Old 03-27-2010, 02:43 PM   #1
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
Cheap and Easily Removable License Plate Frame (no drilling required!)
Not sure I have seen this posted here before, so I figured I would post up what I did. I live in a state with a front plate law..so it is a must unless you want to be harrased. Putting holes in the bumper was not an option, and since I go to shows, I wanted something easily removable. If someone else posted this..I apologize.
First off, start of with a stock plate frame-
Next, I got the below supplies..basically long ass toggle bolts and washers.
Assemble bolts in frame as shown below-
Next if your worry about the frame rubbing, apply some foam tape or similar to areas the frame can make contact.
Next, I applied some electrical tape to the toggles to prevent them from cutting into the back of the grille.
Next, put frame up to bottom grille, and align so toggle bolts slide into the very first slat of the grill. Then manuver the toggles to they are securly gripping the grille and tighten. Mine grip diagonally in the corner of the horizontal and vertical slats.
Securely tighten the bolts. You should be able to pull on the frame horizontally and vertically, and not have any give.
And here is the end result-
Also..in closing, if you don't trust the toggles for some reason..one other thing it appears you could do as a safe backup, is instead of putting the bottom tag bolts in..you could run a zip tie under the tag, and through the holes and grille.
MarylandSpeed is offline
Old 03-27-2010, 03:29 PM   #2
webslinger408
webslinger408's Avatar
Drives: 2010 camaro 2ss rs m6
SWEET THANKS FOR THE HEADS UP...I LIKE THE IDEA.
webslinger408 is offline
Old 03-27-2010, 04:37 PM   #3
pretty cool
2010 SSRS is offline
Old 03-27-2010, 04:37 PM   #4
papabearcamaro
papabearcamaro's Avatar
Drives: 2012 Chevrolet Silverado 4x4 Z71
Thank you for the post and pics. Even though Wisconsin is a front plate state I just can't bring myself to putting it on unless I definetly need to.
If and when I do,this is the way I will go. Thank you for putting this up.
SOLD(Traded for 2012 Silverado Z71 4x4 and 2012 Sonic Hatch.)...2010 Camaro 1SS/RS/LS3,yellow with House of Kolor Tangerine Pearl rally stripes,manual trans.Hurst short throw shifter,4 pack rally gauges,Roto-Fab air intake,Kooks long tube headers with high-flow cats,Borla S-Type catback exhaust,Comp Cam,PRC ported heads,Maggie with 3.6 pulley and 1:1 cog drive,secondary fuel system with 65lb injectors,ADM digital A/F and Boost gauge,Pfadt trailing arms and subframe bushings.614.25rwhp/566.82rwtq on 8# of boost.
2012 Chevrolet Silverado 1500 EX.Cab 4X4 Z71.
papabearcamaro is offline
Old 03-27-2010, 04:48 PM   #5
MarylandSpeed
This my wifes car. I will be doing the same for the company car in my avatar since there are no other options for cars with ground effects.
Old 03-27-2010, 04:53 PM   #6
JSkibisky
Drives: 2010 1LT/RS
... if you need something that will work with GFX, check out BD Speed Shop...
http://www.bdspeedshop.com/item.cgi?...da&part_id=187
JSkibisky is offline
Old 03-30-2010, 11:54 AM   #7
Ronn
Ronn's Avatar
Drives: 2010 Camaro
good idea!
Ronn is offline
Old 03-30-2010, 02:45 PM   #8
Moorepheus
Drives: 2013 Dodge Charge R/T Plus AWD
I did basically the same thing, but with Cable Ties, they work just fine too
Moorepheus is offline
Old 03-31-2010, 10:48 PM   #9
mikaltima
mikaltima's Avatar
Drives: Ordered: Victory Red 2SS
I live in NJ which is a two plate state and I never put the front one on car and I've been driving 6 months with no problem.
[SIZE="2"][FONT="Comic Sans MS"]Victory Red 2SS/RS
Order Placed-- 7/4/09
3000- Accepted by Production Control:TPW 8/17/09
3100- Sequenced:
3300- Schedule for Production: 8/17/09
3400- Broadcast: 8/17/09
3800- Produced: 8/20/09
4200- Shipped:8/20/09
5000- Delivered to Dealer: 8/28/09
6000- Delivered to Customer: 8/29/09
WAITED 57 DAYS.... WELL WORTH THE WAIT!!
mikaltima is offline
Old 03-31-2010, 10:56 PM   #10
2LTRS
Detailing Connoisseur
2LTRS's Avatar
Drives: 2010 Rally Yellow 2LT RS
I would put some foam or cloth between the plastic and the paint to prevent scratching from friction.
2LTRS is offline
Old 03-31-2010, 10:59 PM   #11
Tech
Tech
Tech's Avatar
Drives: 2010 Camaro 2SS
Send a message via AIM to Tech
mine was installed by the dealership, i'm livin in texas and i'm thinking about removing the bottom grille and puttin the plate there behind the bumper...think it'll fly?
Tech is offline
Old 03-31-2010, 11:04 PM   #12
Hillee
Hillee's Avatar
Drives: 2010 Camaro 1SS
Thanks!...from Texas
Hillee is offline
Old 03-31-2010, 11:06 PM   #13
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
best DIY on how to install stock license plate frame to date
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline
Old 03-31-2010, 11:08 PM   #14
ron10
Drives: 2010 2SS IOM L99
good idea.
ron10 is offline
