dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 12-17-2014, 07:58 PM   #1
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
1.85 SLP rockers?
Was thinking about doing the SLP 1.85 rockers with my stock cam, BTR valve springs and pushrods, and bigger lower pulley. Instead of going into the engine and adding a cam. Then just add a 150-200hp shot of nitrous for 1/2 mile and mile racing. What say you all?
http://www.slponline.com/product/501...m-Package.html
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance.
2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14)
jon6.0 is offline   Reply With Quote
Old 12-17-2014, 08:31 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
I thought about just the 1.85 rockers and springs too...the rockers are expensive and a cam swap would yield much more power. Not a bad idea but the cost is high for maybe 20 hp.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 12-17-2014, 09:04 PM   #3
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
When you factor in the amount of labor saved by not changing out the cam it's actually pretty cheap in my opinion. I also figure the rockers would be worth a bit more than what they advertise since this is a boosted application and not NA. Sounds like I'm trying to talk myself into it, lol.
Old 12-17-2014, 09:21 PM   #4
Snidely Whiplash
Fight Crime, Drive Armed
Snidely Whiplash's Avatar
Drives: '14 2SS Yelo Maro, HD collection
Anthony at LG Motorsports - I very much trust his advice - said adding the rockers means having to install new springs and spend time checking the pressure of the springs. On a dollar per HP basis - it's a bad investment.
For that kind of cash outlay - forget the pulley and install a cam. Another option would be a good head porting with the pulley.
Personally, I would do the cam, heads, AND pulley. If ya pull the motor apart...just do it once and get it over with.
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
Snidely Whiplash is offline   Reply With Quote
Old 12-17-2014, 10:36 PM   #5
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
I was already planning on new springs just to raise the rev limit. Based on the stock LSA cam specs of 198/216 .480/.480 122.5lsa using the 1.85 rockers would yield 198/216 .522/.522 122.5 lsa. That shouldn't fatigue good springs. The other point is I don't want to pull the motor apart. A little extra lift, more boost with pulleys, and some nitrous would be a lot easier on my wallet. I only really want the nitrous for doing 1/2 mile and mile racing. I don't need it to be 700rwhp all the time. Been there, done that with my C6. It's useless power on the street unless I run drag radials all the time. 600-650rwhp is the sweet spot for a good set of sticky summer tires. From my experience anyway.
Old 12-17-2014, 10:45 PM   #6
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
So the crate LSA says it has a 198/216 .492/.480 cam in it with a 6600rpm redline. Is that a different cam that what our ZL1's come with? The cam part number is 12623064 and on GM Parts Direct it says stock LSA cam.
http://www.chevrolet.com/performance...gines/lsa.html
If it is the correct specs that would make the cam 198/216 .535/.522 122.5lsa with the 1.85 rockers.
Old 12-18-2014, 10:38 AM   #7
Stephen12ZL1
Drives: '21 ZLE A10
I have always heard lift on the LSA was .480/.480 at least in 2012. Maybe they upped the lift for later model years or just for the GMP crate motors. I still think it is expensive and labor intensive for 12hp(SLP website info). I am all about the bolt ons...but if I have to swap springs and pushrods, I am going to swap the cam too for 70rwhp(approx).
Old 12-18-2014, 10:56 AM   #8
Boother
Drives: 14 ZL1
Don't forget the duration numbers are measured at .050" lift, so with the increased rocker ratio, you will hit that number faster and result in longer measured duration than the 198/216.
Boother is offline   Reply With Quote
