Roto-Fab
Old 08-20-2021, 01:33 PM   #29
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Yeah it does suck. On a positive note the machine shop is making progress on the new block and I'll be ordering pistons and rods soon.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 08-21-2021, 11:44 AM   #30
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
FWIW, my Huron twin turbo car can't run any more than 12 degrees under boost without some KR creeping in. This is on 93 pump gas. But, I'll trade timing for boost any day.
FrankT is offline   Reply With Quote
Old 08-23-2021, 11:46 AM   #31
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
What level of boost do you start seeing knock?
gunchamp is offline   Reply With Quote
Old 08-23-2021, 12:41 PM   #32
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
straight 93 (no meth)?
RealQuick is offline   Reply With Quote
Old 08-23-2021, 03:00 PM   #33
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Well I hope you go to a different tuner on the new engine.
Greenhornet2 is offline   Reply With Quote
Old 08-24-2021, 05:15 AM   #34
eLeSthree
Drives: 2011 Camaro SS 6sp
Originally Posted by IKILLEDSUPERMAN_ZL1 View Post
The tune I had is definitely suspect. So after showing the tuner what others had concerns about with his tune he still says his tune wasnt the cause and it had no more then 15 degrees under boost. I mentioned that a SBE with low boost with my mods usually doesn't spit out rods unless the tune was jacked up.
So was it 21 degrees or 15 degrees? Also, did your tuner know you flashed your FPCM after you had it tuned?? Did you change anything else after the tune?
Like other people have said, usually a poor tune shows itself with chipped/broken pistons or popped head gaskets, not rods through blocks.
Did you pay for trans tuning?
[I realize the OP just wants to move on from this and focus on his new build, but I feel like the same thing could occur if he doesnt figure out exactly what went wrong. Communication with your tuner is key]
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 08-24-2021, 02:42 PM   #35
IKILLEDSUPERMAN_ZL1
Tuner said it has no more then 15 degrees but FrankT looked at my tune and said it had 21. I did tell the tuner I had DSX flashed my FPCM to stop the drop in fuel pressure. Redflag right there that I had to send it off to get it flashed elsewhere. Before it was dropping to 50 from 58 psi. Afterwards it held steady at 58+ The tune wasnt touched after getting it back from the tuner. Yes I will not be going back to the same tuner.
Old 08-24-2021, 03:10 PM   #36
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
The fpcm can be flashed with hptuners, so if your tuner didn't know how too do that then he/she is not up to date on hptuners capabilities.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 08-24-2021, 08:24 PM   #37
eLeSthree
Ok hold on.
1. Did Frank see a log file?
2. The stock fpcm commands 58psi at idle and slopes down to 48psi (iabout) by redline. So your fuel pump was capable of supplying the commanded fuel pressure. The ZL1 fpcm tune file tells it to hold 58psi all the way to redline, instead of dropping off to 48. That is probably why your tuner didnt “waste” a credit on flashing the fpcm. You didnt need it. What size injectors do you have? My buddy ran ID1300x2s with a zl1 pump and a bap (no fpcm flash) on E85 upto 830whp. The fuel pressure dropped to 48psi AS COMMANDED and it Didnt matter cause his IDC was 67%.
Anyway, carry on…. GLW your project.
1158whp 1017wtq.
630whp 658wtq
Old 08-24-2021, 11:05 PM   #38
IKILLEDSUPERMAN_ZL1
1000 cc FIC injectors. ZL1 pump and a BAP. I dont think my inj duty cycle was bad. Tuner only mentioned the FP dropping. He was concerned about that but never mentioned if I was running out of injectors. Anyways I appreciate all the input from everyone. I'm just ready to get it all back together and running soon.
Old 09-17-2021, 11:12 AM   #39
Slowhawk
Drives: 1999 Trans Am
As for the tuning part. Always tune them with the MAP, then add the MAF if you want (I leave SD personally) It does make a difference.
Slowhawk is offline   Reply With Quote
