02-17-2012, 09:27 PM | #1 |
So easy to love Camaros
Tire Pressure - What should it be..really?
I searched but have not found the answer to this question....
The Pirelli P-Zero's sidewall states a max pressure of 50 PSI, the car's tag says 36 PSI, it appears the TPMS goes off at under 32 PSI...I was always taught not to follow the tag cuz you never know if the tires have been changed from manufacture's specs...so I've always adheared to the sidewall. Is everyone else doing so? Not looking to wear these out in 15K. It would seem GM set the low pressure warning for these tires too low, if that is the case. Cold, they should hold about 45 PSI and will warm up close to max. Logical right? Can we set the TPMS to alert for higher pressures, say 40PSI closer to the tires actually rating? OK, let's hear it. Thanks.
02-17-2012, 09:31 PM | #2 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
I go with the 36 cold off my own tire gauge...the dash reading has never matched yet!
02-17-2012, 09:34 PM | #3 |
36 is correct, always follow the cars recommendation for proper handling.
02-17-2012, 09:35 PM | #4 |
Are you sure the side walls say 50psi? Before garaging my camaro I thought it said Max 44psi.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
02-17-2012, 09:39 PM | #5 |
02-17-2012, 09:39 PM | #6 |
I keep mine at 35-36 cold. I have to put air in once a month or so.
02-17-2012, 09:42 PM | #7 |
Turbine Cowboy
Drives: 2010 Yellow 2LT Camaro Join Date: Jan 2011
I keep mine at 36. Always go with the vehicle recommendations
2010 YELLOW 2LT
02-17-2012, 09:42 PM | #8 |
Drives: 2010 ZL550& 2021 C8 Z51 Join Date: Feb 2010
I keep mine between 36-39 psi. When I went on SRT driving experience they kept the tires on the SRT vehicle, on roadcourse at 50 psi. Thought that was a little high, but the cars handled really good.
02-17-2012, 09:48 PM | #9 |
Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
the max psi is for setting the bead. for stock size always go with the body tag. but if you put 22's on, you want to adjust accordingly
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ |
02-17-2012, 09:53 PM | #10 |
Drives: 2017 Camaro SS Join Date: Oct 2009
50 PSI is not the recommended tire pressure. 36 PSI cold is what you should be running.
02-17-2012, 10:07 PM | #11 | |
Drives: '12 ZL1 #1609 Join Date: Feb 2010
Life is too short to drive cars that suck.
My build Thread |
02-17-2012, 10:14 PM | #12 | |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
Stick with the door jam recommended setting of 36 PSI. The TPMS low alarm of 32 PSI is probably correct too. A 4 PSI drop in tire pressure from 36 equates to an 11.11% drop which is significant.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
02-18-2012, 09:06 AM | #13 |
Drives: 2SS/RS Join Date: Sep 2008
Remember the difference between cold and hot pressure is about 5 PSI during the summer and more than that during the winter.
During the summer i run between 35-40 PSI cold depending on if I get distracted for a few seconds while putting air in. During winter I run a little bit less cause the air will expand more when the tires warm up. I run about 30-32 PSI cold during the winter. |
02-18-2012, 09:25 AM | #14 | |
Drives: 2011 Coupe, 1LT, A6, No RS Package. Join Date: May 2011
Let's say they refer to 70 degrees as the initial temperature, and your car is supposed to be at 35 PSI when it's 70. I would assume that means that if it's 40 degrees out, you should set your tires to 38 PSI, and if it were 100 degrees out, then set the tires to 32 PSI. So if it's hotter out the PSI goes down, and if it's colder out the PSI goes up. Am I correct according to my above example?
Never Underestimate The Power of Forums
pirelli, pressure, psi, tire pressure, tires |
Similar Threads | ||||
What do all the abbreviations mean? | CrzyGamr2 | 5th Gen Camaro SS LS LT General Discussions | 77 | 12-07-2012 04:34 AM |
Tire Pressure Questions | nalinc23 | Wheels and Tires Talk Sponsored by The Tire Rack | 21 | 09-15-2010 01:18 PM |
factory 20in wheels cold tire pressure? | mike12345 | Wheels and Tires Talk Sponsored by The Tire Rack | 7 | 05-11-2010 12:58 AM |
Tire pressure monitor CEL after tire change | B.Buster | Wheels and Tires Talk Sponsored by The Tire Rack | 6 | 04-01-2010 08:45 PM |
Tire Pressure Problems | Matster | Canada | 14 | 10-03-2009 06:11 AM |
