05-14-2010, 06:39 AM | #141 |
and MR. HYDE
Drives: 2010 2SS RJT/BLK 6Spd Man Join Date: May 2009
SO when you have a tune installed and you take your car in for service what happens? Do you need to return it to stock? What happens if they update your car when they have it, does it delete the tune? Can you kinda explain that process.
05-14-2010, 07:14 AM | #142 | |
Drives: 2006 Monte Carlo SS Join Date: Jul 2009
always restore original backup before going in to the dealer for anything... |
05-14-2010, 07:55 AM | #143 |
and MR. HYDE
[QUOTE=06MonteSS;1853308]yes... if you're using a handheld programmer such as the Diablo Predator or Trinity, return the vehicle to it's stock/original tune... because if you don't, and they flash an update to the car (yes, it will overwrite the tune you installed), then the last tune written to it won't match the "last tune written" flashed by the predator/trinity, and it will be locked and unusable until you call diablosport to get it unlocked/reset over the phone.
always restore original backup before going in to the dealer for anything...[/QUOTE] OK, another dumb question about this. Just trying to understand. You get a tune to make your car run right, so if you change it back to stock it will not run right when you take it back to the dealer, correct? Second dumb question, when you do a tune, I'll use mine for example since the person writing the tune is not located near me and someone else is doing the install, Once everything is installed I am supposed to get a reading and send it back to the tuner, he is then going to write the tune for my application and send it back to me. All this is done electronically( e-mail ) so by doing this won't I have the files of both stock and tune for the future? |
05-14-2010, 08:24 AM | #144 |
Drives: 2006 Corvette Z06 Join Date: Feb 2010
If you use HP Tuners or EFI Live, you don't REALLY need to return the tune to stock (they can find out apparently). If they reflash your car, you can just re-read the calibration from the vehicle, copy the differences from your tune file, and flash the new tune.
When the dealer reflashes, typically the operating system ID changes, which means your old tune can't just easily flash back in. You can do a write entire, but there's no point. Instead, you just open the new file pulled from the vehicle, open your old file as a compare file, and then copy differences. Bam, done. If you don't have a cam or anything, putting a stock flash back in your car won't really make it drive that bad. |
05-14-2010, 08:34 AM | #145 |
and MR. HYDE
Well I am putting a cam in, but the reason I ask is I know there are some updates that need to be done, A/C, PDIM etc....and just want to make sure of how I do them so I don't mess up anything.
05-14-2010, 08:50 AM | #146 |
My brother and I worked on this a few years ago. most should still apply.
(a guide for newbies to what it takes to build a fast F-body) Being fast is much, much more then just making a lot of power. There are SEVERAL topics that make up the ability to be fast at the track. We will discuss the things that you can directly affect. We will split the topics up one at a time, and even get part-specific, defining what a part is and what it does. Part I: Power A. Nitrous Oxide B. Heads/Cam C. Bolt-Ons D. Short Blocks E. Fuel Systems F. Forced Induction Part II: Drivetrain A. Manual 6-Speed (M6) B. Automatic 4-Speed (A4) Part III: Chassis/Suspension A. Chassis B. Suspension Part I: Power Power is the newbie's wet dream. It is what Vin Diesel said he needed to twist the chassis off the line, and you want a twisted chassis don't you? In its simplest form, the motor is nothing more then a power-making air pump. The more air in, the more air out, the more power you make. That is not everything by a long shot, but it will help you figure out if a mod will help or hurt. There are A LOT of ways to make power -- more importantly, increase power output from your motor. Here are some of them. A. Nitrous Oxide Nitrous Oxide (or N2O) is a chemical oxidizer; it is two parts nitrogen and one part oxygen. The oxygen is the part that makes power. Gasoline combines with oxygen in a combustible mixture. The more of both gasoline and oxygen you have, in the proper amounts, the more power you make. So why not inject pure oxygen? Simple: pure oxygen is much, much more intense of an oxidizer. Having about five times the intensity that N2O provides, pure oxygen would melt your motor. Bang for buck, N2O is the fastest way to make power. That being said, N2O has a bad reputation for giving more BANG then people expected. Let me go on record as saying, this is not the N2O's fault. The fault is on the person trying to get away with spraying nitrous and only having $500 total to put into it. Nitrous is a SAFE power adder, if it is both set up correctly and used properly. Setup Types There are 3 major types of nitrous setups. 