Old 10-12-2014, 08:06 PM   #1
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
Small dash insert, picture of underneath
Does anyone have a picture of the actual dashboard underneath the small dash insert to the left of the steering wheel? I know it has holes for the clips to go in, does it have any other holes back there?? Looking to run wire through. Thanks in advance.
I would love to go out and look myself but my 5 month old is stopping me from doing so lol
45thCamaro is offline   Reply With Quote
Old 10-12-2014, 08:23 PM   #2
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Nope, but you can drill one.
GVA 45TH 2SS is offline   Reply With Quote
Old 10-12-2014, 08:56 PM   #3
45thCamaro
45thCamaro's Avatar
Thanks for the pic and info. I figured as much. I might one clip off the dash insert and use an existing hole
Edit: nevermind can't do that I didn't realize that there was only 2 clips on that piece. Would have to be drilled. However maybe you can tell me, that abl tube, did you have to drill that hole? Or is the hole already there??
Old 10-13-2014, 06:49 AM   #4
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
There should be other holes if you have a '10-12.
He had to drill that hole.
sjmautoprod is offline   Reply With Quote
Old 10-13-2014, 11:32 AM   #5
45thCamaro
45thCamaro's Avatar
Thank you. I have to take a look to see what I have to work with. I would like to avoid drilling any holes if possible.
Old 10-13-2014, 11:38 AM   #6
sjmautoprod
Drives: '16 2SS
Yup. It's possible that the extra holes were removed sometime in '12, like some other changes.
Old 10-13-2014, 12:32 PM   #7
45thCamaro
45thCamaro's Avatar
I have to check that when I get a chance. I will report back. Thank you sjmautoprod
Old 10-13-2014, 01:51 PM   #8
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
In the 2010-11 there are more holes there, we ran extra LED's so there is more lights.
2SSRS@Gen5diy is offline   Reply With Quote
Old 10-13-2014, 05:53 PM   #9
45thCamaro
45thCamaro's Avatar
Thank you. Unfortunately my car does not have the extra holes. Furthermore, my idea for running a wire back there will not work for what I wanted to do with it. I was planning on mounting the new throttle controller in that area. I was going to recess the remote into that dash insert and run the wire behind it. However do to the lack of space and bad viewing angle that it would be I decided to look for another location.
Old 10-13-2014, 08:33 PM   #10
GVA 45TH 2SS
KNGTFALL
I figured yours would be similar to mine since we both have 45ths.
Mine was built Feb 2012 so in the 2nd half of the Model year run.
Old 10-13-2014, 09:11 PM   #11
45thCamaro
45thCamaro's Avatar
Yeah. Mine was built in December of 11. I have to see if I like where I put this remote. Or I will have to move it again.
Old 01-10-2015, 11:19 AM   #12
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Where did you end up putting your throttle controller?
The Bird is the word!
Old 04-15-2015, 12:04 PM   #13
chris7488
chris7488's Avatar
Drives: 2011 camaro ss
the center piece oem
so the center oem piece doesnt come with a abl led
chris7488 is offline   Reply With Quote
Old 04-15-2015, 12:09 PM   #14
sjmautoprod
Drives: '16 2SS
They are not stock.
