06-05-2021, 05:52 PM | #1 |
TWG1
Drives: 2019 Camaro ZLE Join Date: Nov 2019
High Oil Pressure (15w50, On Track): 85+ PSI
Was at NOLA yesterday and on front straight noticed that Oil Pressure would peg in the red (high) on front straight, and later refined it to any revs over ~6k. I was able to avoid it by short-shifting rest of the day.
Specifics: 2019 ZLE, M6, all stock, ~3300 miles. Fresh 15w50, 10qts, PF-64 filter. 5th Track day with this car, reviewed data through Cosworth: Sebring JAN: High oil PSI's were 80.6, 82.4, 85.9 Barber FEB: 84.1, 77.7, 76 NOLA (yesterday): 89.3, 85.3, 83.5 Reading other threads, some say this is an indicator of pending oil pump failure. Seems rare for a 2019 MY, and I would have thought it would have failed by now, with (5) track days with this condition. My last ZL1 A10 (running 0W40) seemed to run 50-60 on track. Can anyone share data as to whether this is a 'track only or 15w50 oil condition, or otherwise? Thanks in advance - TWG1
2019 ZLE M6
2019 ZL1 A10 (Sold) 1967 Jaguar XKE Series 1 Roadster 2021 F150 Powerboost (on order) |
06-05-2021, 06:32 PM | #2 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Not sure why GM recommends 15W-50 for track. My brother used to work for GM Advanced Vehicle Engineering Lubricants Division and always told me 10W-40 is more than enough for track use, where some viscosity loss can be expected. Hot viscosity is about 60% higher than 5W-30 https://www.mobil.com/en/lubricants/...obil-1-15w-50/
06-05-2021, 08:37 PM | #3 | ||
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
The tech said this is how the oil pumps are supposed to work and had a document from GM that showed the acceptable ranges. Here's my thread: https://www.camaro6.com/forums/showthread.php?t=546288 Quote:
They recommend it because of the G force the ZL1 1LE can sustain. If it had an dry pump system then it wouldn't need it. Don't know why they didn't go with that just for the 1LE. |
06-05-2021, 09:35 PM | #4 | |
TWG1
I assume your LT4 is: A) Still pegging 80 B) Still alive w/o any other issues since you posted in 2019?
2019 ZLE M6
06-05-2021, 11:12 PM | #5 | |
15w-50 is way too thick (reminds me of BMWs bonehead call for 10W-60 and the many E9x M3 bearing failures that resulted). They are trying to anticipate viscosity loss for track use but most people change their oil every track event anyway. |
06-05-2021, 11:25 PM | #6 | |
https://www.corvette7.com/forums/sho...d.php?t=535476 Oh GT3? They have a dry sump setup yes? OK. No comparison. Factory fill on the ZL1 and 1LE is 0w40 too...... Last edited by Vigilante375; 06-05-2021 at 11:37 PM. |
06-05-2021, 11:31 PM | #7 | |
It still hits the 80s when WOT and idles just under 30. All while being in the great GA heat. I think the main culprit to identify a "bad" oil pump is the idle PSI dropping to the low 20s. A recent thread was just made on that and I think that's what most users agreed with. |
06-06-2021, 10:10 AM | #8 |
Drives: 1985 Z28 Join Date: Aug 2020
Some folks like 15w40 or 5w40 synthetic diesel oils with high Zinc content like Mobil 1 Turbo Diesel.
I agree there’s no need for 15w50 Mobil 1 if you can use a lighter weight oil. Last edited by Dave777; 06-06-2021 at 10:39 AM. |
06-06-2021, 10:46 AM | #9 | |
Drives: 2018 ZL1 1LE Join Date: May 2019
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial Will buy your GoodYear Supercar 3R Take offs! |
06-07-2021, 11:38 AM | #10 | |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
06-07-2021, 09:09 PM | #11 | |
TWG1
2019 ZLE M6
06-24-2021, 09:46 PM | #12 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
I see high 70s on the track. Make sure you warm up the engine and oil. Do not run the engine at high revs until the oil is 200F.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
06-24-2021, 09:53 PM | #13 | |
Its just going to do this with 15/50 its just heavy oil. Esp when its fresh new oil too.
928rwhp - 93 | 1040rwhp/898rwrq - E65 SAE
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
06-25-2021, 09:20 AM | #14 | |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
Our 15w50 is not too thick for the track, at 250 F+ temps I'm glad it's in there and wouldn't use anything else. Porsche is a different design, requiring a different oil. |
high pressure, oil pump, track |
