10-29-2011, 02:07 PM | #1 |
Drives: AN OLD PILE, buying a ZL1 Join Date: Sep 2011
new manual trans
Question, I test drove a 2011 SS and the manual trans without a short throw felt sloppy. Does the 2012 SS and ZL1 have a different trans than the 2011?
10-29-2011, 02:10 PM | #2 |
I.AM.
Drives: 2011 2SS/RS/A6 cammed-n-whippled Join Date: Oct 2008
The shifter or the trans felt sloppy? If you just mean the shifter, that's easy enough to change.
I'm almost positive it has the same trans but an upgraded version to handle the extra power. It also has a short throw sifter.
NY5thgen.com
10-29-2011, 05:12 PM | #3 |
Use the Force
Both the MG9 transmission and the short throw shifter in the ZL1 are different from the SS.
Walk softly, carry a light saber and drive a ZL1!
10-29-2011, 05:42 PM | #4 | |
I used to be Dragoneye...
The short-throw on the SS is derived from a Hurst unit. ZL1 uses its own design. |
10-29-2011, 05:50 PM | #5 |
Drives: Waiting for the 2013 ZL1 Join Date: Apr 2010
10-29-2011, 05:53 PM | #6 |
MG9 is the RPO for the ZL1's flavor of TR-6060.
10-29-2011, 07:03 PM | #7 |
10-29-2011, 09:13 PM | #8 | |
10-29-2011, 10:13 PM | #9 |
Use the Force
I think it is a dual disc clutch also vs a single in the SS model.
10-29-2011, 10:21 PM | #10 |
You're right. I've always thought of the clutch and transmission as two separate components, so I forgot about that "little" detail.
10-31-2011, 11:24 AM | #11 |
Drives: 2010 CAMARO BLK 2SS/L99 Join Date: May 2009
It should be a transmission that you can beat to hell and back. The TR6060 is pretty strong in stock form already.
10-31-2011, 12:36 PM | #12 | |
TREMEC (TR6060) 6-Speed Manual The standard transmission for ZL1 comes in the form of the latest capacity.TREMEC (TR6060) 6-speed manual with a revised short-throw shifter. The new shifter has a more aggressive motion ratio and incorporates a revised shift knob. The shape of the shift knob is designed to be more performance oriented in the driver’s hand, while the shorter throws result in a more direct feeling of connection with the car for spirited driving. The TREMEC provides smooth transfer of the engine’s exceptional power and torque. In fact, it incorporates various upgrades and a 30% increase in torque |
10-31-2011, 12:46 PM | #13 | |
Drives: '12 AGM ZL1 (SOLD); '07 Ducati 1098 Join Date: Oct 2011
Similar Threads | ||||
Trans almost fixed dealer out of manual trans fluid? | Dexgto | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 4 | 09-18-2011 04:54 AM |
WANTED: 2010 2LT RS Manual trans | alex5252 | Autos For Sale / Wanted | 0 | 06-01-2011 10:44 AM |
Manual on the go with your Apple devices | LED Crazy | 5th Gen Camaro SS LS LT General Discussions | 2 | 09-11-2010 11:21 PM |
WHOLE LOT OF HANDSHAKER'S!!! (manual trans.) | terryg75 | Dealer Camaros for Sale | 9 | 03-08-2010 09:28 AM |
Weird sound in diff or trans. 6sp manual | JEFF2010SSMANUAL | 5th Gen Camaro SS LS LT General Discussions | 5 | 02-10-2010 04:19 PM |
