was his method for moving the reluctor wheel back in position?
Michaels_Camaro is offline   Reply With Quote
Old 09-11-2021, 04:41 AM   #11
AlanRubin
Drives: 2010 LS
You need to make sure crank will not move. There is a tool that will hold
it in place at the teeth on the flywheel/flex plate.
There are holes in the reluctor wheel you can brace something into, to move
it.
There is also a fix kit, you drill a hole, tap, and bolt it. The reluctor wheel
is at a crank counter weight, so the kit has you drill through the wheel, into
that, tap it all the way through and use the provided bolt.
I have had a P0009, but it has gone away, and I didn't do anything with
the wheel. I had replaced all the VVT solenoids, and cam sensors. Even
then, it came up a few times, but I have not had it since I unclogged
the driver side muffler. I had that code for a year, and it has not shown
up for over 6 months now. It would only come up if I used manual
mode, was in 5th or 6th going up a hill with the pedal to the floor. Well,
not anymore...
AlanRubin is offline   Reply With Quote
Old 10-13-2021, 10:09 AM   #12
TooCool5
TooCool5's Avatar
Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP
How did you get the pan off. Is there room with the cross member?
2010 Camaro Auto, Inferno Orange, Titanium Interior, Gearhead Wheels AIRAID CAI
TooCool5 is offline   Reply With Quote