1. Dry 2. Wet 3. Direct port As with most choices, there are pluses and minuses to all of them. Dry: A dry shot relies on the car's MAF, PCM, and fuel system to add the proper amount of fuel to balance the nitrous out. That is, the nitrous is sprayed in front of the MAF, which recognizes a sudden spike in O2 and signals the PCM, which decides the proper amount of fuel needed to balance the mixture. It is the cheapest of the setups to purchase. It also leaves no chance of fuel "puddling" in the intake. The weak point in this system is the car's fuel system. The dry shot is limited to the car's ability to increase fuel. Often a shot will find the weak spot in the fuel system, be it the injectors, the fuel pump, etc. Spraying N2O without the fuel to support it equals the kiss of death for your car. Wet: A wet shot does not rely on the car's MAF, PCM, or injectors to provide the proper amount of fuel to balance the mixture. It has a separate fuel line with its own jetting that is set up to spray the exact amount of fuel needed to go with the size nitrous shot you are using. In some cases, this may require you to step up your fuel pump, but you need not worry about your injectors. Some drawbacks are that with a separate fuel line and the fact that the spray is happening AFTER the MAF, any trouble with the system will go unnoticed by your PCM until it's too late. If your nitrous stops spraying but the fuel does not, then it will puddle and possibly introduce you to your hood-- the hard way... If the fuel side cuts out but the nitrous side does not, then you will go drastically lean and blow your motor. Threat of these things can be minimized. Buy GOOD parts, not the cheapest you can get away with. Direct Port: A direct port setup mixes the N2O and fuel, and directly injects the mixture into each individual cylinder. It is by far and away the safest and best way to use N2O. It does have one major drawback... PRICE. The direct port system by itself, can cost north of $1500. That does not include any of the supporting parts, that really are must-haves with ANY nitrous setup. Accessories Not just the base kit. If you plan on running N2O and would like your car to last more then just one or two runs down the 1/4, then you should compliment your base kit with the proper accessories. These include: - RPM Window Switch: It will turn your nitrous kit off and on at preset RPMs, 1. so you don't spray under low RPMs, which can blow your motor; and 2. so you don't spray right into your rev limiter, same reason. - Fuel Pressure Safety Switch: If your fuel pressure drops below a safe range while spraying nitrous, the safety switch will shut the nitrous off to keep from running the engine too lean. - Bottle Pressure Gauge: It allows you to safely monitor your nitrous pressure from the passenger compartment. - Throttle Position Sensor (TPS) Switch: Also called a WOT switch, it only allows your kit to turn on when you are at Wide Open Throttle. - Automatic Bottle Heater: It will keep your bottle at the correct temperature and pressure to ensure that you are spraying the correct size shot. This is especially important in a wet shot setup, as the shot of fuel will not adjust to the lack of nitrous from a cold bottle. - Purge Kit: This vents old nitrous left in the lines from the last time you sprayed, and keeps it out of your motor. This is not everything there is to know about nitrous. It is only a quick, down and dirty introduction to entry-level knowledge that you should have before you go the N2O route. (As a side note, it should be said that referring to nitrous as NAWS or NOS is a good way to get made fun of at the track, and could even get your ass kicked.) B. Heads/Cam Heads and cams are like peas and carrots. They belong together, should be bought together, they rely on each other; so we will discuss them together. In the beginning of this thread, we said the motor is a power-making air pump. Well, your heads and cam decide just how much air gets in, and how much gets out. Most often referred to as the heart of any race car, the head and cam selection is a huge factor in just how much power your pile is capable of making. Just because you buy the biggest cam on the market, and the biggest-port highest-flowing heads on the market, does not mean that you will make a ton of power. It does not work like that. When purchasing a H/C package, you want a setup that is: 1. Matched to each other's strong points 2. Compensates for the weak points 3. Best suited for the displacement of your motor 1. Matched to each other's strong points: Every head has its strong points and weak points. If you have a set of heads that flows particularly well on the intake side, then your cam selection should take that into account. If it has excellent port velocity, then your cam should again be geared to exploit that. For example, if your heads make the best flow at higher lift, then your cam should have the lift numbers to get it there. 