04-18-2024, 04:42 PM | #1 |
Drives: Chevrolet Camaro SS Join Date: Jul 2021
Re-gearing
So, if you swap from stock 3.45 to 3.91 in an M6 car, is that going to throw off the speedo? Wondering if so, how much for considering having it corrected.
04-18-2024, 04:55 PM | #2 |
04-18-2024, 04:59 PM | #3 |
Uggg... Wasn't thinking about it. Now, I guess I need to add that to the bill $$$.
04-19-2024, 07:54 AM | #4 |
Anthony S
When I had my avalanche tuned, I told them the wrong gear ratio. I thought I had the 345 gears, turns out I had the 410 gears... Speedo was off by 10mph. Drove me crazy.
If you have a tuner who already tunes your stuff its fairly easy to flash a small change like that into the tune. They will probably hook you up for some beer money. Or if you don't have a local tuner, HP tuners credit is $100 plus the tuners fee for going in and making the change.
04-19-2024, 09:13 AM | #5 |
Yep. I pinged the shop that previously tuned the car. They said no problem, they wouldn't charge.
04-21-2024, 02:57 PM | #6 | |
Drives: 2010 Chevy Camaro 2SS coupe (MT) Join Date: Jan 2024
What software for tuning done?
I have yet to see one that doesn’t allow one to recalibrate for different gearing and tire/wheel combinations. Also, you can simply adjust only THOSE parameters and leave everything else as is, so you’re still basically stock ECU/ECM wise, only with a recalibration that doesn’t affect anything engine management wise. I recently went with HP Tuners MPVI 3, and I love it; it’s just very complicated for some to learn, if you’re not a person who will take time to study the software and other car-related tech and computer tech stuff. |
04-30-2024, 05:43 PM | #7 |
Drives: 2012 SS Join Date: Feb 2016
Most tuners will do minor updates for free of charge if they have already tuned your car. Or most all handheld tuners have the option to change the ratio for the speedometer.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
