12-15-2017, 08:16 AM | #1 |
Drives: 2010 SS Join Date: Mar 2013
Radio display out
Hey guys, having an issue with my radio I'm hoping to get some help with. It still puts out sound and can be adjusted with the steering wheel controls, but the display and all the buttons are out, as well as the hvac controls. Also noticed the plug in and USB port in the center consol don't have power.
Have checked the 10a display fuse in the box under the dash, and it is fine. Swapped it out just to be sure and no change in the situation. I would dive in on pulling the display out and checking its connection, but if the display was the culprit, wouldn't the stuff in the center console still work? Or does the power for that come out of the display somehow? Any ideas? This is the typical radio for the 2010, no mylink or anything.
2010 2SS
Mods: OBX Long Tubes, Halltech CAI, Innovate LC-2 Wideband, HPTuners tune (working on it anyway), MGW Short-throw Last edited by ScarTissue48; 12-15-2017 at 08:29 AM. |
01-21-2018, 07:08 PM | #2 |
So I found someone close with a spare faceplate to plug in, and it did not light up/get any power either. Fuses are fine and the faceplate is fine. Whats the deal? Bad bcm? Was very close to replacing my pcm because of a short I couldn't find under the hood, but it randomly went away and the car has been running fine. The faceplate is not getting power for some reason.
2010 2SS
Mods: OBX Long Tubes, Halltech CAI, Innovate LC-2 Wideband, HPTuners tune (working on it anyway), MGW Short-throw |
01-21-2018, 10:12 PM | #3 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
mine was the Radio, it was told to me that some models had bad soldier joints. I replace it and everything works
Hot Wheels Emblems and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills, Hot Wheels door Sills.
01-21-2018, 11:30 PM | #4 |
Was your issue the same as what I described there?
2010 2SS
01-22-2018, 01:18 AM | #5 |
Drives: 2014 Camaro LS / 13 zl1 Join Date: May 2016
I had the same problem with my 14 LS. No display at all. Ended up buying another factory radio on here and problem solved.
01-22-2018, 09:20 AM | #6 |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Try adding power to the screen/AC wires and see if that works, sounds like a wire may have gone bad.
Its pin 10 that is the power. |
01-25-2018, 01:35 PM | #7 |
Drives: 2014 2LT/RS Ashen Gray Metallic Join Date: Nov 2011
There is also a fuse block in the rear hatch, on the passenger side, behind the carpet. Not that easy to get to. There is a radio fuse in this block that may be blown.
04-20-2024, 06:48 PM | #8 |
Drives: 2013 Camaro 2LS Join Date: Mar 2022
Any update on this thread? My 2013 LS has a standard radio and climate control display. It started to go crazy: switched from Sirius to FM, switched back and forth a few times, display went blank then would come back with the standard display of time/date/ temp, then would display climate control, the radio would go on even after I shut it off, the display went back to default time and date (1/1/2010), and every minute or so would go blank, then display climate control, the time/date/temp, radio on and off. The blinker sound would stop working periodically also. I had to drive home continually turning off the radio and turning the volume down to stop the popping and cracking in the speakers. Does anyone know what’s going on before I have to call the dealer? Although reading the info in the thread, I’ll look at the radio fuse first and try to reset.
05-10-2024, 01:35 PM | #9 |
The fan speed and blinker sound and climate control indicator lights would go in and out in addition to the radio and screen. I checked all the fuses with no success in fixing the problem. I took it to the dealer and they think the alternator is spiking and everything works when they disconnect the alternator. They’re going to replace it. More to come hopefully.
05-16-2024, 06:46 PM | #10 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
Interesting.... Post an update when you can.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
05-17-2024, 12:11 PM | #11 |
Dealer stated the alternator swap didn’t resolve the problem. Fortunately they returned the part and are going back to the drawing board. They are working with GM tech support that recommended the alternator swap. At this point I’m into $250 in diagnostics cost. The cost would have been $1,100 for the alternator swap. They called me again and are now saying it is a radio module or something like that (I’m waiting for a response with the exact part name.) They state that’s what the next level GM tech support is saying now. $1,000 cost, and like last time can’t guarantee it will fix it. This time though they said they can’t return the part, so I’d be on the hook even if it didn’t fix it. And I’m up to $350 to walk away with diagnostic cost. I called GM again about this even though they have refused any cost sharing so far. This time stating that this is a dealer service issue now. I also called the dealer GM. I’m waiting for a call back from both. Dealer not guaranteeing their work and charging for diagnostics when they can’t say they diagnosed the problem is a problem.
05-18-2024, 09:49 AM | #12 |
I’m told by the dealer the radio control head needs to be replaced. I didn’t give them the go ahead yet. I’ve been seeing replacement radios like from PAC that some owners say are a better unit. I actually didn’t know you could buy these replacements. Not sure if they’re plug and play as it seems. Any thoughts?
05-19-2024, 05:31 AM | #13 |
Drives: '11 2SS, '11 C6 GS, '04 MDX Join Date: Feb 2012
I put the PAC unit in a little over a year ago. There are two main replacements; the PAC and the Metra. I personally like the looks of the PAC so I went that route. I also added a rear camera.
As you know, you have vehicle controls via the OEM headhunt. The PAC doesn't allow you to make modifications where the Metra will. So if you go PAC, make sure you have the options set you way want to keep them. As far as 'plug and play', you will have some connections you'll need to make from the new head unit. I personally recommend Crutchfield as their prices are decent and their customer support is par to none. You can even purchase the service for them to make the connections for you for making it true plug and play. However I found they use crimps so I ended up taking them apart soldering - though it make it tons easier. All that said - if you want to keep the OEM, there are plenty of used display's and radio on eBay. I'm not sure if it's the display that's going out on you or the radio - but both are on there & a lot cheaper than $1k. I see there is even a new display on there now for $250. |