2. Compensates for the weak points: Like the strong points, every set of heads have its weak points. It is my belief that the cam should compensate for the shortcomings in your heads (since cams cost less). For instance, if your heads do not flow as well on the exhaust side, you may want to consider a cam that has a longer exhaust duration, to allow more time for the waste gasses to escape. 3. is Best suited for the displacement of your motor: If you go out and purchase the biggest-port highest-flowing heads, and the most monstrous cam you can find, and slap it on your stock 346, what will you have? The baddest, fastest 346 this side of the Pecos, right, buddy? WRONG... you will have a over-priced, under-thought pile, that won't hold an idle, falls on its face, and never makes power in any usable power band. Good luck with that... What you want, is the highest-flowing smallest-port heads suited for your cubes, and a cam that makes the very most out of them. I will not get vendor-specific. The choice, in the end, is still yours. I would advise that you ask a ton of questions, to a ton of sponsors, and go with the one that has the best results on hand, is willing to be up front and answer your questions, and puts technical information in words you can understand and will help you match a cam for your needs. The subject of cams alone could fill this website to its brink. This is not a tell-all guide to buying a heads/cam setup; just some basic knowledge and tips that you should know before you drop $3000 on a H/C setup. C. Bolt-Ons Bolt ons are any part that assists in the making of power, that does not touch oil. It is common knowledge that they are the starting point in modding your car, so the fact that you should complete your bolt-ons should go without saying. Let's look at some of them and what they do. Lid: A lid replaces your stock lid, which was designed with comfort, not power, in mind. Simply put, an aftermarket lid does not have the restrictive air silencing fins and baffle found on the stocker. It allows more air in, and is a "must do first or second" mod. A lid is a lid, don't ask which one is best. Cold Air (Ram Air): The factory placement of the lid is poor for two reasons: the amount of space that air has to get into the lid is minimal; and placing it right on top of the radiator all but insures that you will have hot air entering your motor. A cold air (or ram air) kit fixes both of these problems. Either drawing cool air from under the car, or sealing your factory ram air to the cool outside air. Both methods ensure that enough air is getting in, and that the air that gets in is not hot. Headers: Headers replace your stock exhaust manifolds. They assist in the evacuation of spent gasses from your heads. They do this two ways: 1. first, they are free-flowing, which is to say they do not restrict exhaust flow in the slightest. 2. being free-flowing is not enough - GOOD header designs take it one step further by creating something know as the "scavenging effect"; that is, the flow of one header primary as it travels to the collector, creates a void or vacuum in the other primaries, effectively sucking out the exhaust as it is released from the head. I have always preferred "steeped" headers, for this very reason. Steeped header primaries get larger as you move away from the head's exhaust port. This greatly increases the scavenging effect, and increases your power potential. Underdrive Pulleys: Most commonly the crank pulley; it is simply a smaller pulley. 