02-03-2018, 09:27 AM | #1 |
Drives: 2006 Z06 Join Date: Jan 2015
Help me get the Zl1 1LE
Ok Im not trying to start a fire here. Just working through my next street/track car purchase. Looking at the GT350 R and the ZL1 1LE.
I love the look and feel of the Z as I saw it at the Rolex 24 last weekend. Prices on the car are good. Performance is insane. BUT feedback on reviews reports terrible street behavior and in my opinion 3800 lbs is way too heavy for the track. So is it just me or did Chevy build a car that really does not have a fit here? My next questions is how much weight can be stripped out of the ZL1 1LE without going bonkers??? Yes a roll bar will have to be added back in. Thanks |
02-03-2018, 09:31 AM | #2 |
Drives: 1970 chevelle Join Date: Aug 2011
if you can deal with a little bit stiffer ride on the street and you want a better performing car in all aspects get the zl1 1le. if you want a little nicer ride on the street and willing to sacrifice performance get the gt350r
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual |
02-03-2018, 09:38 AM | #3 |
Drives: Pre-production ZL1 M6 Join Date: Feb 2016
Not really an apples to apples comparison. The ZL1 1LE runs with Ford GT’s. The 350 will be a significant performance drop.
02-03-2018, 09:42 AM | #4 |
ZL1
02-03-2018, 10:24 AM | #5 |
Drives: 2019 Shock ZL1 Join Date: Jan 2007
Regular ZL1 M6 with the 1LE aero added to it, rear seat removed, and some lightweight alloy wheels for the track if you want 1LE but street comfort.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
02-03-2018, 10:39 AM | #6 | |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
The car fits right at home on a track, not on crappy, potholed and patched streets that the average driver puts up with. Concur, 3800 lbs is heavy for a track car but it could be lightened if you're serious (is this the "fit" you're referring too?). As some guys on here have done, first place I'd go would be to reduce the underslung weight, put the wheels on a diet and it will liven up the ride on the track quite a bit. |
02-03-2018, 10:43 AM | #7 | |
I think the ZL1's and ZL1 1LE's track times speak for themselves. For the price, you will not find a more dominant track platform...3800 lbs or not. |
02-03-2018, 10:46 AM | #8 | |
ZL1 1LE
02-03-2018, 10:47 AM | #9 | |
I used to be Dragoneye...
Another quick thought on weight...the suspension components (DSSV) are much lighter than the MR the GT350R uses...this will result in the same sort of nimble-responsiveness to changes in the road surface that the GT350R benefits from its wheels. Except the Camaro removed the weight from the working components of its suspension. Street behavior? It's like any other M6 ZL1 except for a couple differences - the ride is a little stiffer than "Track" mode in ZL1, but stiffer doesn't mean "harsh"...it's just...stiff, not painful. The only other street manners consideration is the front splitter...you should raise the shock heigh adjustments to full-high for street driving. That all said - I drive mine daily during the summer, when conditions allow (the Goodyear 3R tires are DOT R-comps, just like Pilot Cups...they don't like heavy rain). If you wanted to dump weight...you could start by swapping the heated, cooled, powered seats with Recaro or Sparco shells. And remove the rear seat....might be looking at 65-80 lbs there, depending on what you put back in. Then there's adjustability. Chevy designed the front struts to be adjusted for height...they included a camber plate for radical amounts of front camber...the rear stab bar has adjustments for under/oversteer...and the driving modes can fiddle with the weight of the steering. Alignment bolts, etc are very simple and easy to use. I have been told by someone attempting to align a Mustang GT350R that it's a b!tch; and a lot of cars out on the track are likely misaligned because of it. This particular person saw an amateur GT350R driver (consistent before and after) drop 5 seconds off his track times after a proper alignment because how it was to begin with was so bad. Read some reviews...watch some videos. The ZL1 1LE is the superior track car, in virtually every single way. |
02-03-2018, 10:51 AM | #10 | |
Wish you were closer so I could offer you a test drive. I think it would help make your decision easier to buy one. |
02-03-2018, 10:54 AM | #11 | |
02-03-2018, 02:46 PM | #12 |
Drives: 2013 Cayenne GTS Join Date: Dec 2013
Let’s just say at the track I blow away GT-R’s.
02-03-2018, 02:56 PM | #13 | |
Sarcasm loading --------
Not exactly the same, but there is a 5th gen SS drift car that was featured in an old camaro now magazine. They got the car down to 2800 lbs.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
02-03-2018, 03:19 PM | #14 |
ZL1 1LE
