Old 05-18-2018, 06:09 PM   #1
activepat
activepat's Avatar
Drives: Red Hot SS 1LE
And the car just stopped.....
Took it out for an errand, pulled in the garage and turned it off. Went to restart immediately to pull in further and ‘dead’. Full power and 12+ volts on voltmeter. Nothing but a single click. Everything lights up and never dims.
Anyone else? 2500 miles, October delivery, May 2017 production date. Can’t be the battery.
Hate to tow it in......
activepat is offline   Reply With Quote
Old 05-18-2018, 06:12 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
make sure you didn't leave it in gear and confirm the brake pedal is depressed. A10 or M6?
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 05-18-2018, 06:18 PM   #3
activepat
activepat's Avatar
A10. We messed with it for an hour. Jumper, box, etc. “click”.....
Old 05-18-2018, 06:24 PM   #4
nighttowl
Sarcasm loading --------
nighttowl's Avatar
Drives: 2018 ZL1 1LE
at least it broke down at your house and not on the freeway.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock
2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD
nighttowl is online now   Reply With Quote
Old 05-18-2018, 06:36 PM   #5
activepat
activepat's Avatar
Yep! Glass half full.
Old 05-18-2018, 06:40 PM   #6
Boo
Drives: 2017 ZL1 A10 Nightfall Grey
I would call onstar if you have it amd get diagnostic! Also you try turning the steering while starting? May be a saftey feature
Boo is offline   Reply With Quote
Old 05-18-2018, 08:59 PM   #7
DangerZL1
Drives: 2023 Black ZL1 Auto
That bites. Sounds like a flat bed ride is in your future. Hopefully it’s something simple.
DangerZL1 is offline   Reply With Quote
Old 05-19-2018, 06:35 AM   #8
activepat
activepat's Avatar
Not sure what to make of this.
Old 05-19-2018, 07:01 AM   #9
kwav8r
Flyin NOE
Drives: 2018 ZL1 (A10)
Poor ground issue or the ecm crapped itself
kwav8r is offline   Reply With Quote
Old 05-19-2018, 07:48 AM   #10
full*throttle*therapy
Drives: '18 RH ZL1 1LE
There is a TSB for electrical gremlins. Something rubbing on metal wearing through the jacket.
full*throttle*therapy is offline   Reply With Quote
Old 05-19-2018, 07:57 AM   #11
TDS
TDS's Avatar
Drives: 2019 Jeep Rubicon Sold:2017 ZL1 A10
Have you had the recall done. Here is a link.https://www.camaro6.com/forums/showt...ghlight=recall
May not be the problem but you never know.
I would start with pulling the negative on the battery, wait a half hour and try and start, If not it is a flat bed ride
Travis
SOLD ZL1 Summit White, A10, Black Strip, PDR, ZL1 floor mats
Ordered 2/11, 2000 2/14, 3000 2/20, 3100 2/24, 3300 3/7, 3400 3/8, 4300 3/16, 4B00 3/21 Bayed at train yard in Ohio, 4200 3/26 All Abroad for the West Coast, 4800 4/4 Deliverd to portland train yard, 5000 4/7 3:00AM Deliverd to Dealer, 6000 4/7 6:45PM Delivered to Customer
TDS is offline   Reply With Quote
Old 05-19-2018, 07:59 AM   #12
1roadking
Drives: 2017 ZL1 silver A10
Did you make sure the battery cables are tight? If they are loose, you could still get power but not enough to start it. If your jumping off the under hood jump points but the cables are loose at the battery it would still not start.
1roadking is offline   Reply With Quote
Old 05-19-2018, 08:45 AM   #13
activepat
activepat's Avatar
Cables are all tight. Recall notice looks interesting! I would go get a battery just in case but this is a gelcell and costs $200 which may not be the issue.
Old 05-19-2018, 08:51 AM   #14
pcguy2u
pcguy2u's Avatar
Drives: 2009 Corvette ZR1
In for the fix...
pcguy2u is offline   Reply With Quote