1. The rotational mass of the pulley is less, and therefore lighter and easier for your motor to turn. 2. It effectively reduces the amount of power required to turn the rest of the accessories, much like shifting to a lower gear. Electric Water Pump: Following hand in hand with the underdrive pulley, the electric waterpump gives the motor one less accessory it has to turn, thereby freeing up a few more HP. Although there is debate as to how much, no-one (who isn't a moron) disputes that it does free up at least SOME amount of HP. Manual Rack-And-Pinion Steering: Along the same lines, the MRAPS gets rid of yet another accessory, thereby freeing up power. It also weighs considerably less then the stock power steering system. Exhaust Systems: While there is A LOT of bullshit that flies around the Internet about "this exhaust sounds better then that one", this post is not for posers who want to whine about rasp. The very best-flowing exhaust there is, is a true dual X-pipe or H-pipe setup, with or without bullet mufflers. The next best thing is a cutout in the I-pipe. No cat-back out-flows a cutout; no Y-pipe setup out-flows true duals. Period. Intake and Throttle Body: I put these together because much like heads and cam, they should be matched. Again all bullshit aside, the best is the LSX 90mm intake and a 90mm throttle body. They are very expensive. A cost-effective second place is the LS6 intake and a ported stock TB. Either of these two choices are worth it, and have been dyno-proven time and again. D. Short Blocks When you're ready to play with the big dogs, it is time to refer to older wisdom: "There's no replacement for displacement." I will not speak to which vendor, or even which short block, is best. But there are a few staples that any good short block should have: 1. be completely balanced and blueprinted 2. forged internals 3. warranty on craftsmanship 1. it should be Completely Balanced and Blueprinted This means that every part of the rotating assembly has been weighed and made to be in perfect balance with like parts; for example, all pistons weigh exactly the same within a tolerance of +/- 1 gram. This ensures that the motor is not vibrating itself to death. A perfectly balanced motor will always make more power, all else being the same. Blueprinting means that every clearance and tolerance has been checked, rechecked, and documented for you on a build sheet. 2. it should have Forged Internals Getting a new short block is something you do not want to have to do twice. Forged internals will last longer, withstand more abuse, and support more power. Do it once, do it right. 3. it should have a Warranty on Craftsmanship This should not be a hard one to understand. If a company will not stand behind its product, then why would you?Do not be fooled by a vendor who says no-one gives a warranty on short blocks. Yes they do, and if that vendor will not, then find one who will. It should be noted on the side, that this does not, nor should it, apply to power-adder cars (nitrous, forced induction). Too many things can go wronge in a power-adder setup, to ever hold the motor totally responsible. Having a potent short block will most definitely make you the guy on your block to beat. Ensure that you have the short block built for your specific application. Most builders do not have cookie-cutter short blocks. They build yours for your goals. Are you looking to be a naturally-aspirated (N/A) monster? Then a 427 mill with high compression may be your best bet. Or are you looking to be king of boost? In that case, perhaps a bulletproof low-compression iron 408 would suit you best. Tell your builder what you want to do with the short block, and they can help guide you to the one best suited for you. F. Forced Induction Apology (no boost) I will go ahead and extend my apologies; I am not including Forced Induction in this write-up. I am not one to write about things I don't have clue one about. I do not know enough about boost to make an informed write-up on it. However, plans next year have me building a boost car for a friend. Perhaps after that I will add to this. So for now, that is all I am going to write on the subject of making more power in the LS1. Part II: Drivetrain Chances are that you will never have your 100 shot blow the welds on your intake. And even though you could not get your dream car (you know, the 10-second Jetta), chances are that if you applied some of the above "power section" to your car, that your car, much like a caterpillar in a cocoon, is going to blossom and do something wonderful for you the first time you hook all that new-found power to the track on a sticky tires.... It's going to break. That's right chucklehead, it's going puke out parts of its drivetrain like someone threw a grenade under your car. Congratulations, everyone in the stands are now pointing and laughing as the stock Honda Civic with a "Type R" badge that you lined up with, goes on to whip your V8 with a hella fast 15-second timeslip. Don't you feel like the MAN? Let's avoid this little mishap, shall we? In this next section, we are going to talk about your drivetrain: the parts that transfer your motor's power into foward motion. Since there are two