Old 09-05-2017, 12:08 PM   #1
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Serious track guys: Are you running equal compound brake pads or split?
Gents,
What are you guys running for brake pad compounds? I'm not looking for info on your specific brake pads, I'm just trying to figure out if you guys are running an equal F/R compound, or a split F/R compound. As far as I can tell, the stock Ferrado's are equal F/R. I used an XP12/8 for 3 events and the fronts got demolished and didn't last, rears look new. This is leading me to believe a compound split of that magnitude isn't warranted, and I would be better off either using an equal pad, or a rear pad that is 1 step under, not 2, from the front. FYI, I use G-Loc pads (same as Carbotech).
seanblurr is offline   Reply With Quote
Old 09-05-2017, 12:14 PM   #2
slick3
Drives: Garnet Red - 20 ZLE
Thats what G-Loc recommended me as well and thats what I am running. Only have one event on them so far but they fronts still look good.
slick3 is offline   Reply With Quote
Old 09-05-2017, 12:58 PM   #3
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
Originally Posted by seanblurr View Post
Gents,
I'm running the same compound front/rear (DTC 60's). Fronts wear 2-1 faster than rears, but the rears do wear. This 2-1 wear is about what I always have gotten on track with various Porsches.
Provoste is offline   Reply With Quote
Old 09-05-2017, 01:05 PM   #4
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
I went big, like 16" front rotors and 8 piston calipers with Rotora's H8 track compound front and rear. Rear brakes are 14.5 rotors with 4 piston calipers.
Several track days on the Roval at Auto Club Speedway with no fade or wear issues. Usually top 5 on the speed charts overall.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
Old 09-05-2017, 01:13 PM   #5
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Since we have electronic brake proportioning valves, staggered setup shouldn't be necessary or would hurt anything. I always used ST43s as equal compound front an rear but wanted to try the ST47/ST45 (since it's pretty common and ST47s would be possibly overkill for the rears).
Also, I feel I can always use more brakes up front since this is the heaviest track car I ever owned/operated.
glamcem is offline   Reply With Quote
Old 09-05-2017, 02:00 PM   #6
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
No need to have split mu's. Like Cem said, EBD, plus the EBD is tuned for same mu pads front/back with stock compounds. If you put a wimpy pad on the back, the EBD quite possibly won't have the trim authority to get the rears to work enough. That certainly explains Sean's observations with rear pad wear. My Alcon caliper temp stickers are lightly at 450°F front and solidly at 370°F rear. The rears are definitely working.
G-Loc has this ridiculous habit of recommending crazy split mu's with no good rationale, certainly not logical. On cars with no EBD, or any prop valve at all, then you tune proportioning with mu. On our cars it's simply not relevant.
Ryephile is offline   Reply With Quote
Old 09-05-2017, 03:45 PM   #7
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Ok, sound's like I may go ahead with an R16 (equal to carbotechs XP16) on all four corners then.
Old 09-05-2017, 04:37 PM   #8
slick3
Great info. Thanks for the explanation.
