dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 06-22-2013, 04:09 PM   #71
911medic
911medic's Avatar
Drives: 2012 SIM 2LT/1970 Camaro
One more note on the Seafoam treatment process. Intensifi mentioned to me that the dealer intake chemical cleaning apparatus hooked up to the PCV intake port on the IM.
I tried to use this port to spray some Seafoam into the IM after the manual cleaning/reassembly, but the engine does not like the unrestricted airflow that came in through that port without the PCV line connected. It chugged and died almost instantly when the PCV line was removed, and would hardly restart, so the attempt was aborted.
Obviously the dealer system seals the opening better and only allows an appropriate amount of air to enter with the chemical.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller
RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting
Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting
911medic is offline   Reply With Quote
Old 06-22-2013, 07:09 PM   #72
intensifi
Drives: '12 2LT Convertible
Great write up! Thanks for all the effort!
The difference between yours with 28K (Before Catch Can) miles and mine with 14K (BCC) miles, really shows the need for getting the catch can on early.
The next time I have my manifold off, I'm going to try throttle body cleaner on the closed valves.
I'll also check with the master tech at Boardwalk Chevrolet on the difference between Seafoam and BG 44K. As I recall he felt BG 44K cleaned better.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 06-22-2013, 08:08 PM   #73
CyberPunk223
Drives: 2012 LS Camaro
you all are nuts,,
don't get me wrong, I put a RX on mine at 7,000 miles and did a aerosol seafoam treatment into the TB, for $150 what the hell,
But lets go back to the drawing board here,, now what harm does having deposits on your valves do?? As long as the valve seats keep themselves clean what's the difference?
It will be interesting to see if people without the catch cans have problems down the road... What are your predictions?
CyberPunk223 is offline   Reply With Quote
Old 06-22-2013, 10:51 PM   #74
intensifi
Carbon builds up on valves.
Eventually it will break loose, fall off into the cylinders, then score the cylinder walls and damage the rings.
Old 06-23-2013, 01:20 AM   #75
911medic
911medic's Avatar
Originally Posted by CyberPunk223 View Post
you all are nuts,,
So I'm nuts for documenting the same process you used (catch can, Seafoam treatment) and taking it a step further and actually physically cleaning the valves?
And you feel the shape of the valve surface itself has no effect on the flow into the cylinder, so crusty, rough carbon buildup will have no effect, right?
That's why BMW came up with the walnut shell blaster for cleaning the valves on their direct injection engines, right? Just for fun.
Sorry if I'm a little sensitive, but your post makes no sense. You call me crazy, then say you've done 2/3 of what I've done, then ask my predictions?
That's crazy.
Here's an article from a couple of years ago: http://www.edmunds.com/autoobserver-...-adopters.html
In it you'll find a description of one owner's decreasing horsepower as his valves collected carbon deposits.
And here's a quote from that article that should show you the potential "harm" that auto manufacturers themselves are concerned about:
"A U.S. patent application filed in 2002 by Volkswagen AG explains the DI-engine carbon-deposit dilemma this way: 'Gasoline engines with direct injection of the fuel into the combustion chamber…suffer especially from the problem of the formation of carbon deposits…especially in the neck region of the intake valves.'
The document describes these deposits as a sticky coating of oil and fuel constituents that, once formed, serves as a base for further deposits, creating 'a circular process, by which the coating thickness of the carbon deposits continuously increases.' Excessive carbon deposits 'have extremely negative effects,' the patent application concludes, citing significant performance losses, sporadic ignition failures and, potentially, holes burned in the structure of the catalytic converter (should bits of carbon break from the valves and pass though the combustion chamber)."
Hmm. Yeah, I'm crazy.
Old 06-23-2013, 01:28 AM   #76
911medic
911medic's Avatar
Yeah, I'm sure there are more potent/effective dissolvers of the carbon deposits than Seafoam. I bet BG 44K is one of them. But I'd probably buy some fogging oil to use in the cylinders before startup after using them.
I was close to using the intake/carb cleaner that I bought. It says right on the can that it quickly dissolves carbon deposits. I chickened out for fear of cylinder wash, even though we only used higher quantities of cleaner in those cylinders we confirmed were closed. But we had to spray some in to check, and one of them looked closed but did not hold fluid until we turned the crank a bit. Which of course means the cleaner went right into the cylinder.
Old 07-03-2013, 04:58 PM   #77
ChadG
ChadG's Avatar
Drives: 2010 Black Camaro LS
Maybe you can test open/closed with Seafoam and once you know it's closed use something more heavy duty? Thanks for posting in my other thread, this has been very informative!
ChadG is offline   Reply With Quote
Old 07-03-2013, 05:05 PM   #78
skipinminn
Chiquita
Nows when I'd like to SEE the GM customer Service guy! tell us how a catch can isn't a good idea as a Standard Part?????
Old 07-03-2013, 06:03 PM   #79
ChadG
ChadG's Avatar
I doubt he'll comment on it being a standard part, but he could certainly weigh in on fears that installing a catch can voiding any part of your warranty. A lot of us go the extra mile to try to do everything we can to prolong the life of our cars, and it's disappointing that many service departments threaten to void warranties for ridiculous reasons such as a catch can. I had a service department here in CA that won't be mentioned tell me that installing a Mobil 1 oil filter would void my powertrain warranty and that I should only use A/C Delco filters . . . . needless to say I found another service department.
Old 07-03-2013, 06:57 PM   #80
suzook
Drives: camaro
2016 2SS,A8,NAV,NPP,MAG Ride,Sunroof
Hyperblue/JetBlack
suzook is offline   Reply With Quote
Old 07-10-2013, 02:22 PM   #81
NYJets77
Drives: 2013 2LT/RS Summit White
Probably never see that.
Call me cynical, but NOT including a catch can makes some business sense:
1. Why include something that costs extra, might prolong the life of the car, and cause consumers to put off buying a new car?
2. Why include something that would reduce profit for your dealers (less IM cleanings, etc)?
3. The consumer is willing to accept business practices like these.
BTW - I have my 2nd RX catchcan on my 2nd Camaro, and I use hardly any oil at all. Maybe my dipstick is broken.
NYJets77 is offline   Reply With Quote
Old 07-10-2013, 10:48 PM   #82
ChadG
ChadG's Avatar
I agree, but I'd like to hear someone from GM to comment on a catch can and warranty issues.
Old 07-17-2013, 12:29 PM   #83
intensifi
Take a look at post #9:
http://www.camaro5.com/forums/showthread.php?t=307431
This is a shot of LFX valves @ 1500 miles with no catch can. The build-up is starting, but not bad yet.
Old 07-17-2013, 03:22 PM   #84
911medic
911medic's Avatar
I've been following that thread and saw that too. It's that "collar" of deposits on the valve stem. That sucker is hard to remove!
