Old 03-12-2024, 11:57 AM   #1
clutchkick
Drives: '12 2SS 6MT
Replacement axles for stockish SS power
So my passenger side axle seal (LS3/M6) has a decent leak, leaves a few quarter sized drops on the garage floor every time it's parked. Looking at some other threads I've seen the axle could need replacing as well, and based off the mileage (93k) probably isn't a bad idea. So that brings me to this question: with GM/Acdelco axles being discontinued, what axles should I get? I have no plans of going beyond FBO power levels anytime in the near future, but do plan on lowering it and do a few autocrosses a year. Even still I feel like 1k+hp rated axles would be overkill, given that I don't launch the car hard. Is there an OE replacement type brand available somewhere (maybe at rockauto / auto parts stores??) that isn't just cheaply made garbage from overseas?
Cold Air Inductions intake w/ race scoop, Borla ATAK Catback, EBC Yellows & RBF 600, BMR strut brace, Z28 replicas, Factory Hurst Shifter
clutchkick is offline   Reply With Quote
Old 03-12-2024, 01:02 PM   #2
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
Talk to Leadsled, I believe he used SKP axles for a Z28 and had good results.
https://www.camaro5.com/forums/showthread.php?t=600181
Mods: Texas Speed 2 inch headers, high flow cats, and X-pipe. Custom mid-pipe, Borla Xr1 mufflers. Torqstorm Supercharger, 3.1" pulley, ZL1 fuel pump. MGW Shifter, Mcleod RST clutch, Tick master cylinder and Tick Billet bushing reinforced slave cylinder. DSS One-piece 3.5" Driveshaft, Metco Driveshaft safety loop, BCRacing Coilovers. BMR Poly Diff bushings, Poly Rear cradle bushings, Sub-frame connectors, Lower control arms, camber arms, and toe links.
The_bald_eagle_machine is offline   Reply With Quote
Old 03-12-2024, 07:24 PM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Not too long ago someone was able to get OEM Z28 axles but they were over $300 each. Z28 and 1LE axles were the best units for the 10 bolt. The outer CV is slightly larger than the regular SS axle.
I'm not familiar with SKP, but it would be nice if someone built an axle that could take 500whp for under 2k.
Old 03-13-2024, 05:27 PM   #4
clutchkick
Drives: '12 2SS 6MT
Thanks for the shout I'll definitely look into it!
Totally agree with Cracka, and can only find Z28 axles for one side and it was pretty pricey
