dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 07-20-2021, 10:27 PM   #1
Mojave13
Mojave13's Avatar
Drives: 04 Colorado, 22 Camaro SS 1LE
California Testing for ECU Tunes During Smog Checks
Details are scarce, but this has potential to be a dozy for those of us tuned. How this state implements this new law at your local SMOG shop and its effect is going to interesting. Costly for some.
I’ve run my set-up through two (2) DMV registrations that required SMOG check. So four years or there abouts; no flags with these mod's. I’m due for SMOG in December it’ll be sad event should Camaro not pass due to new law
May the force be with anyone who’s tuned California Will Start Testing for ECU Tunes During Smog Checks Starting Next Week
2022 6.2L V8 A10 2SS 1LE Shadow Grey Metallic
RotoFab CAI, Borla S-Type 11924CFBA, Sullivan Race Pedals, ACS Rock Chip Guards
Sold 2010 6.2L V8 6M SS/RS Cyber Grey Metallic
1LE Track Pack, DiabloSport Jammer CAI, Stage1 CAM, Ported & Polished Heads, HD LS3 Timing Chain, Melling High Volume Oil Pump, LS7 Lifters, BTR Trunnion Upgrade, LS3 Springs & Pushrods, JBA Shorty Silver ceramic Headers, Granatelli high temp blue wires w/ Fire sleeves, Borla S-type CAT back, MGW black Flat short throw shifter, Custom Calibration/tune
Mojave13 is offline   Reply With Quote
Old 07-21-2021, 03:18 AM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I hear yah. Like I said in another post I think that California has gone too far. I don't know how you live there.
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is online now   Reply With Quote
Old 07-21-2021, 11:38 AM   #3
DRC69
DRC69's Avatar
Drives: 2011 RS 2LT
Hi All,
I saw that about the ECU tunes. Not a big deal, just will have to "re-flash" back.
But I will be careful about what I buy and install.
Must have an EO #.
DRC69 is offline   Reply With Quote
Old 07-21-2021, 12:22 PM   #4
redrum_maro
Runs on caffeine
redrum_maro's Avatar
Drives: 2010 Camaro SS
Originally Posted by DRC69 View Post
Hi All,
Must have an EO #.
Its a little more than that as they are testing for CVN/checksum, some tuning software may not reset this and will not match the stock value
redrum_maro is offline   Reply With Quote
Old 07-22-2021, 10:26 AM   #5
DRC69
DRC69's Avatar
Drives: 2011 RS 2LT
Thumbs up
I didn't know that. I guess I will have to wait and see.
Thanks for the info.
Old 07-23-2021, 12:08 AM   #6
shu92870
shu92870's Avatar
Drives: 2014 Camaro SS 1LE
May be time to get a cheap hi mileage 2010 v6 on cheap.
Use that one as registration and keep my track happy 1LE.
Do cops really check a VIN if it’s the same car and color?
If so it would be a bad day.
shu92870 is offline   Reply With Quote
Old 07-30-2021, 06:38 PM   #7
caper
Drives: 2010 IOM 2ss/RS
ok, but my carb legal system, came with a canned tune...so would it pass? - what if it was retuned since then...would it still pass?
Turbonetics running 8lbs boost at 700rwhp tuned by Hi Rev, installed by K&M w/cat-muffler delete, ACS splitter, Fesler GFX, MPD1 spoiler, Custom painted Rally stripes, Cordon CR1 wheels 275/315s, Hotchkiss comp sways and end links, Barton shifter
caper is offline   Reply With Quote
Old 10-23-2021, 11:19 AM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I just went through this myself..... first test failed due to tune.
You'll need to reflash ECU back to stock tune and depending on your mods reinstall OEM parts. Stock Air Box, Injectors, Exhaust manifolds and cats are the min.
Also after the reflash you'll need to complete the GM drive cycle in order to reset all the DTC codes and sensors. 100 mile drive might do it but you can complete it in 15-25mins if you follow the procedure.
Glad I saved all my stock parts.
Mods:
Old 08-14-2022, 01:32 AM   #9
smwalker
Drives: Caprice PPV
Anything to report Mojave? Get through OK? have to change anything?
smwalker is offline   Reply With Quote
Old 08-14-2022, 01:34 AM   #10
smwalker
Drives: Caprice PPV
If it is part of a CARB legal kit chances are they have that profile in the database. But if you changed it from what the Aftermarket company gave you that would change the CVN and be a fail. Would have to revert back to the original Aftermarket authorized file or the factory GM file.
Old 08-14-2022, 04:54 AM   #11
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
Buy a second PCM and leave it stock for testing.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28)
2009 Pontiac G8 3.6L the DD
Old 08-15-2022, 02:07 PM   #12
PoppaHoss
PoppaHoss's Avatar
Drives: 2010 Camaro SS 6 Speed
Born and Raised Getting out as soon as I am able ..... trust me!!!! F@ck Ca!!!
2004 GMC Sierra Crew Cab 4x4 SLE
8.1 Full Raylar build
2010 Camaro SS 3 Pedal
2002 Honda BlackBird
PoppaHoss is offline   Reply With Quote
Old 08-15-2022, 02:18 PM   #13
morepowerjoe
Good for you. Just don't come to Texas. Just kidding your welcome here.
Old 09-11-2022, 10:43 AM   #14
Mojave13
Mojave13's Avatar
Hey smwalker, hope you found solution to issue.
My mod situation was bleak and discovered no two ways around OBDII. I visited with two performance shops to include original engine builder. Went to multiple local corner SMOG shops. The engine builder lost their contact at DMV that could check-a-box for $500. Every local SMOG shop telling me they unable to not maneuver around plugging into OBDII
So it boiled down to 1) Supercharge using its CARB approved tune 2) Revert to stock.
Each workaround was expensive to implement on eleven year old vehicle. So I went with more expensive option 6th Gen 1LE and reason not update thread. Zero plans to move out of the Golden state so will not mod anything that isn't approved (e.g. turbo/supercharge) or easily revertible
