AWE Tuning
Old 03-15-2024, 09:56 PM   #1
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
SPL rear toe arms track use
So I bought these mainly to avoid the rear toe slipping over time. (Many threads on alignment bolts). However even with the ZL1 1LE suspension having less rubber in the system I felt the difference in handling.
The car has more (good thing) head toss side to side. It is just less compliant and because of that it handled differently for the better. Hitting curbs on the track was very noticeable, which changed some lines. Also good actually. Thumbs up.
I bought the rubber dust covers to keep the joints clean.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 03-16-2024, 01:38 PM   #2
Badmojo
aka BeastZL1
Badmojo's Avatar
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra
Cool. I had them on my ZL1, but haven’t upgraded yet on the ZL1 1LE.
Sent from my iPhone using Tapatalk Pro
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Badmojo is offline   Reply With Quote
Old 03-22-2024, 06:26 PM   #3
Scargoes
Scargoes's Avatar
Drives: 2018 Hyper Blue 2SS 1LE
I bet the difference in the feel is due to the bar vs the stamped metal plate as both the OE and SPL parts are fitted with spherical bearings.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 03-23-2024, 10:31 PM   #4
wakespeak
wakespeak's Avatar
The OEM arm has a small amount of rubber in the bushing. It's meaningful on the track net/net.
Old 04-06-2024, 04:34 PM   #5
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
Did you noticed any change in how the car put the power down on center to exits?
cdb95z28 is offline   Reply With Quote
Old 04-09-2024, 08:58 PM   #6
wakespeak
wakespeak's Avatar
Mid corner to corner exit less compliance steering in the rear, so steering wheel inputs more precise. On the street or track I noticed less swerve on power. Wheels spin but car tracks straighter.
Old 04-10-2024, 07:54 AM   #7
NG329
Drives: Chevrolet Camaro ZL1 1LE
I'm split 50/50 on this. In my 2021 ZL1-1LE I ran the BMR toe rods and it was more rigid in the back. Coincidentally, once I stiffened the chassis further, I had a hard time hitting my PRs back when the car was completely stock.
On my 2022 I am all stock and I've gone faster than I ever have. ...essentially, going back to stock from the rigid setup I had on my 2021.
I feel like some compliance is needed on a chassis this stiff, especially when the tires start to wear down a bit.
NG329 is offline   Reply With Quote
Old 04-10-2024, 10:45 AM   #8
Badmojo
aka BeastZL1
Badmojo's Avatar
My opinion is there is a difference in adding toe rods and doing a full BMR suspension. The factory toe arms with eccentric bolts are horrible at maintaining toe alignment on a track car.
I don't think BMR tests or engineers their components. A full BMR setup adds weight and reduces the range of motion of the rear suspension. It might work for a drag car, but isn't ideal for the road course.
2019 Camaro ZL1 1LE
Old 04-10-2024, 10:53 AM   #9
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i have the full spl parts setup on my ss track car they make amazing products and it definately helps with car feel on track
Old 04-10-2024, 11:49 AM   #10
NG329
agreed on both points.
Old 04-10-2024, 12:46 PM   #11
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
BMR doesn't produce performance components, the only thing worth buying from them is the rear toe rod, everything else is a waste of money.
Christian1LE is offline   Reply With Quote
Old 04-10-2024, 04:07 PM   #12
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
That's good to know.
dpevans is offline   Reply With Quote
Old 04-11-2024, 09:38 AM   #13
NG329
I ran their cradle braces, toe rods, strut tower brace, and sway bar linkages. Definitely not junk.
It wasn't the prettiest stuff (compared to SPL) but it worked.
