TireRack
Old 05-12-2018, 02:58 PM   #1
13SSCamaro
13SSCamaro's Avatar
Drives: 2013 Camaro SS
Boost-A-Pump on stock SS Fuel pump to run E-85????
Anyone using just a Boost-A-Pump on a stock SS Fuel pump? I have the mods in my sig, and about to add the mods on the bottom line on my sig. I was told I should be able to get enough out of my stock fuel pump if I add a Boost-A-Pump. Is anyone able to confirm that or is anyone in here running one?
I am estimating power output to be around 525rwhp and 485rwtq
I already have bigger injectors and the flex sensor to install with the Heads and intake
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, ID850 injectors,ZL1 fuel pump, Flex sensor and E-85, Mantic 9000 and 1LE 3.91 diff 512rwhp/462rwtq
13SSCamaro is offline   Reply With Quote
Old 05-12-2018, 04:32 PM   #2
Bo White
Bo White's Avatar
I wouldnt run a bap on any application.
Totalled:
Old 05-12-2018, 06:01 PM   #3
13SSCamaro
13SSCamaro's Avatar
Any reason as to why not
Old 05-12-2018, 07:14 PM   #4
Bo White
Bo White's Avatar
Its a bandaid for an insuffecient fuel system. They are known to fail and most of the time when you find out its because you hurt an engine.
Totalled:
Old 05-12-2018, 08:06 PM   #5
13SSCamaro
13SSCamaro's Avatar
Im gonna keep looking at reviews but I cant imagine Kenne Bell and Lingenfelter backing something that is not good. I do not want to drop over $1,000 on upgrading the fuel system when i dont need too much more. Unless there is another fuel system upgrade I can do for under $500
Old 05-12-2018, 08:51 PM   #6
xc_SS/RS
Drives: 2010 Camaro SS/RS
ZL1 fuel pump is an inexpensive option but im not sure if it will be enough for e85 with your mods
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-12-2018, 09:01 PM   #7
alaskacamaro
alaskacamaro's Avatar
Drives: 2012 2SS 45TH Anniversary
I run E-85 with a ZL1 pump. After talking with Dxtuning I was told a ZL1 pump will be fine for n/a applications and E-85.
PFADT stage 3 suspension kit, SW LTH, SW cat less retro exhaust, MGW short throw, 3.91 gears, MRR Z28 wheels, Roto Fab CAI, SLP underpully, 255cc ported heads, TSP 229/236 Cam, ZL1 pump, Street Slayer Twin Carbon clutch, ID850 injectors, Snow Stage III Meth kit
480whp/460wtq tuned by Dynosty
alaskacamaro is offline   Reply With Quote
Old 05-12-2018, 09:19 PM   #8
13SSCamaro
13SSCamaro's Avatar
Don't you have to purchase a ZL1 FPCM as well to go with the ZL1 fuel pump?
Old 05-12-2018, 09:33 PM   #9
alaskacamaro
I didn’t. Just bought it from partstaxi and my tuner dropped the fuel tank to install it. From what I understand it drops right in where the SS pump was with zero mods. I’m sure the tune will adjust flow rate
Old 05-12-2018, 11:53 PM   #10
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
If you watch the classifieds every once on awhile a lpe or equivalent pump(cts-v twin pump) is listed, usually its someone upgrading to a bigger system
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 05-13-2018, 03:58 AM   #11
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Nothing wrong with BAP unless it’s improperly adjusted. If your going to go this route, at least use the ZL1 pump...
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
