04-12-2020, 04:10 PM | #1 |
Drives: Chevrolet Camaro Join Date: Mar 2020
RAMPS INFO FOR OIL CHANGE
So what do y'all use to get your Camaro up to change oil? And not a car lift. What do you have and how much?
Thanks Sent from my moto g(7) power using Tapatalk
04-12-2020, 04:29 PM | #2 |
Drives: 2010 Camaro SS Join Date: Jul 2018
a jack and jack stands
2010 2SS/RS 6M, MGW flatstick, CAI cold air intake, SLP loudmouth 2 axleback, TSP 1 7/8 headers w/ hfc, pfadt 1" springs, SRP pedals, emblempros "6.2L" emblems on hood, ZL1 grill, M/T SC-5 wheels, nitto motivo 275f 315r. ZL1 addons wickerbill, smoked lenses, resonator delete x pipe, diode dynamics DRLs 1LE suede steering wheel, mighty mouse CC. SCTX4 and Dyno Steve tune.
04-12-2020, 04:35 PM | #3 |
Well, I was using ramps, but I don't think that's happening anymore. I lowered my car more this week and I can't even get a low profile jack under it unless I drive onto some 2x4s first.
04-12-2020, 05:06 PM | #4 |
Drives: '12 SS Silver Ice Metallic Join Date: Nov 2016
3-ton floor jack, low profile. Jack stands. All from Harbor Freight. I've used them a lot and they have been great.
04-12-2020, 05:08 PM | #5 |
Rhyno ramps from walmart and now that its lowered some 2x10's to get into the ramp.
04-12-2020, 05:12 PM | #6 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
I use Race Ramps 67” Long 10” High. They run about $350 but are well worth the money!
04-12-2020, 05:33 PM | #7 |
It don’t come easy.
Rhino’s that just clear the GFX.
04-12-2020, 05:40 PM | #8 |
Drives: 2011 Camaro 2SS/RS Join Date: Feb 2020
Rhino Ramps. Got them at Autozone for either $39.99 or $49.99
L99 to LS3, Whipple 2.9 Blower with 3.750 pulley, ID1050x injectors, JRE Rough Idle Blower Cam, BTR Bronze Bushing Trunnion Kit , JRE/BTR .660 Springs, BTR Pushrods, Melling High Volume Oil Pump, ZL1 Fuel Pump, JRE FPCM, JMS BAP, JRE 90MM Ported Throttle Body Circle D 3200 Stall Converter, Ceramic Coated Kooks Long Tubes, Kooks Full Exhaust with Hi Flow Cats, Cold Air Inductions Intake With JRE Scoop, JRE Built Rear Differential with Billet Caps, 3:91 Gears and Eaton TrueTrac Posi, JRE Dyno Tune, Moroso Wires, Moroso Catch Can, Factory Reproductions Gloss Black ZL1 Wheels. 659WHP/566TQ
04-12-2020, 06:16 PM | #9 |
Stigs Bahraini Cousin
I don't use ramps, maybe its an OCD thing not sure.
parking it angled will not drain totally.
2015 CAMARO 1LE
04-12-2020, 06:21 PM | #10 |
Yup that's pretty ocd lol. No need to worry about a few ounces of old oil. I knew a guy once who would start the engine for a couple seconds after the oil was drained to make sure he got all the oil out.... the amount of life he took off his cars was way more than the little bit of old oil left in the engine lol.
04-12-2020, 06:34 PM | #11 |
Give speed a chance
My Z/28 has a pretty low snout so I use the ZL1 Addons Premium 3" Jack MagPad for lifting using the pinch weld location. About $41 ea or $131 for a set of 4. Place jack stands at sturdy sub-frame points and have at it.
04-12-2020, 06:37 PM | #12 |
Ok so how many inches would i need to get ?
https://www.amazon.com/RhinoGear-119.../dp/B0117EETEK https://www.summitracing.com/int/parts/bti-rr-40
2015 CAMARO 1LE
04-12-2020, 07:25 PM | #13 |
Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
ditto
p.s. the oil drain is to the passenger rear so oil drains fine I only have to get the drivers side up high enough to get under the car with jack stands
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
04-12-2020, 07:35 PM | #14 |
I can't get any regular ramps to work even the ones I had for my 77vette won't work. My SLP is lowered 1" front and back. But I'm not taking it in for oil change for someone to take it out for a joy ride.
