04-18-2024, 04:01 AM | #1 |
Exhaust Install Question
Hopefully someone here has been in this situation, but I'm getting ready to remove my AWE exhaust and replace it with a Corsa Axle back exhaust. The AWE exhaust doesn't use valves so I remember removing the OEM valve control motors from the stock exhaust since they weren't used. Now that the Corsa exhaust has valves, the install instructions state:
Locate the muffler and the valve control unit removed from the stock muffler. Orient valve to match the rotation of the valve control unit as it was when removed from stock exhaust. Since I have no idea what the orientation of the valve control units were when I removed them from the stock exhaust, is this going to give me any problems installing them on the Corsa exhaust or is it much simpler than this and am I overthinking this process? |
04-18-2024, 05:32 AM | #2 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Pretty sure they only attach one way, been a while since I swapped the ones on my '17 so many years ago, but I don't think you can mess it up...
That said, you could probably figure it out but just attaching the control unit to the muffler and toggle'ing it in the car and watching it. On a lift it might be tricky, but still doable?
I hope the 6th gen Camaro has a melodious horn trumpet. I'll tootel it at the ladies, yelling out "Hi hi." - RenegadeXR
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
04-18-2024, 05:46 AM | #3 | |
04-18-2024, 05:48 AM | #4 |
Drives: 2022 ZL1 1LE Join Date: Jan 2021
I don't have any input to help you out...sorry. But I would like to get your opinion on how the corsa is in comparison to the AWE. Why are you switching? And if you wouldn't mind giving a review on the differences as you drive the corsa. Thanks!
2022 Red Hot ZL1 1LE
1972 Chevy Nova Sold: 1997 Z28 Camaro 2000 Corvette |
04-18-2024, 06:23 AM | #5 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
I would also like to hear a comparison video on the Corsa if you could.
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
04-18-2024, 06:36 AM | #6 | |
04-18-2024, 07:19 AM | #7 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Was your AWE a catback system?
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
04-18-2024, 07:29 AM | #8 |
Yes, which brings me to another issue, I'm hopeful I'll be able to swap the axle back Corsa system and connect it to the AWE X Pipe. I don't want to have to buy a Corsa X Pipe to connect it if I can help it. I won't know for sure until I get the Corsa system tomorrow and get the car up on a lift to see if it will bolt on.
04-18-2024, 08:08 AM | #9 |
They only go on one way, so you should be good. But you could always key the car on with the valves plugged in and not installed to make sure they default to the correct position then install them.
You should be fine on the X pipe. I have my Corsa axle back bolted up to a Borla 60608 resonated X pipe and it all fit perfect.
2016 NFG 1SS A8
04-18-2024, 08:36 AM | #10 | |
04-18-2024, 08:42 AM | #11 | |
Drives: 2023 ZL1 - Modified All Bolt On's Join Date: Dec 2022
I think once you shut the car off, the valves go back to the default position. Thus when I start my car, it defaults in touring mode (as the default)? So, I'd think the valves are in touring mode when no voltage is being pushed to them, the car starts up in touring mode?
2023 ZL1 Auto - CSP 2" Long Tubes by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port | Griptech 2.3" Upper | ATI Super Damper 15% / 9.45" Lower | TooHigh PSI Port Injection w/875cc Injectors | E85 | Granatelli Malevolent Coil Packs | Katech Low Profile Billet Valve Covers | Katech Duel Fuel Pump System | Mighty Mouse 1000 | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | Katech Tuned
04-18-2024, 08:48 AM | #12 | |
04-18-2024, 08:58 AM | #13 | |
04-18-2024, 09:59 AM | #14 |
Another question to ask is when you switch from one catback to another (different brands) is the "cut" you made for the original going to work with the new?