types of drivetrains that come with LS1 F-bodies, we will talk about parts as they apply to each of these. A. Manual 6-Speed (M6) First, let me congratulate you on buying the stronger of the two stock transmissions. With minimal changes, this tranny in near-stock form has been deep into the tens. And in built form, it has propelled an F-body to mid-9-second glory. Now for the bad news. You also possess the single most part-destuctive force known to civilized man. FACT. M6 cars break more shit in the drivetrain then most A4 boys ever dream about. To avoid this (as best we can), we are going to talk about parts that are made ultra-tough, just to stand in defiance to this cruel tyrant called the M6 tranny. 1. Clutch It's time to man up and start giving your left leg a serious workout. Your stock clutch (yes, even if it's a Z06 one) is weak. It is the skinny guy on the beach that all the other clutches walk by and kick sand in the face of. It will NOT hold much more than stock HP, and it won't even hold stock HP for long on sticky tires. If your plans are to run 11s or faster, then you can forget those oh-so-cheap Stage 1 and Stage 2 clutches. I hate the term "stage" because people get wrapped around the word and forget to think about what they are really buying. So you wanna be fast? Well, you have two choices of clutches: Twin Disk A Twin Disk clutch is very strong; it will most definitely get you where you want to be. It will also do so while retaining a very comfortable pedal feel, and streetablility. Sound good? It is. However, as always, with the good news comes the bad. It is well over $1200 for a respectable twin. If you want that comfort, you've gotta pay for it. Sintered Iron Disk Wow, just saying its name makes it sound manly, doesn't it? That's because it is. It's a MAN's clutch. Little pansy boys, who like to complain about too much rasp or the clanks and rattles that solid end links make, need not apply. If you do not love the feel of a race car, then DO NOT buy this clutch! But, if you want a clutch that will kick your car in the ass and say "giddy the fuk up pony!", then this is the clutch for you. Your reward for having balls? How does paying $400 less grab ya? Yeah, that's what I thought. For information on how the clutch works, and the supporting hydraulics, please see my earlier write-up on this topic: The Clutch Prob Post 2. Driveshaft First things first, you need to say to yourself over and over and over again: "ALUMINUM IS FOR BEER CANS, NOT DRIVESHAFTS!!!" When it comes to driveshafts, I will stand on this statement every day and twice on Sunday. If your plans include a lot of power and sticky tires, then you have three choices for driveshafts. Steel Steel is real. Steel is strong. Steel is easy to balance. Steel is afforable. Can anyone guess what kind of driveshaft I have? Thats right, steel. Steel, however, is not perfect; it does have two troubles. 1. It is heavy -- against its lighter counterparts, it does produce slightly more parasitic loss. 2. In the rare occasion that they do break, they take a lot of stuff with them. Chromoly Chromoly... without going into a chemistry class, think of chromoly as having all the plusses of steel, and add to that it weights about 50% less. So why doesn't everyone have one? Price -- ah yes, the almighty dollar. These things are very pricey. Carbon Fiber All right! A real use for carbon fiber, other then making ricer hoods! Carbon fiber is light, very strong, and looks GREAT. One major asset that carbon fiber has that the other two do not, is that in the rare case that it does break, the fibers splinter and crack into what is best descibed as a broom. This means that as you are hitting the brakes and your broken driveshaft is still spinning, it is NOT hurting anything else. Hell, it might even clean off a thing or two. 3. Rear End Let's face facts. When the General was building the F-body, he put no thought whatsoever into the choice of the 10-bolt rear. This rear is not even strong enough to hold the stock HP, and is one of the first things to break when a new F-body racer heads to the track. In the case of the M6 tranny, please do not make a $2500 mistake. If you have spent a week on LS1tech, then you have heard the words "12-bolt" and "9-inch" when it comes to rears. If you have an M6, then I want you to forget the first of those. You are about to spend $2500 on a rear; do you really want to break it? 12-bolts are for automatic cars. They last a long time in an auto. But you own the sledgehammer of parts, the T56, breaker of rears. For you, there should be only one choice -- the mighty mighty 9-inch. Rear end parts... Now that you have chosen the correct rear, it's time to pick the parts you want in it. Most every place that sells these rears will give you these choices. Posi-Traction: The best choice for a car that will not see much track time but still wants a super-strong rear. Detroit Locker:The best choice for a car that will see a lot of both street and strip time. It is more noisy than the posi, but it is also stronger. Full Spool: So you got a RACE car, huh? Well, this is what you want. Full spool is the least street-friendly of the choices, but it is hands-down the strongest. Axles: The simplest way to approach axles is: the more splines, the better. Gears: This is mainly a matter of personal preference. 