02-21-2015, 08:24 PM | #1 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
another lsa build
its been a while since I've posted much of anything! Went a completely different route with the car
So here goes! Parts list Adm lsa conversion kit 2.50 upper pulley btr stage 3 pd cam rotofab cai 2 inch headers gmpp ported ls3s d3 heat exchanger and reservoir circle d 2c 258mm converter (this is what I was specd) 4l80 trans with transbrake zl1 rear with 3.73s zl1 pump, adm fpcm, bap fic 1000cc injectors bo white ported tb Hoping to make around 625whp. Feel free to criticize as necessary. I've already purchased most of it though! I'm staying on strictly pump gas for now! Eventually I'll add water/meth and switch to a 8 or 10 rib setup. Edit: thought I'd add that the current numbers through a m6/zl1 diff are 472/439.
02-21-2015, 09:02 PM | #2 |
Adm intake w scoop. Looks great installed. But you have made a good choice going lsa. I love mine.
02-21-2015, 09:10 PM | #3 |
I have a scoop already! But I agree! Those intakes look amazing. I just couldn't find their race intake listed anywhere. Which is why I bought a rotofab. I don't see it affecting numbers though!
02-21-2015, 09:40 PM | #4 |
Drives: 2016 2SS Camaro Join Date: Apr 2014
I'm considering doing a lsa conversion as well sounds like it's going to be a beast once it's done and it should easily make those numbers. Do you happen to have a printout of all the parts that come with that adm kit? I work at a gm dealer and I plan on buying everything individually and it would be great knowing what all is needed and perhaps part numbers.
02-21-2015, 09:54 PM | #5 |
Drives: 2017 zl1. Headers intake pulley e Join Date: Oct 2014
Didn't even do that much to my lsa!
02-21-2015, 11:05 PM | #6 |
Me either lol. Here is the Adm lsa swap #1. This is a great blower kit for anyone wanting to get into a supercharger and have a factory fit and finish. And there is nobody that can beat the price either. This is my 417 m6 10 psi boost.
02-21-2015, 11:08 PM | #7 |
Most people dont realize the mass air sensor is relocated inside the intake away from the engine heat and reads the intake air better. That is what makes it that much better. But yours will do just fine.
02-21-2015, 11:13 PM | #8 |
'It's an experiment'
The LSA is the way to go -- its an amazing kit and if you get the pulley and setup you have, you'll get there.
If I get the pulley upgrade, I'll be there with mine -- its all about what you want and plan for it -- I kick myself for not getting the pulley when I could have... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
02-21-2015, 11:16 PM | #9 |
Good to know! And thanks guys. Im hoping it does well!
02-25-2015, 09:21 PM | #10 |
Blower kit arrived today! Stock Pulley came right off with a 2 jaw balancer puller. Pulled the snout off and it already had the solid isolator in it. Just waiting on the 2 50 upper so I can assemble the blower and start the install.
I have the motor tore down! Waiting on replacement cam from btr. They sent me a comp core instead of the cam motion. this cam will be replacing a btr stage 4 n/a cam. Last picture was just seeing how it would look. This thing is tall!!!
02-25-2015, 09:30 PM | #11 |
Awesome. Are you having the new pulley pressed on?
-Don
747 RWHP 794 RWTQ
02-25-2015, 09:32 PM | #12 |
I'm going to attempt it in my little 12 ton press. If not a trip to the local machine shop will be in order!
02-25-2015, 09:55 PM | #13 |
I heard a 20 ton may be in order ;o)...
Can't wait to see how it comes out! -Don
747 RWHP 794 RWTQ
02-25-2015, 10:21 PM | #14 |
Looking good. You will love it. Btw the driveshaft i bought from ya fits perfect.
