AWE Tuning
Old 10-08-2016, 08:55 AM   #1
wizprocreative
WIZPRO
Drives: 2016 Camaro 2SS
Groan from Gen6 rear end when cold
Each morning when I crank up my Gen6 2SS, I back out of the driveway then once I turn the wheels and step on the gas to pull off. Then a very noticeable "groan" comes from the rear of the car! The sound happens each time I make a turn until the car warms up - then sound goes away.
I want to take it in for service to check it out but once I get to the deanship, it'll be warm and the sound won't be there for them to hear.
I have read elsewhere that others have had this same problem. Some have said it is the LSD. Has anyone here had this checked out? If so, what is it and is it something that I should be concerned about?
2016 2SS Mosaic Black w/Sliver Stripes, Adrenaline Red interior, All options but duel mode exhaust.
wizprocreative is offline   Reply With Quote
Old 10-08-2016, 09:21 AM   #2
Burly
Burly's Avatar
I did take to dealership for this reason this week. I left it overnight too. They couldn't reproduce it so they won't do anything. I'm going replace diff fluid myself this week to see if it helps.
Burly is offline   Reply With Quote
Old 10-08-2016, 11:31 AM   #3
CME73
CME73's Avatar
Drives: 2017 Camaro 2SS
You are definitely not the first (http://www.camaro6.com/forums/showthread.php?t=440272)
I had mine in twice for this reason, first the changed the diff oil, the second time (still in service) they are replacing the carrier. Hopefully the groaning will go away now. like you said, is only when its cold.
CME73 is offline   Reply With Quote
Old 10-08-2016, 11:40 AM   #4
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
Well, I don't get that sound. But car does not move till it's warmed up, 5.min
My car is picky and sure it's with other camaro's as well. It just does not like a start and go.
LT4 1.7 Supercharger snout ported & Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 10-11-2016, 08:21 PM   #5
rosatelg
rosatelg's Avatar
Drives: 2016 Chevrolet Camaro 2SS Black
Have the same issue. I brought it to my dealer and they could not reproduce it as expected. They offered a loaner if I left it overnight. They won't act on anything that they cannot reproduce.
Will update when I leave it overnight.
2016 Camaro 2SS Black \ Black, A8, 6 Piston Brembo Brake kit, Front Splitter, 56H Wheels, 35% Tint
Delivered on: 9/8/16
rosatelg is offline   Reply With Quote
Old 10-11-2016, 10:32 PM   #6
c4racer
Drives: 2016 SS Convertible
Try adding a little GM lsd additive - maybe factory fill didn't have enuf. Should not cause an issue however.
c4racer is offline   Reply With Quote
Old 10-11-2016, 10:56 PM   #7
SPARTAN sui
PC Technician
SPARTAN sui's Avatar
Drives: 2016 Hyper Blue 2SS
I'm curious too. It has been about 35 degrees now and I notice it at low speed turning.
SPARTAN sui is offline   Reply With Quote
Old 10-11-2016, 10:57 PM   #8
quikag
Drives: 2SS '16 Camaro
Mine does the same thing. I think it's a bad diff. Haven't taken it to the dealer yet.
'16 2SS White/Adrenaline Red Coupe Mag ride, 8-speed, Sunroof, Dual-Mode Exhaust, Black wheels
Also:
2010 ZR1
2018 GT3
2013 LX570
quikag is offline   Reply With Quote
Old 10-12-2016, 06:58 AM   #9
STEVE41
Drives: 2016 SS
dealer change out the deff fluids, it still does it, just not as loud. we will see how long this last before getting really loud again.
STEVE41 is offline   Reply With Quote
Old 10-12-2016, 07:14 AM   #10
Jmcalhoun22
Jmcalhoun22's Avatar
Drives: 2019 Camaro ZL1
I have the same issue
2019 Camaro ZL1 - A10
2016 Camaro 2SS - A8 - NPP - SOLD
2019 Audi Q5 - Premium Plus
2007 Tundra Limited - TRD Supercharged
Jmcalhoun22 is offline   Reply With Quote
Old 10-12-2016, 07:51 AM   #11
bdavies11
I noticed this too for the first time last week. It just started to cool off here in the mornings. Also heard it again today as I left for work. It was about 50* out.
bdavies11 is offline   Reply With Quote
Old 10-12-2016, 07:56 AM   #12
Turtle 2ss
TBC
Turtle 2ss's Avatar
Drives: 2017 Fifty 2ss
Best thing to do and i did it a few times. If you have a GoPro. Mount it to something under the back of the car that don't move to much and record it. Might need to do it a few time in different place so you can see were the sound is coming from.
2017 Fifty A8, MRC, NPP, NAV, LUM, BLK BOWTIE
Turtle 2ss is offline   Reply With Quote
Old 10-12-2016, 09:02 AM   #13
Corner carver
Corner carver's Avatar
Drives: 2017 Camaro 2.0T RS
Also have the same problem, seems to go away after the transmission/rear end temp gets up to about 30C... Still have the stock fluid in the diff after 5000km, I have some new fluid to try just haven't gotten around to replacing it yet. (LTG rear end with LSD)
Corner carver is offline   Reply With Quote
Old 10-12-2016, 09:08 AM   #14
77Z28
77Z28's Avatar
Drives: 2016 2SS A8, NPP, Mag ride
I am taking mine in Monday to leave it overnight so they can check it out.
77Z28 is offline   Reply With Quote
rear end groan, strange noises
