BeckyD @ James Martin Chevy
Old 04-03-2024, 01:23 PM   #1
Badmojo
aka BeastZL1
Badmojo's Avatar
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra
Camaro ZL1 1LE Aftermarket Front Rotor Weights
Camaro ZL1 1LE front 390mm rotor weight comparison. I will put out a video next week on the Racing for ALS Youtube. I'm going to DBA for this season, but was surprised that they are heavier than the factory rotors. Rotor thickness was 35.8 to 36 mm for all three disc.
Edit: Added Video
Edit: Added Pricing
Fronts
Griodisc with Hats $1200 - KNS Brakes
Girodisc Rings with Hardware $850 - KNS Brakes
Factory GM complete $826 -RockAuto.com
DBA Rings with Hardware Kit (reuse OEM hats) $740 - KNS Brakes
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Last edited by Badmojo; 04-06-2024 at 12:23 PM. Reason: added video and price info
Badmojo is offline   Reply With Quote
Old 04-03-2024, 03:51 PM   #2
Badmojo
aka BeastZL1
Badmojo's Avatar
Some additional info:
  1. The rotors all have the same approximate thickness (flat to flat).
  2. The Girodisc has a 235 mm diameter center hat. The stock and DBA are 215 mm in diameter. The Girodisc requires a smaller pad since the pad-to-rotor contact area shrinks from ~80 mm to ~65mm.
  3. The Girodisc rotor "face" thickness is approximately 1.5 mm thinner per side.
  4. The DBA rotor has thicker vanes than the factory rotor and similar dimensions.
2019 Camaro ZL1 1LE
Old 04-03-2024, 05:25 PM   #3
That1guy_tim
That1guy_tim's Avatar
Drives: Camaro 1ss
are the DBA's cheaper than factory?
That1guy_tim is offline   Reply With Quote
Old 04-03-2024, 06:38 PM   #4
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
The Giros are a bigger upgrade than just the weight advantage. Brake feel is better and stopping power is better. I’ve had them on 4 cars and every single one has been an improvement.
Ken.
khcoaching is offline   Reply With Quote
Old 04-03-2024, 09:07 PM   #5
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Unsprung weight is a big deal, multiplier affect. I wouldn't write it off.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 04-03-2024, 09:08 PM   #6
Badmojo
aka BeastZL1
Badmojo's Avatar
Ken.
Ken,
How do you explain the brake feel and stopping power advantage? Did you have different pads or brake fluid?
I'm curious.
2019 Camaro ZL1 1LE
Old 04-03-2024, 09:10 PM   #7
Badmojo
aka BeastZL1
Badmojo's Avatar
A set of DBA rings and hardware kit is about $50 cheaper than factory full replacements at this point in time.
2019 Camaro ZL1 1LE
Old 04-03-2024, 09:30 PM   #8
GunMetalGrey
GunMetalGrey's Avatar
Drives: Track prepped 2018 Camaro ZL1 (a10)
I’m not sure why nobody ever lists the Racing Brake ZL1/ZLE OEM sized rotor as an option, it has veined cooling like the Gyro disk, but is larger to better handle the heavier weight and faster speeds of our supercharged cars
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 04-04-2024, 09:45 AM   #9
Checkmate1
Drives: Garnet Red / ZL1 1LE
Please also post the price for each rotor as well considering us track rats consider these consumables. Price to Value is an absolute consideration.
#SAVETHEMANUALS
Checkmate1 is offline   Reply With Quote
Old 04-04-2024, 11:21 AM   #10
Badmojo
aka BeastZL1
Badmojo's Avatar
Fronts
2019 Camaro ZL1 1LE
Old 04-04-2024, 11:44 AM   #11
khcoaching
khcoaching's Avatar
Originally Posted by Badmojo View Post
Ken,
I'm curious.
Great question. Basically the pedal felt firmer and my foot had more "feel" in the top of the pedal stroke, just more connected to the front tires. As far as power, there is more stopping response in the 30-70% brake range. Same results with both Ferodo 3.12s and Cobalt X1s.
Same with my son's GTI and Elantra N.
I used GM DOT 4 on both my Camaros and never an issue.
Ken
Old 04-04-2024, 10:44 PM   #12
NG329
Drives: Chevrolet Camaro ZL1 1LE
Ken
I wouldn't exactly say that it's "Better" coach. I think it comes down to personal preference. What you're describing is initial bite. Whereas others, may prefer a more progressive feel.
When I tracked motorcycles I preferred immediate lever feel, similar to what you're describing. However, in the car, I actually prefer OEM. I like that the initial bite is less potent as it helps stop me from overbraking and i can trail it to the apex without locking things up.
At my pace (FukkenFast), I honestly don't see Girodisc cutting any more time from my laps. In fact, I should probably be braking less.
Obviously, you're very knowledgable and I respect the hell out of you. However, I just can't wrap my head around anyone wanting to change out the OEM ZL1-1LE brakes (aside from the fluid) unless they're racing at Pro level for hour-long races.
NG329 is offline   Reply With Quote
Old 04-05-2024, 12:13 AM   #13
khcoaching
khcoaching's Avatar
Totally fair and your perspective is great. My perspective is having a car I can take anywhere and have it perform to the level I want, regardless of the track. Having driven stock ZLEs at pace, the stock pads simply don't cut it at hard braking tracks. EX - At Nelson Ledges, the brakes are barely used and stock pads would probably be fine, at The Ridge or say PITT, there is a lot of brake used and stock pads would not perform as well. I, as a driver, want to be able to adjust my braking to any track in any conditions and the Giro setup is just that much better for me with its enhanced feel and power.
Ken
Old 04-05-2024, 05:02 AM   #14
BoilerUP
BoilerUP's Avatar
Drives: Cadillac ATS-V
370mm DBA front rotor rings for the SS 1LE are $290 each right know through KNS, with hardware priced at $41 per side. Kinda hard to beat that for consumable costs.
2018 Cadillac ATS-V Sedan
NCM*Putnam Park*Mid-Ohio*Gingerman*Road Atlanta*Barber
BoilerUP is offline   Reply With Quote