4.11s are perfectly streetable while also performing well at the track. Numerically higher gears lean more to track use; lower leans more to street cars. B. Automatic 4-Speed (A4) This may not apply to the 2010+ camaros. most are the same general principal when speaking of tq converters. Welcome to the wonderful world of the 4L60E transmission. Let me be the first to congratulate you on entering the world of the broken trans. The 4L60E is not the cruel tyrant on drivetrain parts that its M6 brother is. It is most definitely MUCH more parts-friendly. Too parts-friendly. So friendly, in fact, that it will break itself before it will break other parts. How noble... The problem is that it does this far too often, and even in full built form, this transmission is just NOT very good for real drag racing. Most in search of 10-second and quicker timeslips find that they are just not able to do it with the 4L60E tranny. They usually end up with a TH350, TH400, or 4L80 (the 4L80 being the only one of those which has overdrive). 1. Torque Converter Selection of your TC is very important. It has much to do with how quick you come off the line, and your 60-foot. The general rule of thumb is: a 3200-3500 stall for the LS1 street/strip car. If you are gearing your car more for drag-only, then 3600-4400 will be more your speed. Another important number you will see is STR. Without going into a math class, the STR of your TC is part of the torque multiplication that happens in your TC. The higher your STR, the harder your TC hits off the line. You wanna get that 60-foot down? Then get that STR up! 2. Rear End Since you have the more gentle of the two trannys, the 12-bolt is all you need. Simply apply the same principles as the M6ers do for their 9-inch selection. E. Fuel Systems We have talked a lot so far about air, so now let's turn our attention to the other half of combustion: FUEL. Having a fuel system that will support the motor that you are building is paramount. What good is having a motor capable of making 700 hp, but being limited to 500 because your fuel system will not support any more then that? It is very hard to go overboard when planning your fuel system. Because it is adjustable and PCM-controlled, having more then you need is not a bad thing. Once you know how much HP it will take to run the timeslip you want, then that day start putting together a fuel system that will support that amount of HP. As a general rule, you do not want your injector duty cycle to be over 80%. By the same rule, it is best that your fuel pump be able to handle 120% of the RWHP your motor is making. Add to that an adjustable fuel regulator, a fuel pressure gauge, and tuning to dial it all in, and your fueling department should be covered. A. Chassis Parts To keep your chassis happy at this power level, it still only takes a few pieces. Sub-Frame Connectors SFCs are nothing more then mild steel or chromoly bars that are welded to both your front and rear subframe. This will greatly minimize chassis flex, and will also assist in the lifting of the front when you launch. They really are one of the first five mods you should do. Roll Bar/Cage Under the incredible stress from a drag launch, a roll bar/cage will go one step further in adding to chassis strength. But that is not the reason you install it. You install it to save your life if something goes wrong at the track and you find yourself riding on your roof at 100 mph. Oh yeah, and it will help you avoid getting kicked off the track. If you run faster than 11.49 seconds, then you need a roll bar. Faster than 9.99, then you need a full cage. K-Member This part is not so much about strength as it is about losing the weight that your other chassis mods added. You want your car to be strong, but you also want it to be light. This part will more than make up for the extra weight. B. Suspension Parts (again may not apply to 2010+ camaros, Shocks/springs/sway section still