09-27-2023, 05:11 AM | #1 |
What mods for an 700rwhp L99 Camaro?
Hi guys,
I am new here my name is Damian and I live in the Netherlands so American cars are little around here I would like to know what kind of upgrades i would have to do to get my L99 Camaro SS 2ss to get around 700rwhp and do well in the turns when driving on the track as well. I also want the car to be able to handle the power so I can push it hard like its dukes of hazard lol. Not that is breaks down every now and then so lets just say it needs to be able to handle about 800hp if you get the picture. My knowledge about cars is not very great but I would like to learn as much about LS engines as possible, that is why I came to this platform after all so please be as detailed and comprehensive as possible! So I have a 2009 Camaro SS 2ss with at the moment only upgraded Longtube headers with 3″ highflow cats and X-pipe. I don't know how much power it makes right now but I guess around 350 RWHP or 440 BHP. So what would you guys recommend to me to upgrade first? I have in mind right now to go for a stage 2 or 3 camshaft with LS3 convertion, that also made me wonder if LS7 or LSX convertion would be possible if it doesn't cost to much lol. After experiencing a Procharger of a friends Corvette I am leaning towards doing that to in the future sounds and feels amazing. I seen about nitrous shots as well but I know to little about it and its bennefits. Not sure what I should do for the transmission tho, Gear ratio change for sure but other then that no idea. I am the most afraid of the transmission failing.. Also something to note is that I like to have something most others don't something unique so I want the car to look good to when you open that hood. (srry for my bad english
Lets be friends fr: https://www.instagram.com/damianvanloo/
L99 Camaro 2SS 2009 Mods: 1 7/8 Longtube Headers - 3" Higflow cats/ X-pipe Last edited by Dvloo; 09-28-2023 at 02:58 AM. |
09-27-2023, 07:19 AM | #2 |
If you are worried about cost, don't set 700whp as your goal.
The stock differential and axles might live for a bit if you don't launch it hard on sticky tires. You would also be at the upper limit for the 6L80 trans. To get to 700whp on the street, forced induction is your only option. A lot of people use Procharger or other centrifugal blowers. Positive displacement blowers, like Magnuson and Whipple, come on much earlier, but would require power train upgrades for sure. Turbos can get you there but they all have issues to be worked out like heat or oiling. I have a turbo myself but most say the PD blower is the simplest set up for the street and you don't have to make 700whp to be very quick. They also have the best under hood appeal IMO. Whatever you do, plan on 10k USD and that is doing a lot of work yourself.
09-27-2023, 07:35 AM | #3 |
Drives: 2013 1ss Join Date: Jul 2012
You will need about $15k to achieve the goal and another $15k for broken parts once you start using the power.
Basically you should research and plan on upgrading every driveline part after the crankshaft. I have 610rwhp and was fine until I put sticky tires on the stock drivetrain. |
09-27-2023, 08:50 AM | #4 | |
3P171 USAF Combat Arms
Drives: 2013 SS/RS Join Date: Jul 2021
I’m at 801 rwhp and have about $60k in engine, trans, suspension, rear, etc… mods. My motor alone was $37k and I’m looking at another $35-40k to get me to over 1200 wheel. There are a couple members on here that have seen my build sheets & invoices.
416ci LS3/Vortech V7/Built 6L80
994.4 RWHP 793.8 RWTQ |
09-27-2023, 09:31 AM | #5 |
This is the most honest answer you will get.
TSP 229/244 .629"/615" CAM w/ a bunch of goodies 465whp/443tq tuned by MayhemMotorsports-NC
09-27-2023, 09:40 AM | #6 | |
Drives: 2014 SS 1LE Join Date: Apr 2014
Boost of your choosing, fuel system and drivetrain will get OP his goals for 10-15k.
09-27-2023, 11:07 AM | #7 |
He also asked for track level handling. The trans isn’t taking that at least for long. Axels. Rear diff. Etc. a decent supercharger system, without doing a cam and all the top end internal components is $7-10k plus E85, injectors, fuel pump, it keeps going. I’m sure you can somehow do it for $15k, but you won’t be doing it for long.
09-27-2023, 11:45 AM | #8 |
Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
I remember doing research while back on the auto transmission since that's what I have, to handle higher power you need some sort of cooling for the transmission fluid, I think at minimum a deeper pan maybe a trans oil cooler, then on top of that there are kits for replacing the little clutches inside the transmission itself that need to be upgraded otherwise the stock ones will start slipping and taking other things with them.
Behind every scratch is a story on what not to do, and my car has a lot of stories.
09-27-2023, 01:33 PM | #9 |
Cam- 2500-3000$
forced induction 5000-7000$ Fuel components - 2000-3000$ Trans TBD (idk much of the 6l80, just that I had in my G8 which had a trq converter). That's really the meat and potatoes of it all. Then you have to add labor, tuning, miscellaneous cost. Definitely gets expensive.... I don't say how much I've spent on modding my current and previous cars, but it's up there. Do it all in 1 shot if you can.
09-27-2023, 01:50 PM | #10 | |
09-27-2023, 01:55 PM | #11 |
This is why I don't understand how anyone can have a car approaching 1000hp with all the right supporting mods and not build it themselves. Shops want crazy money these days and if you build it yourself, they don't want to tune your build. I might have 37k all in with a built turbo LS3, level VII M6 w/Mantic triple, ZL1 diff with GForce Outlaws, two stage nitrous w/Nano, E85 conversion, meth, Z28 suspension and factory Recaros. It's still probably not 37k and I've fd some stuff up over the years, hell still doing it. I'm not rich, but I make pretty good money and I could not even imagine spending 80k on an engine without having sponsors.
09-27-2023, 03:01 PM | #12 | |
ABM #2399 2SS/RS:SOLD
09-27-2023, 03:36 PM | #13 |
Once i saw the terrible quality from the so called experts i went back to doing it all myself. I've got about 40k miles on my whipple and have broken every part after the crank at least once. I feel much safer and know the car is more reliable with me doing the work.
09-27-2023, 06:11 PM | #14 |
One extra byproduct of doing it yourself is that when stuff breaks you know exactly what it is because chances are you held it in your hands before, then on top of that you know you have no one else to blame but yourself which helps narrow down what went wrong. Although I will say it's not all glamour, pretty sure I shaved off at least 10 to 15 years off my life dealing with stuck bolts, cramped spaces, and those stupid plastic locking clips that they shove on every single electrical connector, I am almost certain those are put there for the one single purpose of pissing you off because I've broken a ton in blind rage and it has not come back to haunt me yet.
700hp, l99 camaro, mods |
