TireRack
Old 01-31-2024, 08:58 PM   #1
milo8604
SSonBayou
milo8604's Avatar
Drives: GreySS M6 SS
M6 to 4l80
I’m gathering everything in need swap my m6 to 4l80. I’m not sure on flex plate install. Do I remove pilot bearing and replace with new one and use spacer that comes with Tci flex plate? Do I remove bearing and just use the that comes with flex plate spacer?
Nightfury Camshaft | AGP TT 57/57's | AGP/Fore Triple Pumps | ID1050X Injectors | Custom 3" Exhaust | McLeod Twin RXT | 10lbs boost 779/707 on E85 711/641 on 93. Tuned by Geoff Skinner EPS
milo8604 is offline   Reply With Quote
Old 02-24-2024, 09:07 AM   #2
Tommy434
Tommy434's Avatar
Drives: 2014 SS 2010 SS 93 Camaro z28
I did this swap last year now swapping to a 400 i have a us shift control box and I modified stock shifter w/ linkage all works like a champ. Let me know if your interested in any of it. Btw i wired all my back up lights and back up camera to work. Just takes a little wiring knowledg.
Tommy434 is offline   Reply With Quote