applies) To keep your tires planted to the ground, you need to upgrade your suspension. Shocks Shocks control the up and down motion of both the front and back of your car. Ideally in a drag race, you want your front shocks to allow the front to rise very fast, but to come down slowly. Your rear should assist in transferring weight at first, and then push the rear end toward the ground as forward movement begins. You need adjustable shocks to do this. It would be better to have two-way adjustable shocks if you can. Springs Your front springs should be weight-specific. If your car is heavy, then you want a stronger front spring to assist in bringing the front of the car up. If your car is a tin can, then you can go lighter on the front springs. For a stock weight car, I would go with a 300lb front spring; for a really light car, 275lbs should be plenty. There is some debate over the rear springs. Many have gotten their best times on stock rear springs; others use what I use, V6 springs. Lower Control Arms LCAs are very important for several reasons. They control wheel hop -- the violent bouncing of your tires as they try to grab traction. And as weight transfers from the front to the back, the LCAs apply downward pressure to the axle housing, planting the tires and aiding in traction. Torque Arm The TQ arm does a few vital things for your whole setup. 1. It (along with the LCAs) is the pushing point for your rear end. 2. It acts as a ladder system to assist in weight transfer. 3. It can affect and change the pinion angle of the driveshaft as well. If you intend to race a lot, then you want a chassis-mount torque arm, not a tranny-mount torque arm. Rear Sway Bar As the power of your motor is translated through your drivetrain, it create a natural torque to one side; that is, the body tries to twist to one side. A drag solid-end-link rear sway bar, will combat this effect and assist you leaving the line straight and true. Pan-Hard Bar As power is sent violently to your rear, the rear end has a natural tendency to move side to side (known to some as the traction shimmy). Your pan-hard bar combats this. If you get an adjustable one, then you can also use it to center your rear end. |
05-14-2010, 08:56 AM | #147 |
05-14-2010, 09:28 AM | #148 | |
and MR. HYDE
Raven, This is an awesome write up and you seem to have alot of knowledge about this. I have a few questions on your post. In a couple of sections you indicate that GM's original parts are really not that good and don't hold up to even stock numbers, like tranny , rear etc..... Why is this? Why would they do that and still warranty for 100000 miles? When modifying, mine for example I am adding a cam, updated valvetrain, headers, highflow cats, cai and of course a tune, what is to be expected in reliablity, Camshaft Specs are: 227/239 .614/.624, supposedly a good street cam with moderate lope for the old muscle car sound. I was told would add around a 100 hp maybe a little less. For me HP is not as important as sound since this car is extremely fast for me to begin with, my daily driver is a crewcab 2500hd 4x4 diesel, so it is a big difference. I have seen from experience everything you talked about in your post, nephew has a Procharged 07 Mustang GT, first was motor, second was tranny, third was rear then driveshaft. He is currently pushing 850 to the rear wheels with some methane injection kit, too much for me. Since you are in the know so to speak. All that HP does not seem good especially when you cant put it to the pavement and when you do it breaks stuff. At C5F I believe I saw more tires spinning than anything. So for the guy like me who wants a little added power, mostly a sound upgrade for the lope, not going to race, maybe dust a few ricers off the redlight, or maybe some hot laps at the Talladega Superspeedway on open days, just to see what it will really do. What do you recommend? |
05-14-2010, 09:56 AM | #149 |
Drives: 2010 2SS RS Red Jewel Tint Join Date: Apr 2010
I just spoke with a service rep. I asked them that on a Camaro with a performance tune, would they leave the tune alone - not reflash it if I want them to perform the regular service work. He said that they would leave whatever tune I have alone. I'm scheduled for LT Headers and a tune within 3 weeks roughly depending on when the Kooks arrive. I was wondering is the answer I received reliable....did anyone else have that understanding with their service rep? I pretty much came clean...I told him that I would have one...warranty risks are on me, I accept that. I just won't have the IT items to change tunes back and forth for service work. Any thoughts appreciated. Thanks.
