10-01-2020, 06:51 AM | #1 |
Drives: 2019 Camaro 2SS Join Date: Nov 2019
Track issue, need advice if there is any?
So yesterday I tracked my car for the 6th time. Came off the first session and went to check my tire pressure and my left rear I noticed the valve stem was leaking air. It appeared to be coming from the base of the stem. I could wiggle it a little to get it to stop, but as soon as I let it go, it started to leak again. Have the original run flats on the car so I was able to limp it home. PSI was 16 when I got home, 38 when i came off the the track. Has anyone cut a valve stem, and any solutions, or just bad luck?
2019 Camaro 2SS, Shadow Grey
10-01-2020, 07:56 AM | #2 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Do your TPMS sensors bolt into the rim or snap in? If they bolt in there should be a nut on the outside below the valve stem. That nut gets tightened to 80 in-lb (9 N-m) so can check to see if it's loose at all. If you've got the snap-in style ones (i.e. rubber base instead of metal), you'll likely need to take it to a tire shop to either get it re-seated or replaced if it's damaged.
I'd also be leery of that tire if it was driven at pressure that low on a runflat. They're designed to only drive 50 miles or so at low/no pressure, and any driving at low pressure will start to damage the internal sidewall construction which could be cause a tire failure sooner than expected, especially if you track the car. Might want to consider keeping the dealer in the loop because if the valve-stem just came unseated or was defective you might get it and a new tire covered under warranty.
2017 SS 1LE.
10-01-2020, 09:34 AM | #3 |
Drives: 2013 C6Z06 Join Date: Nov 2016
Not sure if your valve stem was rubber or not, but I won't track rubber valve stems anymore. I either melted one from brake heat or something just cut it during a session, but coming back in the pits and hearing it leaking was all i needed to switch to metal valve stems only.
10-01-2020, 10:11 AM | #4 | |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
10-01-2020, 10:35 AM | #5 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Glad you made it home! Unfortunate you were unable to return though... Was nice meeting you, and your parking lot neighbor in the ZLE. Curious on what you find with the stem/tpms nuts. Hope you do get them (TPMS/Tire) covered as "Alpha1BC" suggests.
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
10-01-2020, 10:59 AM | #6 |
Drives: 2020 Camaro ZL-1 1LE Join Date: Jul 2018
Metal valve stems
+1
Home Track: NCM Motorsports Park
10-01-2020, 12:01 PM | #7 |
Yeah, nice meeting you. You were hauling the mail for sure. I was like F, I got some work to do. HEHE!!!
10-01-2020, 12:02 PM | #8 |
Do metal valve stems come on TPMS, or you run without TPMS? These are backup rims, so I don't really care.
10-01-2020, 01:11 PM | #9 | |
I would think your OEM wheels came with metal stems/tpms (one unit). AFAIK the actual valves in the stem (rubber or metal) are the same regardless. That could of loosened too, not just the outer nut. I have TPMS on all my wheel set-ups. One set has a bad TPMS not reading on a rear wheel, so the set wont complete the re-programing process. Not the end of the world without dash readings, if you are disciplined at tire temps and manual pressure readings.
10-01-2020, 02:53 PM | #10 | |
10-01-2020, 04:38 PM | #11 | |
10-01-2020, 07:01 PM | #12 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
1+ on Provoste's recommendation, albeit i have not upgraded mine in 4 seasons. Maybe i should...
One thing that can lead to valve failure/slow leak is running without caps. Seen this cause several issues if/when crap gets inside. So, i always ensure i have mine on all the time. Cheers! |
10-03-2020, 07:18 AM | #13 |
Checked it out. OEM stems are metal.
