Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
BeckyD @ James Martin Chevy
Old 11-10-2018, 02:28 PM   #1
Whocares05050
Drives: 2018 Camaro SS 1LE
1LE Trans Fluid Amount
I bought 4 liters of trans fluid but my dealer said cause the 1LE has a trans cooler it requires 5.2 liters. Is this accurate? My searching didn't come up with much. Thanks.
Whocares05050 is offline   Reply With Quote
Old 11-10-2018, 03:25 PM   #2
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
I just did mine and purchased a case of six as it was cheaper than buying five bottles, it ended up taking 4 and maybe 4-6 oz out of the fifth, I may have spilled a bit to.
Warrior102 is offline   Reply With Quote
Old 11-10-2018, 04:49 PM   #3
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
I posted Tremec's datasheet for our TR-6060 in this thread: https://www.camaro6.com/forums/showp...5&postcount=24
It's fluid capacity is 3.45 Liters, approximately.
Ryephile is offline   Reply With Quote
Old 11-10-2018, 05:01 PM   #4
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
I thought I read somewhere you needed to fill it full then take some out. Dont remember the details. Or why its bad to over fill.
Pollock is offline   Reply With Quote
Old 11-10-2018, 08:05 PM   #5
Whocares05050
Yea the dealer told me the regular SS takes 3.45-4 because it has no trans cooler and the 1LE does have the trans cooler so it takes up to 5.2.... very conflicting info.
Old 11-11-2018, 07:53 PM   #6
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
Originally Posted by Whocares05050 View Post
Yea the dealer told me the regular SS takes 3.45-4 because it has no trans cooler....
Ughk, your dealer mislead you. All manual trans SS's have the front horizontally mounted trans cooler.
Old 11-11-2018, 09:48 PM   #7
Camaros & Coffee Norcal
Camaros & Coffee Norcal's Avatar
Drives: 2013 Camaro 1SS & 2015 Camaro SS
We do these pretty often for our track customers. 7.4 pints (3.7 qts) for the SS and 10.2 pints (5.2 qts) for the 1LE is OEM recommendation. On average we see just shy of that, but not much. We have exclusive offers on Amsoil for Camaro 6 members, so dm us for more info if interested. Hope this helps.
Camaros & Coffee Norcal is offline   Reply With Quote
Old 11-12-2018, 07:17 AM   #8
24v
Drives: 2018 SS
So does the SS 1LE use more fluid than the standard SS or not?
24v is offline   Reply With Quote
Old 11-12-2018, 10:55 AM   #9
Whitespeed
Drives: 2018 1SS 1LE & 1973 Datsun 240Z
Deleted my reply. My recollection was incorrect.
Nigel
Whitespeed is offline   Reply With Quote
Old 11-12-2018, 01:20 PM   #10
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
The SS 1LE has the exact same coolers as the normal SS. In fact, the trans cooler is also the same used in the Heavy Duty cooling package for the 2.0T and V6, and also the ZL1.
https://www.gmpartsgiant.com/parts/c...~22960693.html
Old 11-12-2018, 08:06 PM   #11
Whocares05050
I changed it out today. Took 3.6l
Old 11-12-2018, 08:32 PM   #12
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
That's correct. The service manual stresses not to overfill the MM6. Here's a quote from the manual:
"IMPORTANT:
Transmission fluid level setting must be followed exactly as written or the
transmission may be overfilled or under filled. For fluid recommendations, Refer to Adhesives, Fluids, Lubricants, and Sealers (MM6)
Transmission fluid level MUST be 3.2 mm (1/8 inch) below (1) the fill plug. This can be done by one of the following methods:
1. Bend mechanics wire to 3.2 mm (1/8 inch) to check fluid level. Add or remove fluid as necessary.
2. Fill transmission until level with the bottom of the fill plug hole, then remove 240 ml (8 ounces) of fluid."
See the attachment in this post called "manual trans flush.pdf": https://www.camaro6.com/forums/showthread.php?t=500494
I also referenced this thread when I did mine: https://www.camaro6.com/forums/showthread.php?t=492814
Old 12-26-2018, 05:34 AM   #13
SaphfireSS
Drives: 2017 Camaro 1LE SS
Yes it does but the 1LE sends trans fluid to rear diff for cooling as well. Pretty sure SS does not.
SaphfireSS is offline   Reply With Quote
Old 10-24-2023, 02:31 PM   #14
aBee150
@NHTFALL
aBee150's Avatar
Drives: 2018 Camaro 1SS 1LE
Sorry to revive this thread, just want to make sure I didn't mess anything up. I just did my transmission fluid change. I didn't measure any quantities and had only bought 5 quarts of fluid.
I emptied out my fluid through the drain plug (removed the transmission support), and I filled it back up to the fill line. I siphoned out 240 ml of fluid (1/8 inch below fill line).
Car drives fine and the temperature seems the same, but there is no way I filled 5.2 qts of fluid.
aBee150 is offline   Reply With Quote
