TireRack
Old 07-16-2010, 11:43 AM   #1
My 5th
My 5th's Avatar
Drives: 2010 2SS/RS M6 Black on Black
Outside Air temp sensor reads high
I tried searching but couldn't find anything on this problem. The outside air temp display in my radio seems to read about 7-9 degrees hotter than the real temp. I pass a local bank with a temp display and my reading is always hotter by at least 7 degrees. I know the bank's temp could be wrong, and probably is, but 7 or more degrees is too much difference.
Can the Camaro's display be adjusted? Or is it a matter of checking the sensor to see if it's blocked, or getting hot air off the radiator? Where is the temp sensor located? Pics? Thanks.
Meh
My 5th is offline   Reply With Quote
Old 07-16-2010, 11:45 AM   #2
DevilKnightFalcon
DevilKnightFalcon's Avatar
Drives: 2010 Camaro 2LT/RS
Send a message via AIM to DevilKnightFalcon Send a message via Yahoo to DevilKnightFalcon
Mine is always dead on. I don't judge by those signs because they never seem to be accurate but I got in the car the other day around 5pm and it read 117 degrees. Went home, watched the news and the high temp for the day was...117 degrees.
MBRP Catback/Magnaflow Resonated X/Airraid V2 CAI/Dash ABL/Interior LEDs/Custom Paint/Jet Coated American Racing LT Headers/High Flow cats/Trifecta Tune
DevilKnightFalcon is offline   Reply With Quote
Old 07-16-2010, 12:17 PM   #3
bradshaw
bradshaw's Avatar
Drives: 2010 LS3 2SS M6
Probably a bad sensor, take it to dealer and have it checked , mine is very accurate.
bradshaw is offline   Reply With Quote
Old 07-16-2010, 12:33 PM   #4
Darth_Emma
Psssssssssshhhhhhhhhhhhh!
Darth_Emma's Avatar
Drives: under contruction
My car reads warm when it's been parked on a hot day on hot pavement. Once I start driving, it's accurate. My other car (which is not a Camaro) does the same thing.
Darth_Emma is offline   Reply With Quote
Old 07-16-2010, 12:33 PM   #5
Frank in MD
Raining Blood
Frank in MD's Avatar
Drives: 2014 SS Performance Sedan
It will read high on startup, once you start moving temp display usually adjusts down by 5 to 7 degrees.
Frank in MD is offline   Reply With Quote
Old 07-16-2010, 01:13 PM   #6
it's because the Camaro is the Hottest car on the streets
Old 07-16-2010, 01:58 PM   #7
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Another thing to keep in mind is the location of your car's sensor vs. the location of the bank's sensor. You are on the road (probably either asphalt or concrete) and you have the added heat sink capacity from the road giving off higher temps that your car's sensor is picking up. The bank's sensor is (probably) not located directly above a giant heat soaked man-made rock.
I ran across this interesting thermal map of Syndey Australia...notice how the roads are red and the rest (buildings) is blue. They recorded a 4 degree celsius (~7 degrees farenheit) difference between the roads and everything else.
rolnslo is offline   Reply With Quote
Old 07-16-2010, 02:07 PM   #8
x626xBlack
ARMY of one.
x626xBlack's Avatar
Drives: 2011 Black SS/RS
Heat radiates from your car. Until you drive long enough for the wind to cool the body to ambient temp, your car is reading the heat at the sensor... if the sensor is on the hood of a Black car and its 100 out side that hood could actually be 107F. It is not wrong, that hood is actually 107F. I bet that darker cars will show a higher temp since darker colors absorb heat instead of reflecting it like white cars.
If the sensor happens to be on the under carriage or close to it your sensor is reading the heat of the blacktop or the heat radiating from the black top...
So while your sensor is not reading ambient temp, the temp it is showing is correct for the location it is in.
Hope that helps.
x626xBlack is offline   Reply With Quote
Old 07-16-2010, 02:09 PM   #9
jtzako
Drives: 2010 IBM Camaro SS
Mine is usually 'correct' within a couple minutes of starting to move. However in thick traffic or while in a parking lot it is always quite a bit higher than actual. This is normal so I dont worry about it.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 07-16-2010, 02:13 PM   #10
x626xBlack
ARMY of one.
x626xBlack's Avatar
On other models GM puts them between the outside of the radiator and the inside of the front bumper so they cool rather quickly to outside temp when driving. Not sure on the Camaro
Old 07-16-2010, 02:50 PM   #11
balagan
Drives: V6 RS SW
I wish my temp sensor read high, unfortunately when it says 49C it usually means it, even in the shade.
balagan is offline   Reply With Quote
Old 07-16-2010, 03:08 PM   #12
rolnslo
Rolling along...
rolnslo's Avatar
OK, that's too damn hot for me. 49 ºC = 120.2 ºF
Old 07-16-2010, 11:33 PM   #13
My 5th
My 5th's Avatar
My temp does go down after driving for a while, but it's still too high IMHO. My car is black and that might have something to do with it. Also, it seems to make a difference whether the AC is on Max recirculate, or just off Max and Fresh intake. Guess I'm gonna have to get under the hood and see if I can locate the sensor--maybe it fell out of a bracket or something.
Meh
Old 07-17-2010, 07:33 AM   #14
Huck1974
Drives: 2011 2SS
Its right in front on the Camaro also. I noticed it when tearing the car apart yesterday
Huck1974 is offline   Reply With Quote
VOLANT POWER CORE COLD AIR INTAKE (CAMARO SS) NOW IN STOCK! Nick@moranoracing V8 Bolt-Ons & Tunes 0 06-30-2010 01:45 PM
Breathless Performance Polished Cold Air Intakes! MoranoRacing V8 Bolt-Ons & Tunes 0 06-29-2010 10:52 AM
K&N TYPHOON Air Intake Kit - On Sale ~ Bolt on 18+hp! Circuit Motorsports V8 Bolt-Ons & Tunes 101 02-06-2010 12:16 AM
Fastlane Pipeline Cold Air Intake Fastlane V8 Bolt-Ons & Tunes 24 01-12-2010 09:35 AM
