07-29-2014, 04:23 PM | #1 |
DiabloZL1
ZL1 Info on first upgrades
So my fellow ZL1 owners I have a CAI, 2.55 upper, larger idler with HD Belt, cutouts, and a tune. Running 14PSI now.
I am having a hesitation issue under full load above 3500 to 3800 starting in 3rd all the way up my rpm band until I change gears then it starts all over in the next gear past 3800. Any ideas on causes? I've read everything from needing injectors already up to faulty MAF sensors. My last dyno tune I was at 555rwhp/549rwtq. Anybody run into the same issue so soon in a build? |
07-29-2014, 04:31 PM | #2 |
Have you tried cleaning your MAF sensor?
07-29-2014, 04:37 PM | #3 |
DiabloZL1
07-29-2014, 06:27 PM | #4 |
Drives: 2013 ZL1 Join Date: Mar 2013
It does sound like you need injectors.I think you have maxed them out with the horsepower you have.That would be the first thing I would do.You might want to take it to a tuner somewhere and they will be able to tell you what is going on.
07-29-2014, 06:41 PM | #5 |
DiabloZL1
Yes my tuner said I need more fuel...so injectors then pump but I don't see that is necessary when hennesey, livernoius, ligenfelter are not doing fuel upgrades until 650 700 hp range. Makes me think he is not tuning my car correctly. Also seen speed density tuning forum talk about fixing this issue. Just wanted to find out what everyone thought...
07-29-2014, 08:42 PM | #6 |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
Try re gaping the spark plugs a little smaller and see how that goes. My last boosted car did that. Smaller gap in the spark plugs fixed it. Like .02-.05 smaller. Good luck!
07-29-2014, 09:32 PM | #7 |
DiabloZL1
I have my plugs at .034 right now. Put in TR6IX about a week ago. Is that small enough gap?
07-29-2014, 09:46 PM | #8 | |
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
Did the tuner tell you what your injector duty cycle was? Anything over 90% and you should get new injectors. Also, did they mention if your fuel pressure was dropping off? Fuel pressure dropping will also cause your injector duty cycle to go up. You should worry about stable fuel flow and pressure first. If you have that and you are still over 90% IDC then you need larger injectors.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
07-29-2014, 09:49 PM | #9 |
DiabloZL1
Ok will do. Thanks
07-29-2014, 11:46 PM | #10 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
You MAY need bigger injectors, BUT that wouldn't cause your symptoms. Look at the tune. Who tuned it? Probably you are feeling knock retard or burst knock kicking in. Or they pulled so much timing out you're feeling that hesitation. At 14 psi boost, your power is down from what I'd expect also.
Bryan 2018 ZL1 M6
07-30-2014, 12:42 AM | #11 | |
DiabloZL1
08-02-2014, 09:20 PM | #12 |
Drives: 2014 ZL1 M6 Join Date: Jul 2014
update?
tony
2014 ZL1 M6
Bone stock, for now! 2001 Z28 M6 !cags, !air, FTP 85mm Lid, Z06 85mm MAF, P&P TB !4x4, Strano Springs, Strano Sways, Koni 4/4s, Watts Link ARH LTs, ARH catted Y, SLP catback with Dual/Dual Muffler, SLP CME and Valance OE Wheels Machined Face C5 DDs, 18x10.5s, with 295/35-18s on all 4 corners! 352rwhp and 366rwtq |
08-02-2014, 09:45 PM | #13 |
DiabloZL1
Going a different route. Working with Mike over at vengeance racing to run a different tune. Buying an EFI live V2 tool so I can flash my own tunes he sends me. I'll go from their and post if it was my previous Crappy tuner guy or I really do need different fuel delivery setup.
08-02-2014, 10:06 PM | #14 |
Going for Plaid
Good choice. A tuner not wanting to say what your injector duty cycles was is complete BS. Having EFI Live or HPT will allow you to have a daily driver tune and a race fuel tune if you so desire.
