02-28-2021, 11:40 PM | #1 |
Drives: 2011 Camaro SS Join Date: Jul 2017
My turbo install- it finally runs.
It's been awhile but the car is running. It still needs a tune which I'll get this coming week. I took a short video. Sorry but it was windy AF today. Recap of mods. It's a L99 with a Huron speed single turbo kit. VSracing 7875 gen1, Summit stage 2 turbo cam with the supporting BTR valvetrain for the LS3 conversion. Exhaust is the 3 inch DP to unk brand X pipe with no resonators or mufflers from previous muffler delete. I did the rear suspension with BMR parts, cradle bushings and ZL1 pump and BAP before the turbo. So far all sounds good and no issues. I'm excited to get it tuned and drive it. I havent driven this car since early last summer when all the install was started!
https://youtu.be/jE2MN9r7PiU
03-01-2021, 02:15 AM | #2 |
Oh man, she's gonna be a beast! My god, I couldn't imagine having a big spinnyboy bolted to my 6.2
Just curious, have the rings already been gapped a bit more or are you just going to keep the boost at a safer low level? What are your power goals with this setup?
03-01-2021, 06:11 AM | #3 |
Evil Genius of Chevrolet
Looking good. Should get some nice numbers from the dyno.
03-01-2021, 10:20 AM | #4 | |
03-01-2021, 11:09 AM | #5 |
Drives: 2010 ss Join Date: Oct 2015
pretty sure you will run out of fuel after 600whp.with the zl1 pump and bap and dont for get about injectors
03-01-2021, 11:12 AM | #6 |
400HP used to be enough..
Drives: 2010 2SS rs manual Join Date: Aug 2009
Glad to see you finally got it running. You'll probably be happy at nine or ten pounds boost. I think it would be more streetable at that level.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
03-01-2021, 11:29 AM | #7 |
Drives: 11 Camaro SS, Ninja 1000, Santa Fe Join Date: Sep 2020
Keep us posted on the tune. Love to see the build sheet and net whp.
11 Camaro TT SS. 14 1LE motor, full coilover, CNC ported LSA heads, stainless valves, dual springs, Comp 224 cam, Melling oil pump, AGP Garrett GTX30r's, 1400cc injectors, full 3" Magnaflow, dual Walbro 450lph fuel pump, ZL1 6L90 trans, trans cooler, Circle-D 3600, 3.91:1 Eaton Truetrac, line lock, Lingenfelter 2 step. Current boost - e85 814 RWHP.
03-01-2021, 11:47 AM | #8 |
Sounds badass! Shes gonna be a beast
03-01-2021, 11:48 AM | #9 |
If on 93, I think you can go a bit past that with a 1050 injector. Could be wrong though
03-01-2021, 12:12 PM | #10 |
I'm using 1000 cc FIC injectors and on 91 octane. I'll prob throw the SMG aux pump on there to be safe.
03-01-2021, 12:16 PM | #11 |
Sounds great man!! She's gonna be a beast for sure!! Good luck and let us now how it goes. Like InFiD3ViL said, I too couldn't imagine a turbo of SC setup on MY beast, it would be awesome no doubt!! Enjoy.
03-01-2021, 02:11 PM | #12 |
over 700WHP here on 12psi ZL1 pump with FPCM no fuel pressure drop.
03-01-2021, 06:25 PM | #13 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
I’m a manual and at 8 lbs of boost, 650rwhp , 1000cc injectors, running ZL1 pump and a JMS booster. No fuel pressure issues and injectors are at 60% duty cycle. With an auto you may be pushing it it should be do able.
03-01-2021, 08:40 PM | #14 |
I'm so jealous
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
