Old 08-07-2017, 05:37 AM   #1
OnkelMatze
OnkelMatze's Avatar
Drives: Camaro 2SS/RS LS3 AirForce
engine won´t start when hot - problem solved
I had these starting issues when engine was hot, like at a stop after a while of driving
cold starts worked fine....
- bought a new battery, same
- bought a new starter, same
- wrapped starter with heat shield, same
gauged the volt value at the starter when engine was hot,
there were 2 volt less than directly from the battery in the trunk
solution:
installed an additional ground wire from the engine block
to the chassis, now hot starts work same as cold starts
attached a picture of the new cable
OnkelMatze is offline   Reply With Quote
Old 08-07-2017, 06:10 AM   #2
camguynj
camguynj's Avatar
Brilliant! This has been a chronic problem that has plagued many over all 5th gen yrs who tried everything you did except measuring for voltage differences. Looks like you found the Holy Grial cure. Thanks for posting the pic. Which side of the block did you mount the addtl ground as you can't tell for certain from the pic, looks like left front? Just curious what heat shield wrap did you use?
Old 08-07-2017, 06:38 AM   #3
OnkelMatze
OnkelMatze's Avatar
its at the driver side, there was an empty drilling hole at the block where the new cable was mounted
I used the Universal Starter Head Shield from Amazon
here is a picture of the mounting at the chassis driver side:
Old 08-07-2017, 06:54 AM   #4
camguynj
camguynj's Avatar
Thanks for the reply. What is that wire that shares the chassis ground spot? Also just to be certain because you're in Germany is the driver side the left side of the car?
Old 08-07-2017, 06:57 AM   #5
OnkelMatze
OnkelMatze's Avatar
looks like another ground cable, but I am not sure,
all of the work is done by my local shop
Old 08-07-2017, 07:36 AM   #6
camguynj
camguynj's Avatar
Reason I asked is mine is a '13. It has the empty block drilling hole but chassis grounding is different. I didn't see anything grounded on the drivers side chassis frame rail. Doesn't mean anything a ground is a ground, unless the ground yours shares is the alternative or front battery terminal ground and that's what's helping keeping the voltage constant at startup?
Old 08-07-2017, 07:53 AM   #7
OnkelMatze
OnkelMatze's Avatar
I just talked with my mechanic, he says the second cable at the chassis frame is directed to a control module
any contact at the chassis works fine for that additional cable, best place is where a screw already exists
Old 08-07-2017, 09:07 AM   #8
camguynj
camguynj's Avatar
Thanks for checking, much appreciated
Old 08-09-2017, 02:10 PM   #9
jdpeezy91
jdpeezy91's Avatar
Drives: 2012 Camaro 2SS RS
Im having pretty bad eletrical and hot start problems here to, would like to know where you ran this ground to on the sub frame or body do you have to drill a hole for it or bolt it to an existing point?
jdpeezy91 is offline   Reply With Quote
Old 08-09-2017, 02:19 PM   #10
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
Curious, why didn't he replace the bad ground cable instead?
JerTM is offline   Reply With Quote
Old 08-09-2017, 02:28 PM   #11
OnkelMatze
OnkelMatze's Avatar
there was an existing point where the additional cable was mounted
check the picture of the chassis frame below
Old 04-22-2018, 04:22 AM   #12
05SilverStreak
05SilverStreak's Avatar
Drives: Black aSS 2011 - L99
So is this going to plague every 5th Gen as it gets older? Now My Car won't start!
Staying stock and loving it............
05SilverStreak is offline   Reply With Quote
Old 04-22-2018, 09:22 AM   #13
camguynj
camguynj's Avatar
The starting problem in this post is due to starter “heat soak” which really has nothing to do with the age of the car, it’s primarily due to the heat affect that LT hdrs have on the starter.
What kind of starting problem are you having?
Old 08-14-2018, 08:22 PM   #14
Leo72793
Drives: 2011 2SS/RS
solution:
What sized bolt is that? Im going to try this.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
