Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 05-21-2013, 09:17 PM   #1
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
My Dirty, Dirty Intake (Pic Heavy)
UPDATED 06/22/2013: See the bottom of this post.
So, I bought my car used with ~26,000 miles on it a couple of months ago. Since then, I've put about 3000 miles on it. I just recently installed an RX catch can and breather, so the car went about 28,375 miles without one.
As an aside: Big shout out to Tracy/SC2150 from RevXtreme. I bought my cc/breather used from a C5 member. It came with an older bracket that was first used on the LLTs, and didn't fit my LFX application. Tracy sent me a new bracket, free of charge, and took the time to give me some advice on cleaning the used items prior to install. He did all this for a customer that wasn't even buying from him, and from whom he didn't make a dime. Many thanks!!
OK, back to my dirty story.
Before installing my catch can and breather, I pulled my intake air tube and throttle body off to try to snake a cheap borescope I bought into the IM and hopefully get a look at my intake valves without pulling the whole manifold off. I wasn't able to get the scope to twist into the intake runners and see the valves, but I did find oil in my intake tube (coming from the "clean side" connection), and some oil in the reservoir that's molded into the IM right behind the throttle body:
You can see in the second pic above how the inside of the IM is coated with a shiny film of oil. The borescope also showed congealed globs of oily gunk in the manifold, too. Yuck.
I also found my throttle body to be dirty, too:
So after that I installed the CC/breather, and yesterday I followed Intensifi's excellent DIY on pulling the IM for cleaning, and pulled off my TB and IM to finally clean them and get a good look at how dirty and carboned up the intake valves have become, and here's what I saw:
Dirty throttle body (still, never cleaned it):
Oily underside of IM:
Oily/gritty intake runner openings:
And, finally, my intake valves:
Except for that one cylinder, they're not horrible...but that one is pretty dang bad.
So, my plan is an experiment. I have been doing some data logging of my "dirty" engine, and now I've confirmed just how dirty it really is. Step 2 will be to do a Seafoam treatment of the engine. Then I plan to pull the IM again and see just how effective it was at cleaning the valves. If it's still dirty, I will do the manual cleaning as described in Intensifi's DIY, then do some follow-up data logging and see if there are any significant changes.
UPDATE #1: Did a Seafoam treatment, described in this post.
UPDATE #2: Rechecked the intake/valves after Seafoam, and manually cleaned them. See this post.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 05-21-2013, 09:24 PM   #2
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
2010SLVRBULIT is offline   Reply With Quote
Old 05-21-2013, 09:50 PM   #3
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Please post with results this may be possible "sticky" potential imo
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 05-21-2013, 09:55 PM   #4
911medic
911medic's Avatar
Will do. You'll have to be patient, though, as my spare time to work on this stuff is very limited, especially this time of year with three boys playing baseball at the same time (in different locations).
Old 05-21-2013, 10:32 PM   #5
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
And this is why boys and girls you need a catch can!
Mods:
Old 05-21-2013, 10:54 PM   #6
911medic
911medic's Avatar
Old 05-21-2013, 11:47 PM   #7
intensifi
Drives: '12 2LT Convertible
Welcome to the "dark" side.
You'll have it all "clean" in no time!
P.S. thanks for the kind words!
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 05-21-2013, 11:53 PM   #8
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Just wow!
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 05-22-2013, 05:33 AM   #9
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
This is going to be good.
Exactly.
Old 05-22-2013, 02:07 PM   #10
LS1346CID
Enjoying the lil things
LS1346CID's Avatar
Drives: 2012 Camaro RS Loaded - Lil Red
Wow.... that is alot of crap on that one valve!!!
It's all stock!
With the exception of : BrakePerformance slotted and drilled rotors, K&N filter, other misc bolt on's, Tint, Clear Bra, WhiteOut emblems, Painted Calipers
LS1346CID is offline   Reply With Quote
Old 05-22-2013, 03:19 PM   #11
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Best Emoticon ever!!!! Beats the heck out of this little guy:
Old 06-05-2013, 10:21 PM   #12
ICTsccaCamaro
ITCRNRS
june update for us?
Old 06-06-2013, 11:11 AM   #13
911medic
911medic's Avatar
Sorry, haven't had time to seafoam/pull it apart again. Maybe in a week or so. Super busy with work/family/projects.
It's still in the works, though. Haven't forgotten about it.
Old 06-06-2013, 04:36 PM   #14
ASH@IPF-TUNING
ASH@IPF-TUNING's Avatar
Drives: 4x4 Turbo
Hello !
that carbon suit is NOT coming completely from the burned OIL ... ALL DFI engines have that Problem !
1) from the EVAP System there is always a Little bit of oil and condensate transfered into the engines combustion area .... BUT the intake valves were the cold parts of the engines valvetrain so the oil and condensate CAN PHYSICLY NEVER burn to ashes at the cold intake valves ! !
2) the DFI process is creating lots of carbon suit during the combustion and during the nessesary valve overlap .. were INTAKE and EXHAUST valves BOTH open and covered with the carbon suit ... BUT the exhaust valves get HOT enough to burn the carbon suit ... so at all DFI engines you see dirty intake valves and not so dirty exhaust valves !
3) all old style intake manifold injection engines clean the INTAKE valves automaticly by the fuel spray into the cylinder ... old Technology .. but cleaner Intake valves !
Good examples you find around the world in all Forums about DFI engines ... here a 98kmiles driven Golf TFSI :
http://i483.photobucket.com/albums/r...valvedirt3.jpg
and Porsche Cayenne DFI V8
http://i46.photobucket.com/albums/f1...offman_001.jpg
http://i46.photobucket.com/albums/f1...offman_003.jpg
So Google yourself and you will find many examples from ALL worldwide DFI engine manifactures !
Greets ASH@IPF-TUNING
ASH@IPF-TUNING is offline   Reply With Quote