Kooks 1 7/8 LT Headers / K&N High Flow Intake / Magnaflow competitive X-pipe Cat-Back / Tune / 3M Clear Bra Protection
05-14-2010, 10:13 AM | #150 |
A dealer reflashed my car without saying anything when I had just headers. I was driving home and noticed skip shift was back on, and then got a CEL... they had reflashed it without even recording it on the service record.
05-14-2010, 10:33 AM | #151 |
Unbelievable. I'll make it clear to them not to mess with the tune. But that's no guarantee I know. Maybe I'll just let the performance service guys [non-GM] perform the service stuff I can't handle.
05-14-2010, 11:08 AM | #152 | |
To be honest. whether its for getting on it from time to time. or going to the track weekly, the first thing i always recommend is doing your suspension/gears (or a built rear) and some drag radials.... there is no point in have 380+ hp. without being able to put it to the ground. You guys are especially hurting for that with those big wheels and low profile tires. but of course. what comes with traction is breakage. thats where the comment of "GM's original parts are really not that good and don't hold up to even stock numbers" applies. I learned the hard way. I did my motor first back in the day. Heads/cam. Made 435 rwhp only ran 12.6's because i couldnt hook. when i did suspension and tires. i hooked..... and broke lots of rear ends and severals transmissions after i put in a 9" rear. It comes with the territory of learning the limits of the cars. but for someone like who who doesnt plan to race or just occasionally get on it. im sure you could get away with doing the cam first then move to your suspension. |
05-14-2010, 11:22 AM | #153 |
and MR. HYDE
Is there a difference in take off power and rolling power. Reason I ask is sometimes when cruising, I notice I can not suck up people like I thought I should, I guess from 35 to 65, you know these people they pull up beside you and want to race. I have tried not tried from a dead stop, guess worried about the tailshaft on the tranny breaking. Just was kind of curious, wouldn't want to embarrass myself, lol. I usually just let them go especially when the boys 11 and 13 are riding with me.
But like I stated earlier my mods are mostly for the sound and the added HP is just a bonus. I think I relayed that to the vendor I bought my stuff from enough that he knows what I want. I did ask about the heads to see if they needed any work while doing this and was told that basically with the mods I am doing that these heads flowed well and basically would be wasting money porting, polishing etc... I am sure GM did not squeeze every bit of power out of these motors coming from the factory, and that they are tuned for more reliability and dependabilty rather than performance and I am sure that the man doing the tune on my mods understands what I am going to do with it and will tune it more towards the middle than pushing the limits. I guess it's like they say "How fast can you AFFORD to go?" Last edited by Dr Jkel; 05-14-2010 at 11:38 AM. |
05-15-2010, 09:39 AM | #154 | |
as long as when you do this the clutch is already engaged you will be fine. (foot off the pedal, while in gear and already waiting at a desired RPM) unlike some people who like to push the clutch in and rev it to 6K and dump it @ 35 mph. reason being. when the clutch is engaged and its in the gear you want already, everything is already set in motion. when dumping the clutch all the parts are loose. so when you dump it. it smacks everything around resulting in immediate or eventual breakage (depends on mods, traction, driver) |
Similar Threads | ||||
Your Warranty Rights | The_Blur | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 75 | 10-19-2012 07:24 PM |
Started modifying my engine cover. | THUMPER20X | Cosmetics and Lighting Modification Discussions | 10 | 01-26-2010 07:11 PM |
Modifying the stock airbox. | Stevo | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 18 | 12-17-2009 07:54 PM |
Modifying the L99 | Evilangel | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 8 | 11-02-2008 03:13 PM |
Modifying YOUR Camaro | JustinZS | 5th Gen Camaro SS LS LT General Discussions | 243 | 03-18-2008 10:50 AM |
