Vararam
Old 02-17-2014, 12:45 PM   #15
Old 02-17-2014, 01:31 PM   #16
Frost
Frost's Avatar
Drives: GM anything
Originally Posted by Bad70supreme View Post
.... and when I pulled the belt off and on it just happen to start making this noise....
It's already been said in this thread... you don't take the A/C belt and put it back on; if you take it off you must replace it. That's how it's made and was the intention when designed.
Frost is offline   Reply With Quote
Old 02-17-2014, 05:36 PM   #17
AnUnarmedMan
AnUnarmedMan's Avatar
Drives: 2013 LS
Is it your wife? Mine whines every time I talk about my car lol!!!!!
AnUnarmedMan is offline   Reply With Quote
Old 02-18-2014, 12:53 AM   #18
I reused my AC belt just fine.
Old 02-18-2014, 08:15 AM   #19
Frost
Frost's Avatar
Drives: GM anything
Cool, but it's a one-time use belt and it's designed to be replaced once removed. Well over half of them that get re-used squeal and/or have other A/C problems. It's great that yours worked, but it's not really something you should probably advise people to do, since most will have a problem afterwards.
Old 02-18-2014, 08:34 AM   #20
AKA-22
AKA-22's Avatar
Drives: ELLE-1
interesting ..
AKA-22 is offline   Reply With Quote
Old 02-18-2014, 11:19 AM   #21
Wait.............. I DID have problems with the AC going warm in really hot weather. It would go warm then blow cold when the sun went down. (interestingly enough the sun would go down and the outside temps still be the same or even in a tunnel the AC would blow cold) The belt never squealed or anything. Surely my problem wasn't due to reusing that belt? I'd be surprised but I suppose it's possible.
Threadjack........... sorry, I'm done.
Old 02-18-2014, 04:36 PM   #22
Frost
Frost's Avatar
Drives: GM anything
That happened to us back in spring / summer of 2010 when we were doing our first 5th gen installs. The first one didn't squeal at all, but had problems with the A/C temp being warm/hot when it should have been ice cold.
Old 02-18-2014, 04:53 PM   #23
Damn. I'll never do that again. haha
Old 02-20-2014, 03:54 PM   #24
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
Interesting.... I've re-used mine twice and wondered why my AC never seemed to be cold enough. Thanks, learn something new every day.
BFASTNOTLAST is offline   Reply With Quote
Old 04-08-2014, 12:08 PM   #25
LonDowell
LonDowell's Avatar
Drives: 2012 SS/RS
oh boy... I converted my l99 to LS3 and put in a CAM. Love it, BUT, today I turned on the A/C and it worked OK for a while... Then, slowly got warmer and warmer. Heard a sound like a "howl" from the engine bay. Turned off and on the A/C over the next twenty minutes and sure enough, it would be cold for a while, then warm...
They mentioned that they would have to replace the stuff that is used instead of Freon these days... No mention of a belt replacement. It is at the dealer now looking into the A/CC issue. I'm hoping they don't come back at me with an issue with warr...
LonDowell is offline   Reply With Quote
A/C Whining Noise Modern07 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 54 01-14-2014 08:44 AM
V6 whining noise. i007spectre Tuning / Diagnostics -- engine and transmission 8 08-02-2010 07:24 PM
whining engine noise with increase in rpm camarowa Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 01-27-2010 05:28 PM
QC missed something-- AC Compressor making a whining noise under engine load Kyle.Gilmour Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 12 10-09-2009 10:42 PM
Whining noise from transmission!? azvren Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 06-28-2009 05:33 PM
