Vararam
Old 06-12-2019, 10:26 PM   #1
greycamarollt
Drives: 2010 Camaro V6 LLT
Wrapping BBK headers after installed?
I finally got ceramic BBK headers on my LLT V6, which the ceramic didn't really seem to retain the heat and now looking it cooking my camaro's computer when it is idling for long periods like say a few stop lights. I don't get codes at highway speeds.
I was thinking wrapping the headers with the titanium heat wraps then put a header blanket over the wrapped headers. Overdoing it? I read the wrap reduce the life of the headers but rather change them instead of all the wiring. Yeah I know take the headers off then wrap them... They were such pain on the passenger side to install. Am I crazy to try wrap them bolted to the engine?
greycamarollt is offline   Reply With Quote
Old 06-13-2019, 04:26 AM   #2
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
No need to wrap them if they're ceramic coated.
StingrayblueSS is offline   Reply With Quote
Old 06-13-2019, 12:18 PM   #3
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
What issues are you seeing that you are trying to address? If it is ceramic coated, it should be good. Even stock, you wouldn't have any issues so have you done other work to the engine to need this extra coating?
hrpiii is online now   Reply With Quote
Old 06-13-2019, 12:23 PM   #4
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
Cooking your computer? Please explain...
Honestly no need to wrap them. Everything under the hood was made to handle heat.
GJDM
LsxDoctor is offline   Reply With Quote
Old 06-13-2019, 01:54 PM   #5
GodWentPunk
GodWentPunk's Avatar
Drives: 2015 2SS White Convertible CE/INDY
If they are ceramic coated, then that should be good for heat reduction. Are you 100% sure they are coated??
joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
GodWentPunk is offline   Reply With Quote
Old 06-13-2019, 10:18 PM   #6
greycamarollt
joe...
I had to pay $100 more for BBK ceramic headers, got these from JEGS. When the stock manifolds and heat shields were there I don't recall having that much in the engine bay.
Old 06-13-2019, 10:39 PM   #7
greycamarollt
had i known the temp would be similar i would just save the $100 for a header heat blanket
Old 06-14-2019, 11:59 AM   #8
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Umm...no. There are numerous reports of melted electronics from headers.
And why do you suppose the original manifolds have heat shields?
Old 06-14-2019, 12:03 PM   #9
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I might be more apt to see if you can fab a little heat shield if the Computer is close to them and getting direct heat off them. I am not familiar with the V6's tho. Otherwise I suppose I would wrap them.
Greenhornet2 is offline   Reply With Quote
Old 06-14-2019, 02:38 PM   #10
LsxDoctor
LsxDoctor's Avatar
Manifolds hold way more heat than headers, especially ceramic coated. This is over kill. Show me one 5th gen camaro with melted electronics due to installing headers...
GJDM
Old 06-14-2019, 10:46 PM   #11
DJ_BigC
Rockin' Steady
DJ_BigC's Avatar
Drives: 2010 Camaro 2SS
I second that post. Most commonly I’ve seen oxygen sensor wiring melt due to poor installation/not being cautious enough with securing the wiring away from the header aside from that i’ve never seen one “electronic” component melt from headers.. that just barbaric. To be clear Im talking about 5th gen Camaro’s before I get roasted by keyboard wizards.
Eric Carrier, proud GM Technician for over 10yrs.
2010 Camaro 2SS Black, L99, SLP headers, GMPP axle back, complete JRE tune, 22" Boss 337's, Nitto Invos 5% tint, Eforce Supercharger w. 3" pulley, ADM FPCM, ID850's, JRE fuel rail mod, Eforce CAI, Moroso catch can, spark plug insulators.
DJ_BigC is offline   Reply With Quote
Old 06-14-2019, 10:53 PM   #12
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Zero issues with heat from headers. The BBKs are steel headers with a ceramic coating I think. Does the wrap hold moisture?
rontammy0 is offline   Reply With Quote
Old 06-16-2019, 09:29 AM   #13
greycamarollt
I absolutely agree those cast iron manifolds really held in the heat, the headers seem to act as radiators for heat, I almost felt that I lost hp because by the time exhaust gets to the tail pipe most of the heat lost in the engine bay.
Old 06-16-2019, 01:01 PM   #14
Quicksilver2SS
Quicksilver2SS's Avatar
Drives: 2SS/RS LS3 NPP
Wrapping the headers will rust them
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
Quicksilver2SS is offline   Reply With Quote
