06-11-2016, 08:45 PM | #1 |
Drives: 2015 camaro ss Join Date: Jun 2016
remove the paddles. put them on the floor
i can make a shifter that puts the paddles on the floor. the first stick is for PRNDM. the second stick is for upshifts . and the last stick is for downshifts.
06-11-2016, 08:51 PM | #2 |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
Dam!!! Look at that!!
06-11-2016, 09:21 PM | #3 | |
check it out
06-11-2016, 09:52 PM | #4 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
This is actually pretty cool!
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
06-11-2016, 10:04 PM | #5 |
Drives: '23 LT1 A10 Join Date: Oct 2015
Omg
24 LT1 M6 Sharkskin Metallic
06-11-2016, 10:43 PM | #6 |
Drives: 2011 ss Join Date: Sep 2015
Interesting...
06-11-2016, 11:25 PM | #7 |
I have one stick that does all of that.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
06-12-2016, 12:53 AM | #8 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Really? Lightning Rods?
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
06-12-2016, 01:24 AM | #9 |
Drives: 2016 Camaro White 1LT Join Date: Apr 2016
Awesome.
06-12-2016, 02:46 AM | #10 |
More then meets the eye!
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
06-12-2016, 07:32 AM | #11 |
waiting at the tree
Very cool.
Congrats on a very unique mod,maybe you can sell the idea to Hurst and make some money
2010 2SS/RS A6 ZL1 Rims
06-14-2016, 08:35 AM | #12 |
Drives: 2017 HBM A10 ZL1 Join Date: Feb 2011
Very cool takeoff on lightning rods.
My build thread http://www.camaro5.com/forums/showthread.php?t=224342
Go is good. Stop is better. |
06-15-2016, 01:25 AM | #13 |
Drives: T Join Date: Mar 2015
looks cool, hahaha. Wish the l99 came with more center console shifter options
06-15-2016, 01:43 AM | #14 |
Drives: 2011 2SS Join Date: Aug 2014
Wtf, wouldn't it have been easier learning manual.
