#1 |
![]() Drives: 2009 Camaro Join Date: Jul 2022
LS Valve cover barb size???
I'm wanting to get a quick dis-connect for my oil catch can line to connect to me driver's side valve cover (2009 Chevy 5.3L LS engine)
But, I'm not exactly sure what quick dis-connect connector to buy or where to buy it. The first step should be knowing what size the barb is located on the rear of the valve cover If anybody know what size this barb is, and what quick dis-connect connector to buy, please let me know. It looks kinda like 3/8 to me but it may be metric sizing. |
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SS-RS Join Date: May 2011
Try asking in here. A lot of knowledge in here.
https://www.camaro5.com/forums/forumdisplay.php?f=11
#3 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I think almost all of these for GM are 3/8. I know they are on ecotec motors. You have to be careful of what style you get since there isn't a lot of room on the valve cover side of the connector. The screw in retainer type likely won't work. You need the clip on style that has "windows" in the sides to be able to disconnect it. Something like this;
https://www.ebay.com/itm/13122379893...4AAOxymmJTkhAx I got some that didn't have the windows in the side and had to drill holes to be able to push the release clips. |
#4 |
I ordered one very similar to this... but these may not be deep enough.
I'll know for sure one it arrives. |
#5 |
![]() Drives: 10 2ss/rs Join Date: Jul 2018
You can just remove that tap it and put a an fitting in
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
#6 |
The bung on my valve cover appears to be pressed in so I'd have to remove the valve cover, drill it out and then install the fitting I'd like to have.
I wasn't interested in working this hard on this as I can always just use a 3/8 hose and worm clamp. I was just exploring what was available by way of quick dis-connects |
