Old 05-09-2017, 06:15 AM   #1
ShadowYYZ
Drives: 2014 Camaro 2LT Deep Magenta
Power steering groaning?
Whenever i turn slowly or back up slowly (v6 14 camaro 2LT Manual ) I hear like a electronic/groan/moan coming from the front. Even sometimes just sitting idle, i can slightly hear it.. Just like a slight constant noise.
my steering wheel sounds like a zipper/squeel during slow speed turning.
Any thoughts what this could be?
ShadowYYZ is offline   Reply With Quote
Old 05-09-2017, 07:00 AM   #2
ShadowYYZ
From another member, never got a reply. Same noise when idle, i feel that noise directly from power steering.. It makes that groan/eletronic noise...
Old 05-09-2017, 07:34 AM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
You won't see any leaks as you have electronic power steering.
Soprano 4/1/00-6/14/11, Gone but NEVER forgotten!
FSP tuned: 377/389
nyrfan is offline   Reply With Quote
Old 05-09-2017, 07:52 AM   #4
ShadowYYZ
I don't think it is electronic, thought the SS are though.
Old 05-09-2017, 08:36 AM   #5
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Sounds like a bad steering rack. My electric steering is silent.
TheFlyingBananaSS is offline   Reply With Quote
Old 05-09-2017, 08:50 AM   #6
ShadowYYZ
I thought so, I let the service advisor know about it last time i was in. (2x visit ) . They stated "lubed up parts" yet, noise is still there...
Also, they replaced an oil adapter gasket thingy that was dripping near the steering rack... cause it to look damp....
Old 05-09-2017, 09:09 AM   #7
styx84
styx84's Avatar
Drives: 2014 Camaro 1LS
V6 Camaro's most definitely have regular old hydraulic power steering. NOT electronic like the V8's have.
Here is a picture showing where the power steering pump is on the LFX.
It's under the plastic engine cover on the drivers side front.
https://cimg0.ibsrv.net/cimg/www.ls1...er3-141576.jpg
styx84 is offline   Reply With Quote
Old 05-09-2017, 11:07 AM   #8
ShadowYYZ
Thanks for the info.. So, any thoughts what it could be :/.
Old 05-09-2017, 11:18 AM   #9
styx84
styx84's Avatar
First thing I'd check is the level and condition of the power steering fluid.
Old 05-09-2017, 11:53 AM   #10
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
I would start with a good ol' fashioned bleed... really pretty easy, not a messy task. In short, you'll jack up the front end of the car, and place in it jack stands. Then, slowly turn the wheel lock to lock, slowly, a number of times (20? 50?) with the vehicle off. Then, do the same with the vehicle running. This should clear out any air bubbles that might be in your system, possibly creating the noise you are getting.
I recommend YouTubing the bleed process, where you'll get better info than my vague memory of how to do it...
Scalded Dog is offline   Reply With Quote
Old 05-09-2017, 06:26 PM   #11
ShadowYYZ
So, I called the service manager and stated to go in tommorow. Drive around to replicate the issues, i hope this will grab the attention surely. After going back 3 times over the same issue. I feel embarrassed, never was assertive person.
Old 05-09-2017, 07:28 PM   #12
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Nothing at all to be embarrassed about man. This is their failure, not yours.
Just keep in mind certain people will detect that you are a bit passive and prey on that, taking advantage of you in the process.
Especially when it has to do with money, such as a dealer service bay.
InFiD3ViL is online now   Reply With Quote
Old 05-10-2017, 09:36 AM   #13
christianchevell
old school chevy rodder
christianchevell's Avatar
That Zipper sound and that Squeal are a sure sign your too lonely in Oklahoma......and some local Yocal is there in his big rubber boots watchin.....
ROFL I just had too I cant resist....
That may be belts slip also...... check the belt and the thing should be dry clean/unfreyed and you can get a can of belt dressing if needed. If air in the system it takes time to work out....
Old 05-10-2017, 10:08 AM   #14
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Ask the dealership to change out your PS fluid and replace it with the latest greatest automatic transmission Dexos.
