TireRack
Old 06-12-2020, 08:09 AM   #1
Whitlow
Whitlow's Avatar
Drives: Chevrolet Camaro
Throttle Controller
So I'm looking for some information on throttle controllers. Who has them what type do you like it. I'll take any advice from y'all
Thanks
Sent from my moto g(7) power using Tapatalk
Whitlow is offline   Reply With Quote
Old 06-12-2020, 12:08 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
I have the Vitesse and love it! Some people have complained about it giving them the "reduced power" state but I've only had this happen once in ~4 years and it was when I flicked the throttle a couple of times quickly (I'm guessing the ECU can't keep up/gets confused with the voltage amplification from the throttle controller).
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 06-12-2020, 12:38 PM   #3
mbesman
Great White
mbesman's Avatar
Drives: 2015 Camaro 2SS
I have Vitesse now for 2 years.. not a single issue and love it. Others have said otherwise but no issues with mine.
mbesman is offline   Reply With Quote
Old 06-12-2020, 12:41 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Same. Never have had an issue and I run mine with a ported TB.
InFiD3ViL is offline   Reply With Quote
Old 06-12-2020, 07:58 PM   #5
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
took mine out of my wrecked ls3 car and put it in the l99. i think it actually works better in the l99 as in more noticeable from sp 4 and up,i noticed it changes the shifting considerably. like everyone else i have seen horror stories mine messed up twice in the ls3 car but i just pulled over unplugged it at the petal and plugged it back in later.i didn't think it was that much of a inconvenience for the effect it has the 99.9% of the time that it works.
lemontwist is offline   Reply With Quote
Old 06-12-2020, 09:07 PM   #6
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Here’s a list I made up awhile ago.
Throttle Controllers
I personally have the Pedal Commander. No issues to date and fun to drive with it.
0stones0 is online now   Reply With Quote
Old 06-13-2020, 04:21 PM   #7
christianchevell
old school chevy rodder
christianchevell's Avatar
Btw the " Vitesse" when it came out looked exactly like any other Chinese controller with a sticker on it BTW....
Old 06-13-2020, 06:26 PM   #8
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Camaro6 forum members praise the solar performance ones. I’ve never used one before so I can’t comment
Bigdumogre is offline   Reply With Quote
Old 06-13-2020, 06:52 PM   #9
0stones0
It don’t come easy.
0stones0's Avatar
I’ll add it to the list.
Old 06-13-2020, 07:33 PM   #10
lt1power
Drives: 2011 2SS RS
Pedal Commander. Works great, no problems. The bluetooth version is the best.
lt1power is offline   Reply With Quote
Old 06-13-2020, 08:39 PM   #11
chasmanian
chasmanian's Avatar
Drives: 2015 Camaro SS
vitesse. Had it about four years. The original one i had before that threw a code and they replaced it. No trouble since.
chasmanian is offline   Reply With Quote
Old 06-14-2020, 01:17 AM   #12
InFiD3ViL
InFiD3ViL's Avatar
What is the bluetooth for? Change settings using your phone?
Old 06-14-2020, 05:06 AM   #13
0stones0
It don’t come easy.
0stones0's Avatar
That’s basically it. Allows you to hide the button controller under the dash or wherever, as well.
Old 06-14-2020, 02:47 PM   #14
Danial
Danial's Avatar
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert
Thanks
I have a vitesse for sale if you decide to go that way. $100. In the interest of full disclosure, it worked great for about 2 months and then one day my car went into limp mode. I took it off that day.
Danial is offline   Reply With Quote
