10-02-2018, 04:56 AM | #1 |
Drives: 2013 2SS LS3 Join Date: Apr 2017
2013 2SS 6MT--Too big of a cam??
I've got a 2013 2SS LS3, currently torn down, about to be cammed. Has forged pistons in the bottom end (Guy that put them in says they have .040" on the top deck.), trunion rockers, and BTR Dual valve springs (.660" lift, standard size guides at .505".) Also has COMP 5/16" 7.400" length pushrods. Also have Ferrea Intake Valves.
Essentially I'm trying to put the largest possible N/A cam in the car without creating any PTV. Texas Speed has their new Stage 4 F-35 Cam at 235/248 and .649"/.615" with a 111 LSA. My question to you all is this cam too big? Do I risk binding a valve spring? Can I just get shorter pushrods? If so, what length do you recommend? P.S. All of these valve train upgrades and forged pistons are already done because I had a guy put a stage 4 BTR cam kit in for me, he did it cheap(get what you pay for), but too cheap. Didn't torque down cam bolts and they backed out whilst driving down the highway....sad face. Wouldn't cover rebuild cost either. So that's why I'm here. |
10-02-2018, 05:46 AM | #2 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
With aftermarket pistons in there.. you need to measure imo
603 h.p. 495 ft lbs tq. |
10-02-2018, 07:05 AM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
With aftermarket pistons you should not have a problem, it sounds to me like you dont have any experience with engine building at all. You should have someone put it together that knows how to measure it and get it done right. Sorry to be so blunt but just trying to save you grief down the road.
10-03-2018, 12:33 AM | #4 |
Drives: 13' 1LE Join Date: Apr 2012
Go a bit smaller if you want to be safe about PTV. Stage 3 is better for PTV, and is more forgiving in case of an over-rev.
Both arent too big, but gears and smaller wheels/tires would help a lot to tame biggest cams.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
10-03-2018, 08:41 AM | #5 | |
GPI Sales Consultant
But these guys are right - you're not stock any more and you really want to do some actual PTV measuring to make sure you're in a safe spot. Also, I dunno about the F-35, but the the SS3 is cut on a smaller base circle and requires a longer 7.425" pushrod for proper lifter preload. You should be measuring for that (proper lifter preload) as well. The F-35 and SS3 are both really good choices for a stout NA build. I recommend you give GPI a call and talk through your combo, they may be able to offer some insight on your options. It sounds like with the aftermarket pistons you may have plenty of relief and could reasonably running a more aggressive cam that usually requires fly-cutting in stock applications. Not sure what your goals are, but that's something to consider - Ryan at GPI could help you spec out something custom that would really maximize your setup.
Got a question about a GPI product? Feel free to shoot me a message! |
10-04-2018, 07:41 AM | #6 |
old school chevy rodder
You need to talk to professionals first...……. Most builds require longer pushrods by .025 due to the smaller than stock base circle, of course if your reusing anything it may be OK, measuring for PTV clearance smart, and the largest CAM NOT ALWAYS THE BEST...… you want power you can go all out paper chase for HP and torque be damned and average power be damned or you can be smart and look for lots of power under the curve to move a heavy object. You amount in the Hole matters to the pistons as does the Head gasket thickness, and fly cutting is always a option for some and what we think of as big cam is small for real race cars.....
10-06-2018, 07:56 AM | #7 |
Drives: Black aSS 2011 - L99 Join Date: Apr 2012
I just installed the BIG Texas Speed Cam, their 2.00" headers and full 3" exhaust, (no cats), to the back. Did the L99 to LS3 conversion while I was in there, (all Texas Speed). Now I sit all mechanically ready to blow tires and My computer is stuck in 4 cyl mode, the TPS's are both acting up, and misfires are being reported to the ECM because of the DOD delete. What can be done for a quick fix as far as tuning goes? I have the trifecta flash cable so I can hook up from my laptop to the OBD port. I wonder if I throw a stock LS3 tune in there if it will work until I can get to the tune master and dyno?
Staying stock and loving it............
10-06-2018, 08:25 AM | #8 |
Just fyi... I used to use the .639/.623 TSP 235/239 cam was awesome, no problem with PTV clearance 112 LSA but used; 675 springs......
cam, camshaft, ls3, texas speed, valvetrain |
