08-21-2020, 08:44 PM | #1 |
Drives: 2012 Camaro SS 45th Anniversary EU Join Date: Jun 2020
Diff Oil recommended but...
Hi guys!
I have a little wine sound from my rear end on speeds 80-100km/h. I know that manual says about 75W90 but I use thicker oil 75W140(Amsoil) for all my posi rear ends . Is it ok? P.S.: We have a very hot summer here +38-42 degrees C (100-107 F) |
08-21-2020, 10:43 PM | #2 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Should not hurt, a little whine is nothing to worry about. Is it on decel or all the time?
Roto-fab CAI, Nick Williams 102mm TB, LOD X1 V3 intake manifold, GMPP LS3 heads, Night Fury cam, TSP 2” long tubes, Corsa ZL-1 catback, Nitrous Outlet 102mm plate kit/150 shot, NGK BR7EF plugs with Taylor plug wires, DSX flex fuel kit, ZL-1 fuel pump and injectors, B&M deep trans pan, Yank 3400 converter, 3.45s with BMR Delrin bushings, mishimoto 169° Thermostat, GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, ZL1 10 spoke wheels, 12” subwoofer, and custom paint matched interior.
08-22-2020, 02:13 AM | #3 |
08-22-2020, 03:52 AM | #4 | |
A howl or whine during acceleration over a small or large speed range is usually caused by worn or burned ring and pinion gears or improper gear set up. Rumbling or whirring at speeds over about 20 mph can be caused by worn carrier bearings. The noise may change while turning. I have 173,000 on my Camaro, and the diff is not making any noises. I probably just jinxed that... |
08-22-2020, 03:57 AM | #5 |
Yes I know it is ring and pinion. Is it possible to change only ring pinion in future without changing pumpkin?
08-22-2020, 04:12 AM | #6 |
It's actually 100% easier to change the whole unit, rather than taking it out,
taking it apart, and changing the ring and pinion gears, bearings, setting preload, and spacing, putting it back together, then back in the car. You also have that marker step where you mark the ring gear to check for proper gear mesh. That's another pulling the cover off, looking, and if okay, back on and fluid fill again. The only time you want to change the ring and pinion is when going with non standard gear swaps, like something GM didn't offer... The LX/LD Dodge Charger is the same way, they call it a carrier. Mine had a 2.89 carrier, I wanted better. For $50, +$50 shipping, I got a 3.64 carrier on eBay, and it only took two hours to swap it. I was not going to pull it out, take it all apart, change the ring and pinion with all the setting up, then put it back in. That would have taken all day, and more money and labor. Naa, a whole unit swap was so much faster and easier. If it becomes a concern, just buy another unit and pop it in. These usually do not go bad unless you're continually drag racing the car. There is no shaft or differential up and down motion, so the pinion angle doesn't change to put stress on the pinion gear. It's all relatively a straight shot. The only movement you get is from bushings, and mount flexing. It's no where near a solid axle like my Mustang has that swings up and down on a panhard rod. The diffs in these cars should almost last forever under normal driving habits. |
08-22-2020, 04:14 AM | #7 | |
08-22-2020, 08:11 AM | #8 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Start by changing the fluid. Make sure is has the friction modifier in it.
These cars are noisy by nature. You should hear the diff with aftermarket bushings.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
08-22-2020, 08:37 AM | #9 |
I changed oil. Refill with Amsoil 75W140 severe gear plus added friction modifier Amsoil Slip Lock. Noise disappeared. Yes before i chanhed bushing to BMRs. Now i habe a little clunk in diff when puting D with brake pressed and little throttle added(Makes clunk 1 time). Then opposite gear in R same clunk 1 time
08-22-2020, 11:49 AM | #10 |
Fast Cars and Old Guitars
I just had to drain my first Diff change with Amsoil Severe Gear. I’m a huge Amsoil fan going back to the 80’s. But something about that and Redline’s LSD additive (all the store had) made it growl horribly after about 2 months and 3-500 miles. Only when turning... I thought it might like GM’s gear oil and additive so that’s what I put back in it. Quiet for now but I read it could return. The Amsoil was quiet at first too.
08-23-2020, 08:17 AM | #11 |
old school chevy rodder
there is a additive that's supposed to go in with the stock fluid BTW and without it may cause a whine...I would never use something not in the recommended grade as to void a warranty unless someone is very versed in the exact application and parts used for it... BTW
08-23-2020, 10:43 AM | #12 | |
08-23-2020, 11:13 AM | #13 | |
Here's an older thread on the ZL1 https://www.camaro5.com/forums/showthread.php?t=388177
08-24-2020, 07:53 AM | #14 |
I am not a fan of changing gear oil the a thicker viscosity. It may cause poor lubrication of the clutches and chatter/groan. Will it hurt? not really. For every day driving I would stick with 75/90. If you are getting a whine you have wear. Likely the side carrier bearing has some play so when the diff is loaded it is pushing the carrier to the side changing the tooth contact pattern making the whine. Road course or towing is the only time I'd use 75/140 personally.
