04-25-2010, 09:05 AM | #3697 | |
PWA Relapse
1/4 mile times I think will bounce back and forth between the two. But in high speed acceleration the SS has an advantage. - X
2017 1LT/RS A8 Hyper Blue Metallic |
04-25-2010, 09:05 AM | #3698 | |
Drives: 2010 IBM 2SS/RS Join Date: Feb 2010
Been awhile since I looked at the KB site,I see what you are talking about...those numbers are of course FlyWheel #'s. But also just because a kit is capable of making numbers on a "completely stock engine" doesn't mean the engine and driveline will last. The range is because you can change pullies and change the boost...ie run a big pulley make lower boost therefore less power....or run a smaller pulley,make more boost and more power. Read all the way through on the site...nothing against KB but their site can get a little confusing for some when they start reading the ramble. At 16psi they bent all 8 rods...even at 14psi they were running C16...again regardless of the big print I still say you won't make even 1000 FWHP(~850RWHP) reliably by just bolting on a KB kit...you can probalby make it ...but I doubt it will last. Also when they say stock with a KB kit even they are including add ons...their 115mm TB,2 BAPS ect...those are add ons to their kits..but that still doesn't help the piston,rods or the driveline live. If you want to make that kind of power reliably you need a purpose built short block with lower comp and at a min forged pistons and forged or billet rods..and that still doesn't adress the rest of the driveline. For instance I doubt the stock clutch will live long behind that power...if you are actually using it...then there is the rear axles..and everything in between...it goes on and on...and gets very expensive very quick to make big useable power..now if all you want it a big dyno number doing it "all stock" might be fine. HP POTENTIAL Twin Screw superchargers MUST RELY ON LARGE FREE FLOWING INLET SYSTEM TO PRODUCE MAXIMUM PERFORMANCE. The 2.8, 3.6LC and 4.2LC Kits all use a huge air guzzling 4.5” filter, 4.5” MAF meter and 4.5”x4’ long Ram Air Pipe feeding the MAMMOTH™ inlet manifold (accepts up to 115mm throttle body). Compare that to the competition. Kenne Bell “0” restriction - short runner discharge manifold, intercooler and heat exchanger are designed to support 1000+HP on a 100% stock motor. Forged pistons and rods are necessary at some point but the kit components including the 2.8L will support it, so there’s no upgrading of basic components necessary with the 2.8, 3.6 or 4.2 kits. Just upgrade the stock 90mm throttle body to our 115mm. See Tech Tips for dyno tests. It fits the oversized Kenne Bell MAMMOTH™ inlet manifold and 4.5” inlet system
2010 IBM 2SS/RS Camaro (M6) Previous rides: 2003 Twin Turbo Mustang Cobra(900 RWHP) 2004 KB S/C Mustang Cobra(700 RWHP) 2003 Mustang GT,Heads,Cam, N20 ect.. Last edited by HIGHOCTANE; 04-25-2010 at 09:31 AM. |
04-25-2010, 09:11 AM | #3699 | |
You Can Call Me Jay
Drives: 2010 1LT RJT Manual w/CAI & Solo Join Date: Sep 2009
Kudo's to Ford for releasing some real engines for the 21st Century. They also look better under the hood, in my opinion. |
04-25-2010, 09:15 AM | #3700 | |
Drives: 2003 Cobra Convertible Join Date: Feb 2009
04-25-2010, 09:20 AM | #3701 | |
and you are right. it's not just about hp. once you account for gearing and torque multiplication, the new mustang also makes more tq at the wheels than the camaro |
04-25-2010, 09:34 AM | #3702 | |
PWA Relapse
- X
04-25-2010, 10:04 AM | #3703 |
BOOOOOM MF'R!!
Drives: to Chipotle daily Join Date: May 2009
pointless, like all of these threads.
04-25-2010, 10:24 AM | #3704 |
Drives: FIRST ON RACE DAY Join Date: Feb 2009
I'm going to assume that you all have seen the MT test where the Mustang beat it in every challenge from the 0-60 in 4.3 to the 1/4 mile @ 111mph in 12.7 and even breaking and the skid pad. So yes I believe thing's will be close on average however if you have an auto vs auto it doesn't look good for the Camaro.
04-25-2010, 10:29 AM | #3705 | |
04-25-2010, 10:36 AM | #3706 | |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
Yeah, as soon as the Motortrend Mag shows up, the shoe with be on the other foot. And I'm sure Road and Track will then have their results. GM High Tech Performance and MMFF will have there's. And its pretty easy for a Magazine to create the results they want. |
04-25-2010, 10:48 AM | #3707 |
It sure is. My reason for posting it was to show that it is clearly capable of some great times especially if MT got the results they did.
04-25-2010, 11:09 AM | #3708 |
Drives: 2000 Mustang GT Join Date: Jul 2009
I do believe as speed increases the Camaro will start to gain the advantage. Bigger displacement motor and the gearing starts to work against the stang at high speed.
04-25-2010, 11:12 AM | #3709 |
Dances With Mustangs
It always cracks me up to see people bragging about their choice of car model AFTER they've poured thousands into modifying their car as though the reason they're "walking all over brand xxx car" is because of their model car. Once you start boosting, charging, etc. it has nothing to do with the body style or model. At that point it's money and mods versus money and mods.
Like one poster said there's always that stupid Honda Accord in town that can rip everyone to shreds because the owner put the money and mods in it to get it to that point. Does that make the Honda Accord the best car for performance? No; has nothing to do with it being a Honda Accord anymore; it's money and mods. The drivers I have respect for are the ones that can line up in identical cars next to you and beat you. To me driver skill is the most impressive "performance mod" and the one I respect the most.
Blue Angel is here!! 1SS/RS LS3 M6 IBM |
04-25-2010, 11:27 AM | #3710 | |
Drives: 2005 Cadillac CTS Join Date: Jul 2009
Silly Silly Silly. Sometimes I feel like some of the people on this forum just aren't car enthusiasts. |
Similar Threads | ||||
Camaro VS Mustang Mega Thread | Beau Tie | Chevy Camaro vs... | 3644 | 03-09-2012 07:45 PM |
Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
Official 2011 Mustang GT info released | nester7929 | General Automotive + Other Cars Discussion | 81 | 12-28-2009 03:13 PM |
