04-16-2018, 02:14 PM | #1 |
Drives: 2017 Camaro 2SS Join Date: Sep 2017
Heat blowing out when climate control is off?
Lately I've been noticing that heat continues to blow out even when the climate control "power" button in the center is set to off. I usually leave the temperature dial set at 70 degrees and leave the buttons for where I want the heat coming out remain lit, so I have everything set how I want it when I press the "power" button back on. Am I missing something? Shouldn't that climate control power button override every other button that remains lit, or do I have to turn every button off?
04-16-2018, 02:16 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Apr 2017
Try pushing the re-circulation button. That's what works for me.
2016 2SS, MRC, NPP, A8. Procharger P-1X,Stage II,std bypass, 3.9, Alky Meth - 10.84 @129 - DA+2000
New Mods - GPI drop ins, Kooks 2", LT4 fueling, Cam, Circle D Converter, 3.5 pulley & dual nozzle meth. |
04-16-2018, 03:08 PM | #3 |
04-16-2018, 03:25 PM | #4 |
Drives: 2018 ZL1 A-10 Join Date: Jan 2017
I have noticed this as well. Let me know how pushing the re circulate button helps.
04-16-2018, 07:33 PM | #5 |
Drives: 2017 Camaro Join Date: Mar 2018
If you are moving and the recirculation button isn’t pressed then outside air is blowing over the heater core into the car depending on the last setting of the blend door actuator. This is completely normal and every car does this.
04-16-2018, 07:33 PM | #6 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
04-16-2018, 09:46 PM | #7 |
Drives: 2018 SS 1LE Join Date: Apr 2017
04-16-2018, 09:51 PM | #8 |
Drives: Tesla M3 LR-AWD [Former 1SS owner] Join Date: Jan 2018
04-17-2018, 10:33 AM | #9 |
So what is the point of the on/off button then?
04-17-2018, 10:48 AM | #10 |
You have the controls to shut down incoming air flow and a control to allow only ambient air temp, not heated or cooled . The system works just fine, not sure what you want the heating, ventilation, and cooling system to do ?
04-17-2018, 12:11 PM | #11 |
04-17-2018, 12:17 PM | #12 |
Drives: 2000 GMPPSV SS & 2017 ILE SS Join Date: Jul 2017
What about the rear defogger turning itself on automatically at times upon startup? Anyone ever have that issue?
04-17-2018, 12:29 PM | #13 |
Drives: 16' 2SS, 06' Silverado SS Join Date: Jul 2017
04-17-2018, 12:51 PM | #14 |
By making sure the blower fan is completely off and turning temp down to low setting , you shouldn't get anything thru the vents other than outside air temp. I agree that if you park a car with 195 degree water temp and out in the sun it will heat soak and upon start up you will feel heated air coming thru the vents until it exhausts that heated air. Make sure your recirc setting is set to recirculate outside air not inside the car air.
