Vararam
Old 06-14-2010, 06:39 AM   #1
timdh5
Drives: 2SS
98 Octane
Living in Dubai, I'm lucky enough to be able to feed my Camaro with 98 Octane
I just received a Predator Tuner today. but the max fuel option is 93? Shall I just use that one?
timdh5 is offline   Reply With Quote
Old 06-14-2010, 07:35 AM   #2
DSteck
Drives: 2006 Corvette Z06
Just because the gas has a high octane count doesn't mean you'll neccessarily make more power. While the octane ceiling doesn't hurt, I still wouldn't run tons and tons of timing.
Is that 98 rating RON or MON? Or is it (R+M)/2?
DSteck is offline   Reply With Quote
Old 06-14-2010, 08:54 AM   #3
06MonteSS
Drives: 2006 Monte Carlo SS
yeah, due to the different rating system used over there, your 98 octane rating over there is equivalent to our 93 octane over here in the U.S...
06MonteSS is offline   Reply With Quote
Old 06-28-2010, 11:42 AM   #4
phenixdragon
Drives: 2010 Camaro SS
If that is true about the rating system then it's okay but generally speaking, the higher octane beans you have a slower burn which means you have less amount of combustion per minute which means you may have an overall less in power. It doesn't hurt the motor,but it may give you less over all power.
phenixdragon is offline   Reply With Quote
Old 06-28-2010, 11:53 AM   #5
GQ4Life
Drives: 2010 Camaro SS LS3
most those countries all use RON
98 oct RON = 94 oct (R+M)/2 [us oct rating system]
so there is no difference.. just use the 93oct
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Octane Ratings? Icefsh Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 12 03-10-2015 05:10 AM
How much octane boost can you put in your tank? OHIOSS 5th Gen Camaro SS LS LT General Discussions 11 05-21-2010 08:41 AM
How to get 93 octane? BlownSS 5th Gen Camaro SS LS LT General Discussions 3 03-23-2010 12:11 PM
Anyone running something other than 87? jeansonne627 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 31 10-01-2009 02:40 PM
No 93 Octane in California tribone Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 15 08-27-2009 04:18 PM
