03-13-2020, 10:09 PM | #1 |
Fel-Pro valve cover gaskets...WTF?
So I am almost done with my cam swap and noticed something strange. My valve cover gaskets, which are 6 months old and only have 1600 miles on them have grown/stretched and no longer fit. It is like they grew over an inch. There is quite literally too much gasket. No matter what I do I cannot get them to fit.
Anyone ever experience this? I hate to trash a fairly new set of gaskets, but this is just ridiculous, especially from a company as well known as Fel-Pro. I will likely replace with OEM stuff.
03-13-2020, 10:13 PM | #2 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
had same prob....get sum new ones from Advance Auto for $20...
good luck! PEACE
03-13-2020, 10:32 PM | #3 |
I just did, unfortunately I had to go with Fel-Pro again because I don't want that to hold up completion waiting for the AC Delcos. But I had $5 in Speed Perks and the 20% off coupon code. Came out to $12.77. I can handle that for that price.
I just don't understand why they stretched like that. Anyhow, thanks for the heads up man.
03-14-2020, 05:20 AM | #4 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
I had the same issue.
I couldn’t reuse them because they stretched so much. Sent from my iPhone using Tapatalk
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
03-14-2020, 07:08 AM | #5 |
I had the same issue "back in the day" and that is why I stopped using Felpro..
03-14-2020, 11:30 AM | #6 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Been that way for years, always considers Felpro valve cover gaskets a one time use item just like condoms .
OLD GUY FLYING FAST AND LOW
03-14-2020, 08:47 PM | #7 | |
I honestly never knew that (The gaskets, not the condoms lol). I can totally understand a year or two, but I have put 1600 miles on this engine (First start was Last October) and they were totally unusable. That's lame. But overall it's not a huge deal since they are rather cheap. OMG, so close to finishing my cam swap. Just need to install the fuel line, fill the radiator, reinstall my coil packs, plugs/wires and my Vararam. I had to quit for the night as my back is killing me and I don't like working in the dark on my car. Too easy to miss something stupid. Oh yeah, and install the startup tune Ryan from GPI sent. First start has my nervous as heck.
03-14-2020, 09:38 PM | #8 |
When i took my supercharger out the factory brick gasket was so oversized i couldn’t use it. It was 1” bigger all around. Had to order a new one.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
03-15-2020, 10:49 AM | #9 | |
Drives: 2010 SS L99 Join Date: Sep 2018
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
03-16-2020, 05:21 AM | #10 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
+1
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported LS3 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, 1 Walbro 450lph, 2 525lph return style fuel system, deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
