Old 05-05-2013, 09:11 AM   #1
Threlkeld's SS
Threlkeld's SS's Avatar
Drives: 2010 camaro ss
Torque spec for header bolts?
Getting ready to do a header install and I need to know the the torque specs. Thanks
Threlkeld's SS is offline   Reply With Quote
Old 05-05-2013, 09:14 AM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
I posted all the LS3 torque specs in the Big DIY Index. It's a sticky in the DIY subforum.
On that note, I believe it's 18 lbs/ft though.
Click to view my build thread
Old 05-05-2013, 09:19 AM   #3
SPCBA
Drives: pleather and Chiclets
remember to retorque after a few heat cycles...the cats or off road pipes too
SPCBA is offline   Reply With Quote
Old 05-14-2013, 01:31 AM   #4
BAWLZ SS
BAWLZ SS's Avatar
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova
I doing my Kooks header install tomorrow and instructions say to torque bolts to 25-30lbs inst thatt too much. I dont want to strip the threads on the head. It also states to use a little bit of hi temp silicone on the gasket on both sides!? Is this correct? Sorry 1st time installing headers,on a car. Just want to make sure i do it right! Also do i use any lock tite on the bolts?
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
BAWLZ SS is offline   Reply With Quote
Old 05-14-2013, 06:12 AM   #5
The Stig
The Stig's Avatar
Pretty sure it's 18 but
Old 05-14-2013, 08:08 AM   #6
RJT-SS
RJT-SS's Avatar
Drives: '11 2SS/RS A6
I just finished installing my Kooks last night. I re-used the factory bolts and torqued them to between 18 - 20 ft lbs. No leaks so far. Will re-check after a few heat cycles.
Do not use loctite; you will never get them off if you have to. Use some anti-seize.
Performance Mods:
Kooks 1-7/8 LTs; Calico coated w/HFCs, Solo Mach XL catback w/J-pipes, VMax TB, C.A.I. Intake, JRE Tune, RX Catch-Can
RJT-SS is offline   Reply With Quote
Old 05-14-2013, 08:29 AM   #7
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
ARH told me 18 ft./lbs. on the header bolts, and just "good-n-tight" on the O2 Sensors. That being said, I torqued the bolts down to about 22 ft./lbs. to account for prevailing torque, and I used anti-seize on the bolts too. And yes, need to re-check them in about 500 miles.
blazzin1 is offline   Reply With Quote
Old 05-14-2013, 08:45 AM   #8
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Use oem gaskets. Do not use loctite. Anti seize if fine on header bolts but that's up to you. However, you should use it on 02 sensors or pay the price later. 18ft lbs on the bolts then recheck after some cycles.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 05-14-2013, 08:57 AM   #9
DEANGE2001
DEANGE2001's Avatar
Drives: 2010 2ss LSR CAI, Borla S axle back
I installed my kooks LTS about 2 weeks ago did about 25 ft-lbs...my buddy I did the install with is a mechanic and said 25 is fine and should not need retightening but I may still check them and the cats
2010 2SS (Red w/ White Stripes) LSR CAI, Kooks 1 7/8 LTs with Cats, Borla S-type Axle-back Exhaust and Tune
"cmon, the engine has all forged internals...its just begging to be blown"
DEANGE2001 is offline   Reply With Quote
Old 05-14-2013, 09:12 AM   #10
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
None of mine loosened up after 500+miles but there are PLENTY reports of that happening. Definitely enough to go back and check. It only takes a 15min or so to check them all.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 05-14-2013, 09:40 AM   #11
LeanPocket
Drives: 2010 2SS
german nice and tight.. 120,000 miles no issues..
LeanPocket is offline   Reply With Quote
Old 05-14-2013, 09:50 AM   #12
Alvin@PCMofNC
Drives: 2010 IOM RSS
Kooks calls for 25-30 ft lbs. The manual calls for 18 if I remember right. We do not use the KOOKs gaskets. The stock gaskets seem to work better.
Alvin@PCMofNC is offline   Reply With Quote
Old 05-14-2013, 10:33 AM   #13
BAWLZ SS
BAWLZ SS's Avatar
Yeah im using my stock gaskets too as my tuner recommended. again Kooks calls for 25-30 lbs so I will be doing 25 lbs and see how that goes. The stock bolts had some yellow stuff on them when I was taking them off last night that's why I asked if I should use locktite but I will just stick to anti seize. Thanks everyone!! Cant wait to see how it will sound after!
Old 05-14-2013, 12:10 PM   #14
The Blue Ox
The Blue Ox's Avatar
Drives: 2010 SS L99 Inferno Orange
Be sure and get your inch pounds and foot pounds squared away! Big difference! 12 inch pounds equals 1 foot pound!
Should be kooks 25-30 ft lbs!!!
The Blue Ox is offline   Reply With Quote
