09-19-2017, 09:37 PM | #1 | ||
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
[ASKED] Camaro SS No-Lift Shift feature questions
Al,
My primary reason for asking this question is to confirm that the No-Lift Shift (NLS) algorithm is functioning properly on my 2017 1SS. At this year's Camaro Fest in Bowling Green, I asked during the Q&A about the NLS algorithm and you confirmed it was enabled on all 6th gen manual transmission Camaro SS cars. I recently tested the feature out and it did not work how I was expecting. Before I use it again, I'd like to confirm I'm executing it correctly and not just banging into a 6500 RPM limiter if that's not how the feature is supposed to work. Could you please help me clear up the following questions: 1. When the accelerator pedal is at 100% and remains there throughout the procedure, what should engine speed do as the clutch pedal gets depressed and the shift lever moved to the next gear? Does engine speed jump to and get held at 6500 RPM or is engine speed supposed to reduce? 2. What are the enable criteria for the no-lift shift algorithm? 3. Is the algorithm tuned exactly the same between the SS 1LE and SS without 1LE package? Background information and follow-up questions: When I perform a no-lift upshift, as I depress the clutch the engine speed will go to 6500 RPM and stay there similar to this video below. I'm concerned that the feature is not working as intended and it might just be hitting a normal rev limiter. Another example is in this post as well: http://www.camaro6.com/forums/showpo...1&postcount=24 However, others (specifically with the SS 1LE) have PDR videos of executing a similar shift and engine speed drops to match up with the next gear. Reference this video: Which video demonstrates the NLS feature operating properly? Does PTM in the 1SS 1LE impact the NLS algorithm?
Best 1/4 Mile: 12.24 @ 115.9 mph Last edited by vtirocz; 10-18-2017 at 09:47 AM. |
09-20-2017, 02:55 AM | #2 |
I thought all manuals were no lift shifts. Dont know anything about the electronics. None of my cars had that stuff.
09-20-2017, 05:51 AM | #3 | |
CamaroFans.com
However, from the threads we have here this is a great question. |
09-20-2017, 04:34 PM | #4 |
ALWAYS-N-BOOST
Great Question
2012 1LS M6 Black-Sold 2013 2LT M6 BluRay- Sold 2015 1SS 1LE M6 Black-Sold 2021 ZLE A10 Riverside Blue - Awaiting Arrival 01/10 |
09-21-2017, 07:45 AM | #6 |
I used to be Dragoneye...
Me, too....I haven't yet tried it in the ZL1 1LE....
09-21-2017, 10:09 AM | #7 |
Instagram: @SSAVAGEVERT
Drives: 2016 SS M6 Vert Join Date: Jan 2016
I'm curious as well to this answer. I have a manual 1SS Convertible and when I attempt a no lift, I'm not hearing the sputter that the vehicle gives off. My question Is it all Manuals or Only manual coupes?
2.9L Whipple | Compstar Rods, Diamond Pistons & GPI Cam | Mantic Triple Disc | Corsa Performance Exhaust | DSX Aux Pump | LT4 Fuel System | BMR Lowering Springs | ZL1 OEM Conversion | 360 Customs Built | And More!
Click & Follow My Build |
09-21-2017, 06:17 PM | #8 |
When will the first question get answered? I'm anxious to get the details on this one!
Best 1/4 Mile: 12.24 @ 115.9 mph |
09-21-2017, 06:29 PM | #9 | |
SABIO
Drives: 2016 CAMARO 1SS Join Date: Jul 2015
There is no guarantee it will even be asked. Expect possibly 2 weeks for selection. Another week for voting and the winner get passed on to Al and the Camaro team. It could take...a week? 2 weeks, a month for an answer from them
09-24-2017, 11:13 AM | #10 |
Moderators,
What's the timing on the first set of questions being selected and poll set up? Thanks for adding this section!
09-24-2017, 11:53 AM | #11 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
I'm not sure why there is so much uncertainty with this feature maybe because it's not listed in the manaul but it definitely does not work in touring mode and it's painfully obvious when it works and when it doesn't.
You either get a smooth shift or you don't. I guess getting an official answer will clear things up |
09-24-2017, 04:10 PM | #12 | |
The question in the first post is clear. Two No lift shifts behaving differently as shown in the videos. Which one is working as intended, or was the feature in the 1LE tuned differently? I really would like to hear straight from the team that designed it to confirm exactly how it's supposed to work.
09-25-2017, 09:15 AM | #13 |
Drives: 2017 2ss, m6 Join Date: Jan 2017
I'd love a true answer to this as well. I'm not even certain how it's supposed to work...but my 2017 SS in track mode works exactly like the first video. There doesn't seem to be a whole lot of rev matching going on...it just lays up at the limited from the looks and sounds of it so I don't use.
09-25-2017, 12:33 PM | #14 | ||
So...at most - a Month from now. |
