AWE Tuning
Old 07-08-2018, 04:10 PM   #43
Stocktastic
Drives: 2017 Hyper Blue SS 1LE
Hopefully this stuff shows up at Advance or the like soon.
Stocktastic is offline   Reply With Quote
Old 07-08-2018, 04:17 PM   #44
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Originally Posted by Litespeed1000 View Post
Hit 1500 miles and finished changing rear diff and engine oil. My local dealership now carries Mobil 1 ESP, 0w40, Dexos 2.
Oil looked clean in both, far less metal partiicals than the 500 oil change.
What is the cost per qt?
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 07-08-2018, 06:54 PM   #45
ZL14ME
Drives: 2018 ZL1 M6
$11.32/qt at my local dealer. Stupid expensive.
ZL14ME is offline   Reply With Quote
Old 07-09-2018, 01:58 PM   #46
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Drives: 16 SS & 17 ZL1 Both Yellow
Send a message via Skype™ to EDFHOBBIES
Originally Posted by Krowser View Post
Interesting...
My friends and I do a lot of spirited driving here in Florida where the humidity and heat is quite real. I know the atmosphere in Europe is not the same as Florida; however, I can imagine that South Florida's climate is more punishing for an oil than in Europe. Additionally, I don't think Europe uses 10% ethanol in their fuels.
I know more zinc content offers better metal to metal lubrication and protection; however, it is a bitch for catalytic converters. Perhaps for the catless Camaros, the euro spec would be better with the higher zinc content.
GM knows there's a problem with DI (deposits and consumption) that's why the big emphasis on LOW ASH, if you look at all the ingredients for wear items they have a very high TBN number like 12.0 or higher, Euro oils, Mobile 1s best oil, Amsoil ect... this new ESP oil is emissions safe Why? ( u think about it) the additives for wear are the main ingredients that build up deposits they have taken some metal %s outs.. you can see the Analysis at mobile 1, to confirm. Also down a lot is the TBN it goes hand in hand with additives this ESP is 8.5 which is really low for a good synthetic anti wear oil that can go the distance on long intervals.
Examples of low ash percentage oils
.5 to .8 Mobile 1/ ESP, diesels stuff lie SAPS
less than 1.0% is medium ASH
greater than 1.0% is high ASH
The best protection would be a good catch can system and the highest TBN number around.. GO to the DEXOS page I saw no listing for AMSOIL which people swear by, Red line, and other well know proven oils. I did see Royal Purple which a lot won't use anymore.. So they either won't pay to be on the DEXOS 2 list or it won't pass because not being low ash.
as far as the weight change it's a happy medium between street and race for protection and will cut down on oil consumption.. And if oil is being consumed the low ash will not hurt the emissions system as much!
Nothing new I sit through the boring diesel classes with the manufactures to be certified ever year with all the new tier 4 emissions compliant crap stuff low ash oils nothing new so its easier to clean with the onboard regen systems!
Kong Ported 2650, Crawford Racing Port Injection, Weapon X 112mm Adapter, NW112mm TB, Livernois Ported LT4 Heads, Lingenfelter GT32 stealth cam, Haltech Elite, and Carbon by Trufiber
EDFHOBBIES is offline   Reply With Quote
Old 07-10-2018, 02:21 AM   #47
Biscuit.fr
Drives: Red hot ZL1 A10 2017
What is the dexos II specific?
(Except for our warranty....)
0w40 Europ doesn’t look bad?
Biscuit.fr is offline   Reply With Quote
Old 07-10-2018, 04:19 AM   #48
waterman
waterman's Avatar
Drives: Grandad's C2 L89
I feel you brother.
I'm a tier level Cat certified tech myself. As you know, DI will take a massive toll on intake valves and guides, varnish intercoolers and aftercoolers and greatly reduce performance and an engines ability to eliminate heat. Then inevitably, the coking of the intake valves and their guides will float a valve and bounce it around the combustion chamber.
