Old 11-06-2014, 06:09 AM   #1
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Unhappy Need help/opinions/options
Went out last night to test the new setup and had bad "clunking" noises in the rear through the 60. (No noise in the burnout box )
It was really bad when turning down the return road. Car would pull to one side when accelerating.
Axles or rear?????
If rear...Looking for advise and cheaper rebuild/upgrade options. 9 in isn't really in the plans but will be considered.
Rear currently has DSS axles (second set)
DSS driveshaft
3.70's Posi Mod/caps
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 11-06-2014, 07:30 AM   #2
lexlueger
lexlueger's Avatar
After thinking about it....Axles. Anyone from DSS still on here?
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 11-06-2014, 07:42 AM   #3
H-E
Drives: 2010 zr1 Camaro 2011 vert
Give me a call and we can go over a few things..
H-E is offline   Reply With Quote
Old 11-06-2014, 08:22 AM   #4
lexlueger
lexlueger's Avatar
PM your # again. Thanks.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 11-06-2014, 06:00 PM   #5
lexlueger
lexlueger's Avatar
No other input??
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 11-07-2014, 07:53 AM   #6
H-E
980 521 0722
Old 11-07-2014, 10:36 AM   #7
lexlueger
lexlueger's Avatar
980 521 0722
Just called, no answer. Need to get a diff/w wavetrac A.S.A.P
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