After seeing it first hand over the last 25+ years, I/we understand that especially in a forced induction (turbo and blower) application, the great importance of reduced oil volatility in controlling the effects of DI. As well as the the positive effect that Walker Airsep (diesel catch can) had in DDI applications cleaning up the red headed stepchild of direct injection. I won't even mention the effect that a direct blow by vent (prior to the Walker) had in fouling up an engine room.
IMHO, those of you who are not running a catch can with GDI/PCV are taking a HUGE risk of reducing performance levels and eventually a significant failure. That is without costly media blasting of your I valves and potentially valve guide replacement every 40-50K miles.
You are probably thinking that if it was that important than GM would have made it OEM. That is what Cat and Detroit and Cummins thought as well years ago. Until their warranty costs skyrocketed and MARPOL regs/EPA emissions regs kicked in. Then they had no choice.
Fair discloser, GM did a great job on the clean side of the LT4.
Draining a catch can takes a couple of minutes. However the bean counters and lawyers at corporate understand that if you forget to drain the CC, your LT4 is in a world of sh*t, and then they are on the hook. I believe that they understand that it's not worth the cost and risk to extend motor longevity at the risk of someone who doesn't understand the importance of changing their oil, let alone blowing a motor because they forgot to drain their CC and sucked all of that nasty byproduct into their intake. They understand that coking and varnishing will not kick in a big way until well after 3/36,000 has expired.
FI with GDI? Do yourself a favor and get a CC (that doesn't defeat the PCV) and run a high quality low volatility (low ash as EDFHOBBIES pointed out) full synthetic. It will make your cats happy too. Dexos 2 oils are from what I understand, well engineered, low volatility products.
2018 ZL1 1LE sw/PDR
waterman is offline   Reply With Quote
Old 07-10-2018, 04:40 PM   #49
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
Dealers are all over the place on the ESP 0W-40 Oil
I went for the 500 mile oil change and the dealer looked at me like I was crazy when I asked for the new oil. He said that it was for 2019 Corvettes. He opened my hood and pointed to the oil filler cap (I ordered a new cap today).
I tried to explain but the service tech was not having any of it. I went to the parts department and they said that they did not have any in stock. Is there a TSB # on this change?
Heartbreaker is offline   Reply With Quote
Old 10-19-2018, 11:04 AM   #50
Bolt-onC6
Drives: 2017 Corvette
Here's the liter version for much less.
https://www.tascaparts.com/oem-parts/gm-oil-19353135
Bolt-onC6 is offline   Reply With Quote
Old 10-19-2018, 12:23 PM   #51
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
gmparts overstock has the "new" 0w40 for 7.47 per qt. 19370233 part#. 0w40 Cap is part# 12686472 $4.40.
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold)
'15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold)
'12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 10-19-2018, 12:27 PM   #52
Stephen12ZL1
Drives: '21 ZLE A10
http://www.corvetteactioncenter.com/...date-1389.html
Old 10-19-2018, 12:48 PM   #53
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Originally Posted by Stephen12ZL1 View Post
What stupid website.. can't copy text.. dumb.
ing for grip.
Are you in the NY/NJ/PA/CT region? Join us for autox fun at MetLife Stadium. HUGE lots, tons of runs.
http://www.motorsportsne.com/
Vtor_ZL1 is offline   Reply With Quote
Old 10-19-2018, 06:27 PM   #54
Stephen12ZL1
Drives: '21 ZLE A10
use a screenshot...
Old 10-19-2018, 07:11 PM   #55
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Nothing F12 can't fix.. something leftover from another era.. omg dont copy my text.. yeah, i'll just snip it.. or F12 and rip it off console inspector.
ing for grip.
Old 10-20-2018, 12:58 PM   #56
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
Originally Posted by waterman View Post
I feel you brother.
While there is a lot of good information in this post, I feel I must point out the very long thread on this site where GM voided someone's warranty when their oil pump died, because he had a catch can on his car. His oil pump did NOT die because of the catch can... But GM refused to honor his warranty because he had a catch can and his VIN is now black listed by GM as having an invalid warranty now.
As I plan to keep my ZL1 for a very long time, I will be installing a catch can... But only AFTER my warranty has expired.
I don't want to give the jackholes at the stealership ANY reason to void my warranty.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
